Question about Refrigerators
I have a stictch in my side, it hurts when I breathe and has been there continuosly for 3 days
2 Suggested Answers
  • 2976 Answers
SOURCE: i have a brother xl
There is a small screw on the bobbin holder. Tighten it SLIGHTLY. This will increase the bobbin tension.
Posted on Jan 02, 2009
Does tooth extraction hurts?
This is car and truck repair?
Jan 29, 2015 | Cars & Trucks
Toyota 8000 no longer sews zig zag, the needle can be moved to the side positions manualy
sounds like the cam or gear is damaged or broken, the machine needs to be checked
Jul 16, 2014 | Toyota Sewing Machines
Laptop shutting down with a pop sound.
get a laptop fan pad dont know what popped but not good to set on a cloth surface cant breath get some duster and blow the fan out mabey internal fan weak if so replace
Apr 01, 2012 | Dell Inspiron 15 Laptop
Is my Behringer Powered Mixer PMP2000 cooling fan suppose to run continuosly. It has a distracting hum in our small church. I don't remember it always running (fan) when we first started using it? Help :-[
Sorry, the fan is thermally controlled and USUALLY will run at low speed when unit is lightly loaded. In hot weather or driven hard it will run faster and louder.
Whatever you do, do NOT block airflow... these are a dual 400 Watt continuous amp (600 a side peak) and they need to breathe !!!
If you can duct cool air to it, that will help. You could also try sound absorbing baffles while maintaining adequate clearance for airflow.
Aug 20, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
The freezer fan runs continuosly
It may be because there is some air leak into the freezer. Check if it is closed air tight. Also try defrosting the freezer. Check the fan after that. It may stop working continuously.
Apr 21, 2010 | Kenmore 57029 Side by Side Refrigerator
Sounds like heavy breathing
The # 5 thermistor , pt # WR55X10025, located at the bottom of the freezer , slightly in front of the drain , with 2 white wires going to it , slid into a housing . This thermistor , is the freezer thermistor , which tells the control board , the freezer temp , when to cycle off , and is associated with the fan speed . The " breathing " sounds like the fan speeding up and slowing down . Replaceing this thermistor , should fix the problem .
Jan 20, 2010 | GE Refrigerators
Help! My GE Profile Arctica runs 24 hours a day...sounds like a fan. It stops when either door is opened, then starts as soon as the door closes. The temps on either side are higher than what they are set...
It is normal operation for ARTICA fans to run continuosly except when the door is open. If the door remains open for 3 minutes the fans will run anyway.
The temperature will vary about 6 -8 degrees from the selected temperature. The temperature will increase during a defrost cycle.
I do not believe you have a problem.
Apr 21, 2009 | GE Profile Arctica 25.4 Cubic Feet...
1995 chevy cat conv removal
its against the regulations to remove and is a criminal offence,to use a vehicle fitted with this or anything else thats come from the factory means the vehicle is not complying with the homogolonation certificate.But you should gain 10% minium more power.or recycle this gas guzzling monstrosity and turn it into 3 smaller cars and let the kids breathe fresh air
Feb 18, 2009 | 1995 Chevrolet C1500
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
