Question about Radio Communications
I have a bearcat 172xl scanner it comes on but will not pick up anything has a new annt
  • 211 Answers
SOURCE: Low Hum Noise in Bearcat III Scanner
Yes, it does sound like a bad power transformer. Try powering it using a DC supply or battery and see if the hum goes away.
Posted on May 26, 2009
BillB-SA
  • 2761 Answers
SOURCE: modifiy scanner
Sorry, but by law your scanner is not capable of receiving cellular frequencies, and there is no modification that can enable such reception. Don't feel too disappointed though, as nearly all cellular transmissions are digital now, and that's a mode that your scanner could not decipher even within its frequency coverage.
Posted on Aug 16, 2009
BillB-SA
  • 2761 Answers
SOURCE: my bearcat scanner BC147xlt will not pick up codes in my area
Press the WEATHER button. If the scanner picks up a weather broadcast then you either have the wrong frequencies programmed in for your area, or it's possible that you're in a "dead" zone where you just won't receive much without an outdoor antenna. If no weather broadcast is received, chances are that the scanner's processor is "fried." Yours is an old scanner, and they do wear out.
For local frequencies, try CityFreq.com or RadioReference.com. Both have excellent databases.
Posted on Aug 29, 2009
  • 3 Answers
SOURCE: won't stop scanning
L16 Disc coil needs adjustment, Audio is slightly off, and improper noise to DC squelch level detect used to stop scan on active channel. Set to an on freq signal like a NOAA weather channel, and useing a non-metallic tool, adjust to best sounding audio, probably less than a half turn either direction. An on freq signal moduated by 1000hertz, connect scope to speaker and adjust for highest undistorted recovered audio would be better if you could.
Posted on Nov 14, 2009
BillB-SA
  • 2761 Answers
SOURCE: Uniden Bearcat BC 350A scanner won't pick up 800 channels
You BC350A provides coverage of popular bands between 29 and 512MHz, so it is not capable of receiving signals in the 800MHz range. Sorry, but you'll need a different scanner to follow the action.
For a comprehensive database of active frequencies and systems in your area, visit:
www.RadioReference.com
For information on current scanner models and their capabilities, visit:
www.ScannerMaster.com
Posted on Jan 02, 2010
In moving we lost our antenna.. we can pick up the weather chammel with out a antenna, but that is all.. what kind of antenna do we need?? Radio Shack does not have anything they said would work.can you...
You need an antenna with a Motorola plug, also known as an automotive plug, and a 90 degree angle - or a swivel. You can pick one up on any of the scanner web stores (Scanner World, Scanner Master, Grove Enterprises, etc.) or on eBay. Here's a link to a current eBay listing:
http://cgi.ebay.com/Police-Scanner-Antenna-fit-Cobra-SR-900-BC147xlt-/310183255041?pt=LH_DefaultDomain_0&hash=item48385cdc01
Bill B.
Listening in since the 60's
Jan 04, 2011 | Uniden BC248CLT Base Scanner
I have a uniden bearcat scanner model#bc148xlt and it seems to not want to take the local frequencys and it comes up error when you hit the enter or e button
You didn't mention what frequencies you're trying to program. BC148XLT coverage ends at 512 MHz, so you will get the error message if you try to program anything above that. Also, you must be sure to include the decimal point when programming a frequency into the scanner. I hope this helps.
Need the manual for your scanner? You can download/print it here:
http://www.radiopics.com/1.%20Manuals/Bearcat/Bearcat%20BC148XLT%20%28Manual%29.pdf
For a comprehensive database of active frequencies in your area, visit:
Bill B
May 20, 2010 | Radio Communications
HELP with bc350c scanner, won't pick up feeds
Sounds like an antenna problem. Remove your back-of-set antenna and see if reception changes. If it's the same or nearly the same, check the antenna solder connections inside the set and resolder if necessary. You might also try an outdoor antenna or one of the indoor/outdoor units that's enclosed in PVC pipe. These are fairly inexpensive and can be found on eBay or other sources.
Nov 28, 2009 | Uniden BC350C Base Scanner
Bearcat 140 scanner.It will scan but will not pick up any signals,even witha tower antenna? none at all and not myweather channels also.
If you are good with electronics, go to www.mods.dk. They have an alignment manual for the Bearcat 140 series that also includes troubleshooting advice and schematics.
Use the manual for the Bearcat 145XL. It is virtually the same radio as the 140.
The link to the file is:
http://www.mods.dk/downloadmanual.php?RefFil=BC-145XL_Alignment.zip&radio=
Sep 28, 2009 | Uniden BC244CLT Base Scanner
My bearcat scanner BC147xlt will not pick up codes in my area
Aug 16, 2009 | Uniden BC248CLT Base Scanner
Won't stop scanning
Dec 31, 2008 | Radio Communications
Radio Communications Logo
26 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
