Question about The Office Equipment & Supplies
Kiesha used a photo that measured 4 inches by 6 inches to make a copy that measured 8 inches by 12 inches. What is the scale factor of the dilation?
    Master:
  • The Master
  • 923 Answers
The scale factor was 2:1, or 200%
Posted on Apr 21, 2017
Tip
LPI, PPI,DPI conversions
Here is a conversion chart for DPI (Dots per inch) to LPI (Lines per inch) or PPI (Pixels per inch)
180 DPI................31 lines/inch or 68 PPI
360 DPI................63 lines/inch or 138 PPI
720 DPI................127 lines/inch or 280 PPI
1440 DPI..............255 lines/inch or 561 PPI
2880 DPI..................510 lines/inch or 1122 PPI
If you plan to enlarge your image, it is better to enlarge it when you're scanning rather than in your application. Each time you modify
an image, you lose some quality. Keep in mind when you enlarge a small photo, such as a 35 mm slide or wallet-size photo, you'll need
to scan at a high enough resolution to retain your image quality, but not so high that your file size is too large to be efficient. You must
manually adjust the resolution (dpi) to maintain the same image quality when you resize your image. For example, if you have a 300
dpi 2 x 2-inch image that you want to enlarge to 4 x 4 (a factor of 200%), increase the Scale setting to 200% or change the resolution to 600 dpi.
on Jul 19, 2008 | Epson Perfection V200 Flatbed Scanner
Halfway point between 2 cities
run a ruler between the two points and half way will be half the distance of the ruler measurement multiplied by the scale of the map example if the ruler is 6 inches between the cities and half way is 3 inches and the scale is I inch equals 300 miles then 3 inches will be 900 miles ( scale is on the front or back of the map)
Dec 30, 2013 | Cars & Trucks
How are you supposed to know if two shapes are similar if there aren't on a grid.
Use a ruler to measure the lengths of the sides and a protractor to measure the angles. The scale factor is the lengths of one divided by the lengths of the other.
Dec 07, 2013 | The Learning Company Achieve! Math &...
What is the Minimum Curve Radius for Model Trains?
The length of your equipment, even more than the scale of the model, is the most important factor in setting a minimum radius. The list below includes conventionally accepted minimums for each of the major scales.
  • Z Scale: 195 mm
  • N Scale: 9 3/4 inches
  • HO Scale: 15-22 inches
  • HOn3 Scale: 15 inches (narrow gauge)
  • S Scale: 20 - 30 inches
  • O Scale ("Toy"): 13.5 inches
  • O Scale ("Scale"): 72 inches
  • On3 Scale: 36 inches
  • G Scale: 24-44 inches
Jan 10, 2013 | Crafts & Hobbies
I have just got a new HP 1050 Deskjet J410 Series printer. I am not able to increase or reduce a document when copying. What do i need to do?
Press Copy until Reduce/Enlarge appears in the top line of the dis
The following options are available in the Reduce/Enlarge menu.
you will have three choices.
Reduce/Enlarge
Actual Size
Custom 100%
Full Page 91%
Legal > Ltr 72%
Also:
Use Photo Fit to Page when you want to automatically enlarge your original
photo to fill the printable area of the paper size loaded in the paper tray.
Photo Fit to Page only enlarges original photos that are standard photo sizes. The
standard photo sizes are as follows:
• 3.5 by 5 inches (9 by 13 cm)
• 4 by 6 inches (10 by 15 cm)
• 5 by 7 inches (13 by 18 cm)
• 6 by 8 inches (15 by 20 cm)
• 8 by 10 inches (25 by 25 cm)
For originals containing text or photos that are not a standard size, use Reduce/
Enlarge.
Manual is HERE Copy functions start on page 27.
Mar 27, 2011 | Office Equipment & Supplies
What is the motherboard form factor of the Sony VAIO PCV-J120 PC Desktop motherboard?
Micro-ATX (mATX, or MATX)
To be sure there is a guide to use.
A full ATX form factor motherboard measures 12 inches by 9.6 inches. 305mm by 244mm
(9.6 inches is approximately 9 and 9/16ths inches)
A Micro-ATX form factor motherboard measures 9.6 inches by 9.6 inches. 244mm by 244mm
http://en.wikipedia.org/wiki/Motherboard_form_factor
(Scroll down)
Regards,
joecoolvette
Dec 12, 2010 | Sony VAIO PCV-J120 PC Desktop
How do you add pictures to the photo fram:
Use PhotoFiltre free photo editor program to edit your pictures.
You may download it from the below link.
http://www.4shared.com/file/gqHN4jSz/pf-setup-en.html
1. Photos should be in .jpeg format.
2. It is better to scale your photos with the above editor to 800x600 pix.
3. Prepare your pictures in a PC using PhotoFiltre. Scale all the pictures.
4. Transfer your pictures from PC to a USB Flash Disk (Memory Bar)
5. Plug USB Flash Disk to your Photo Frame.
6. Probably your photo frame will ask to transfer your pictures from flash disk to internal memory. Accept this and by pressing enter/OK/Set (Any button that changes from one product to another.)
I think it helps.
Jun 15, 2010 | PANDIGITAL 7-Inch Digital Photo Frame with...
62 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
