Question about Dishwashers
On my dishwasher, what does an L1 code mean, and how can I clear it?
3 Suggested Answers
007tech
  • 95 Answers
SOURCE: AR-M257 service code L1-00
L1-00 is determined as "scanner feed trouble". The scanner unit (which holds the mirrors) is not moving as it should be. There are a few possibilities. Firstly, does the mirror unit move when the copier is turned on? if not it could be a disconnected/broken scanner wire or bad drive motor or simply dirt/debris or a loose wire binding the unit up.
If the unit moves on power up then it could be a bad sensor or a bad board not registering the signal from the sensor.
You can check the operation of these items in SIM mode : press the following keys one after the other "P" "*" "C" "*" then press 1 and enter/copy button and you'll see the option available.
I hope that helps.
Posted on Mar 31, 2009
kevin_getz
  • 1031 Answers
SOURCE: What does L1 error code mean on an Electrolux
The only solution I can come up with for this one is that L1 is a Leak Detector problem-When water is detected under the tub. I spent an hour researching this issue. I've never come across this one before.
Posted on May 12, 2012
Zdt12011fa dishwasher is built in and the flood alarm is in operation - how do I reset?
First you need to remedy failure or any leakage than reset appliance.
Under Reset I mean to delete all alarm stored in memory.
1. Turn off the dishwasher.
2. Press and hold S1 while switching on the dishwasher. Keep
holding the Program button until:
- LED L1 blinks, L2 and L3 is on
- Release S1
3. When L1 is blinking, L2 and L3 is on, press the S1 before L2 and
L3 is turned off.
- LED L2 is blinking, L1 and L3 is turned on.
4. Wait till L1 and L3 is turned off, then press S1
- All used LEDs flash 5 seconds on 1 second off repeatedly.
- If buzzer is equipped, it beeps for 5 seconds
- The alarms saved in the memory are erased
5. Switch off the appliance.
26259192-aipk5px1bmfkdpsmrgevaqwn-3-1.jpg Dado
Aug 14, 2016 | Zanussi Dishwashers
Error code CO HOW DO I CLEAR IT ON THE DISHWASHER
Hey Robert, thank you for your post!
Based off the information you have provided your Electrolux dishwasher is displaying an error code of "CO" and you would like to clear it out. The error code "CO" means that there is a miscommunication within your dishwasher. The best way to clear the code out is to perform a reset and you can do that by disconnecting the power cord for at least ten minutes. If the code continues to display this could mean that your keypad, a wiring harness, or control panel may need to be replaced and I would recommend having a professional technician out. They would have the appropriate tools needed to disassemble your dishwasher and test each component. This will help protect you from any unnecessary part purchases. -Matt
Jan 15, 2016 | Electrolux Dishwashers
UL error code on frigidaire dishwasher
Thank you for your inquiry, Elizabeth!
I see that your Frigidaire dishwasher is displaying an error code of "UL" and you would like to know what it means. A "UL" error code means that your dishwasher is in relay test mode. You should be able to clear out the error code by pressing cancel and holding down the hi-temp button. If that does not clear out your error code I would suggest performing a reset on your dishwasher and you can do that by flipping the household circuit breaker off for at least ten minutes. Hopefully this information is helpful. -Matt
Apr 24, 2015 | Frigidaire 24 in. FDB635RF Built-in...
What does L1 error code mean on an Electrolux dishwasher
May 11, 2012 | Electrolux Dishwashers
How do you get past the ****** dam, where the wolves are chasing you, have tried everything
Cheats On the Press Start screen, input CROSS then hold L1 + R1 and input DOWN, DOW, RIGHT, UP. The Press Start message will turn green. During gameplay, the following codes and code effects may be input and activated:
Invulnerability ... Hold L1 and input DOWN, UP, DOWN, RIGHT, RIGHT.
Pevensie Kid Life Restore ... Hold L1 and input DOWN, LEFT, LEFT, RIGHT.
Accrue $10,000 ... Hold L1 and input DOWN, LEFT, RIGHT, DOWN.
Clear/skip current stage ... Hold L1 and input DOWN, LEFT, DOWN, LEFT, DOWN, RIGHT, DOWN, RIGHT, UP.
Unlock All Stages ... Hold L1 and input UP, UP, RIGHT, RIGHT, UP, RIGHT, DOWN.
If the code input is correct, the phrase Cheat Activated will appear. All codes may be toggled off by re-entry.
you can use the clear current stage trick..if you are fedup with your stand now...
Dec 23, 2010 | Buena Vista Games Chronicles of Narnia:...
How do i clear the L1 L2 so on cells?
I do not understantd what you mean by the so on cells words.
1. To clear all lists
Press [2nd][CATALOG] to access the list of commands. Scroll down till the fat right arrow point to ClrAllLists. Press [ENTER][ENTER] to execute the command. Screen displays Done.
2. To clear the list L1 completely
Press [STAT][4:ClrList]; command echoe on main screen as ClrList . You must specify what list you want to clear. To clear L1, you insert at the place of the cursor L1 and press [ENTER]. But to insert L1, you press [2nd][1] (L1) and press [ENTER].
3. Clear L1 and L2 completely you do as in point 2.
Press [STAT][4:ClrList] [2nd][1] [,] [2nd] 2 (L2). On screen command appears as ClrList L1, L2. Press [ENTER] to execute it. Screen displays Done
4. To clear a number in a cell.
Press [STAT][1:Edit]. The list editor opens. Move cursor to the top of the list, say L1. and highlight the heading
The whole list appears on the commande/edit line.
Press [ENTER].
Cursor moves to the entry line where all elements on the list appear between { }.
Use the cursor to the value you want to remove and press [DEL]. Do not leave unneeded commas.
Hope it helps.
Oct 21, 2009 | Texas Instruments TI-83 Plus Calculator
L1-18 code
I don't see a reference to a L1-18. A L1 code is a scanner feed problem. I only show a L1-00 code. Sorry.
Jul 01, 2009 | Sharp AR-507 Copier
What does the code L1-00 on a Sharp ARBC260 copier
L1-00 means that the scanner unit under the glass was interupted in it travle and didnt return to home position within a specified time. Often you can restart the power to clear this.
May 11, 2009 | Sharp AR-C260M All-In-One Printer
I just got a used stove and its a single magic chef eletric stove. when I plug it up it will beep and on the display screen it says L1. what does that mean. im not sure what model it is though. its a older...
Usually L1 is a code for power on. So try to clear it by pushing enter or clear and see if it helps.
Please rate me accordingly if this helps and good luck.
Mar 13, 2009 | Magic Chef 9512 Electric Single Oven
WHAT DOES A L1 MEAN
The L1 is indicating a scanner lock.
1. Turn machine off.
2. Make sure the scanner lock is unlocked. This is a clear plastic knob. (it is located on the left hand side of the machine under the document glass in the copy exit area - check your manual for a picture.)
3. Turn machine back on, watch scanner to see if it moves.
4. Try a copy.
5. If you still get an L1 then it might need service because the scanning bar is jammed.
This also is a fix if you are getting blank copies.
Hope that helps...
Jun 23, 2008 | Ricoh 3310LE Copier
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
