Question about Radio Communications
I have a bearcat 172xl scanner it comes on but will not pick up anything has a new antenna
  • 1,162 Answers
Do you have the squelch turned up to high?
Posted on Apr 30, 2017
  • 328 Answers
SOURCE: need telescoping antenna for Bearcat BC350A scanner
http://www.scannerworld.com/content/product/category/Antennas
hope this helps.....Good Luck!
Posted on Dec 15, 2008
  • 211 Answers
SOURCE: Low Hum Noise in Bearcat III Scanner
Yes, it does sound like a bad power transformer. Try powering it using a DC supply or battery and see if the hum goes away.
Posted on May 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: my bearcat scanner BC147xlt will not pick up codes in my area
Press the WEATHER button. If the scanner picks up a weather broadcast then you either have the wrong frequencies programmed in for your area, or it's possible that you're in a "dead" zone where you just won't receive much without an outdoor antenna. If no weather broadcast is received, chances are that the scanner's processor is "fried." Yours is an old scanner, and they do wear out.
For local frequencies, try CityFreq.com or RadioReference.com. Both have excellent databases.
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Posted on Nov 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: Uniden Bearcat BC 350A scanner won't pick up 800 channels
You BC350A provides coverage of popular bands between 29 and 512MHz, so it is not capable of receiving signals in the 800MHz range. Sorry, but you'll need a different scanner to follow the action.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
For information on current scanner models and their capabilities, visit:
www.ScannerMaster.com
Posted on Jan 02, 2010
Need antenna
This radio has a standard BNC antenna jack. Radio Shack does now offer an antenna with a BNC connector on the end that you can use with this radio.
Dec 03, 2012 | Uniden Bearcat 855 Xlt 50 Channel Scanning...
In moving we lost our antenna.. we can pick up the weather chammel with out a antenna, but that is all.. what kind of antenna do we need?? Radio Shack does not have anything they said would work.can you...
You need an antenna with a Motorola plug, also known as an automotive plug, and a 90 degree angle - or a swivel. You can pick one up on any of the scanner web stores (Scanner World, Scanner Master, Grove Enterprises, etc.) or on eBay. Here's a link to a current eBay listing:
http://cgi.ebay.com/Police-Scanner-Antenna-fit-Cobra-SR-900-BC147xlt-/310183255041?pt=LH_DefaultDomain_0&hash=item48385cdc01
Bill B.
Listening in since the 60's
Jan 04, 2011 | Uniden BC248CLT Base Scanner
I have a uniden bearcat scanner and cant pick up my local police dept. I put the frequency in and still dont hear anything. I have a bc145xl 16 channel scanning radio and want to know if its compatible...
If you programmed the correct frequency, you should be getting reception. Check www.RadioReference.com to verify the frequency. Otherwise, you may be too far from the transmitter to receive signals. Try your scanner in other locations, check your antenna, and try receiving the PD on another scanner.
The MARCS - Ohio Multi-Agency Radio Communications system - is a Motorola Type II SmartZone Omnilink Trunking system that utilizes APCO-25 digital transmissions. Your BC145XL is not compatible with trunking or digital systems. In order to follow the MARCS you will need one of the following scanners:
GRE PSR-500, PSR-600
Radio Shack PRO-106, PRO-197, PRO-96, PRO-2096
Uniden BC250D, BC785D, BC296D, BC796D, BCD396T, BCD396T, BCD996T, BCD996XT, or the brand new HomePatrol-1
Bill B.
Nov 11, 2010 | Radio Communications
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
Bearcat 140 scanner.It will scan but will not pick up any signals,even witha tower antenna? none at all and not myweather channels also.
If you are good with electronics, go to www.mods.dk. They have an alignment manual for the Bearcat 140 series that also includes troubleshooting advice and schematics.
Use the manual for the Bearcat 145XL. It is virtually the same radio as the 140.
The link to the file is:
http://www.mods.dk/downloadmanual.php?RefFil=BC-145XL_Alignment.zip&radio=
Sep 28, 2009 | Uniden BC244CLT Base Scanner
My bearcat scanner BC147xlt will not pick up codes in my area
Aug 16, 2009 | Uniden BC248CLT Base Scanner
Alot of static very little talking
Check you antenna on the scanner. You are describing loss of signal to the scanner. It could be the antenna, the antenna connector, the scanner its self.
Check everything over, Try a better antenna.
Aug 02, 2009 | Radio Communications
Antennas Uniden Bearcat BC148XLT
Height and placement of the antenna determines range. Also, check to see you have the antenna perpendicular to the ground (straight up), and place the antenna where it has 19" clear around it. (not up against a wall or other obstruction)
Placing the existing antenna higher, or replacing it with an external antenna would give you more range. A simple test before purchasing a new connector, coax and antenna for the scanner, would be to place the scanner where you think you would place an antenna and see if it gives you the range you desire.
External antennas are available from most any radio shop. (They would need to know what type of connector you need to connect the coax to the back of the unit.)
Sep 09, 2008 | Radio Communications
Radio Communications Logo
65 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
