Dtl139 defy top loader keeps showing E4. The lid is closed.
SOURCE: My Neptune top-loader washer,
Evidently the "OP" code indicates the lid is "open". Solution in my case: I had to replace a wire on the lid switch that a
had rusted and no longer connected to the switch resister.
There is a magnet in the left, front corner of the plastic lid insert. When the lid is closed, this magnet sets on top of the tan colored plastic pad on the left front top of the base washer unit. When the lid is closed, the magnet activates two, small metal rods on each end of a resister within the white. You have to pop up the top of the washer base to gain access to the switch, Good luck,
Posted on Aug 31, 2008
  • 4 Answers
SOURCE: I have a brand new LG 8KG top loader washing machine
Thank you for coming back to me, yes I have had the problem solved today. A technician came around to my home and made a slight adjustment to the Lid and said it should never give me trouble again. It was a free service as my washing machine was brand new and it started up perfectly and went through it's full cycle with no hicups!
Many thanks,
Billie. South Africa. ( Durban)
Posted on Jan 06, 2009
sclarke7
  • 222 Answers
SOURCE: Westinghouse house washer LT9555 top loader wont fill with water
bad lid switch
Posted on Apr 07, 2009
SOURCE: My Midea aw60-982 top loader
It's something to do with the draining, check your drainage hose isnt clogged, mine had a bunch of 5 cent coins stuck just near the pump.
Posted on Nov 22, 2010
einstein1
  • 194 Answers
SOURCE: my washing machine thinks the lid is open when it
THE SWITCH HAS TO BE REPLACED
Posted on Mar 21, 2011
I have a Defy DTL 139 toploaderwashing machine. Keep getting a E4 error. Code apparently mean lid is open. How can I fix this ?
Is the latch on the lid damaged. That would cause it to not lock shut.?
Perhaps the keeper in the washer body is damaged of maybe there is a lead off on the electrical contact on the keeper, which tells the control-system that the lid is down & latched.
There might also be a broken lead or loose connector at the other end of this cable where it plugs into the control-board.
Best of luck.
Mar 10, 2018 | Washing Machines
Defy top loader. What is e4 error?
Generally the E4 error means that the tub is unbalanced. You either filled the washer unevenly, or you are trying to wash something too heavy or too large. Take everything out of the machine, and then re-arrange it and put it back in. If you are still getting the error, you need to wash less clothes at a time.
Another possibility is that your sensor needs replacing, the sensor that tells you how full the tub is and when it's off balance. For that, you need to call a repairman.
Jan 22, 2016 | Washing Machines
Will not spin
https://www.google.co.uk/url?sa=t&rct=j&q=&esrc=s&source=web&cd=3&ved=0CEAQFjAC&url=http%3A%2F%2Fwww.stirlingappliances.com.au%2F_literature_842%2F9Kg_Top_Load_Washing_Machine&ei=WMDAUrn-NdGShQfg7ICwBw&usg=AFQjCNE3nkaGkSJGjbGHHlfFGmjl-ADIlg&sig2=o-WcC1F_-YpElGAi5e6FFw i assume youve checked manual if not above link will work,it suggests e4 to mean lid not closed,this could be a switch fault where the lid closes it must physically move a switch inside,or the wire to switch may have pulled out,either way if 3mths old ring for engineer,e2 is pump fault which would also stop machine from entering spin mode,
Dec 29, 2013 | Washing Machines
E4 error showing on a kelvinator kd14ss
good day
my dishwasher give e3 and e4. what is the problem and how can we solve the problem.
Nov 04, 2012 | Kelvinator Dishwashers
Washing Machines Logo
137 people viewed this question
Top Washing Machines Experts
