Question about Black Office Equipment & Supplies
Do I need black and white or colour photo for NZ passport getting conflicting information my passport at present has black and white photo
SOURCE: Printing photos
its ok I solved it! I didn't realise that all the photo cartridge does is gloss over the colour picture produced by the colour cartridge. I simply had to replace the colour cartridge which had run out, so now its all working perfectly!!
Posted on Apr 09, 2008
SOURCE: Red mist on both black and white and colour prints
remove printer driver. and reinstall its driver.
Posted on Jul 19, 2008
  • 9 Answers
SOURCE: Printing black and white photos from digitally taken colour photos
Hi Pat,
First you will have to check the Nozzle of your printer. To do this, press the setup button and select Nozzle Check. Use a plain paper to do this. Press Ok after that. It will print out a pattern for each color. Make sure that the lines are connected to each other specially for black since that you are printing a black and white photo. Lines going across is on a stair case pattern and should be connected to each other. Proceed with cleaning cycle if needed.
You can do a cleaning cycle using your printer of the computer. You can skip this if you have a good Nozzle check.
Using printer:
Press setup then select head cleaning.
Using computer.
Go to utility of the printer and find maintenance. Click on the head cleaning button.
Once that the nozzle are fine, you can now try printing. I strongly suggest that you use other application first instead of Adobe Photoshop. Since that Photoshop uses color management, it can be that the settings are incorrect. Save first the picture that you opened in Photoshop. You can save it on your desktop to easily locate the file. Make sure that the file is in jpeg format. Now to isolate the issue if it is cause by a software or not, try the standard application for your O.S.
Smaple Application:
Windows O.S. : Windows Picture and Fa Viewer
- right click on the file and select open with.
- select windows picture and fax viewer.
- folow the on screen instuctions.
Note: If you are now on the window on what pinter to use. Make sure that you set the option for printers under preferences to print in gray scale or black only. Select also the correct paper type.
- Proceed with printing.
Mac OSX: Preview or Iphoto
- open the picture under one of the application.
- click file then print.
- Make sure printer is selected.
- underneath the print option, you will have to go to print setting.
- find the option that says color then select black.
- select the appropriate settings for paper.
- the click on print.
Now see if it did print out corectly. If it did, it means that the appplication is the one causing this. If you are familiar with the color manage features of the application Photoshop. Let Photoshop handles the color. After getting to the widow what printer to use, to the the preferences of the printer and select the correct paper type. You will have to find the color management of the printer.
For Windows, It under the advance option under the main tab. Select off no color adjustment.
For Mac instead of going to print setting, find color manage and turn it off. Select off no color adjustment.
Then try printing.
Regarding your other question, If the printer is producing excess inks on your print out when ot comes to black printing and color printing, that pad needs replacement.
Posted on Sep 09, 2008
  • 6 Answers
SOURCE: Not able to scan in
the canon ir3300 have only black & white scanner not a colour scanner, if u want to scan colour photo then go for ir 6600 or ir105 model
Posted on Mar 09, 2009
  • 423 Answers
SOURCE: Grey Photos
Early production versions of the S1000 had this error in the firmware. There is a firmware upgrade that addresses this problem. Here is a link to the upgrade;
Later versions of the S1000 came from the factory with this version of the firmware, and the colour problems stopped. Customers of mine who have performed the upgrade all report the problems to be rectified.
Posted on May 30, 2009
White Lines over Black Colour?
May 07, 2014 | Canon MG5250 Printer
Change Photos from Black and White to Coloured
Unless you want to colorize them by hand, there's no way to add color to black and white photos. Given a black and white photo showing a person in a gray dress, how do you know whether the dress was blue or red or some other color?
Dec 18, 2012 | Fujifilm Finepix S4200 Digital Camera
Photos are black and white only. Cannot get colour.
Look under "Color Options" in the Shooting menu.
Jul 04, 2010 | Nikon Coolpix S210 Digital Camera
MP800R: Error code:201 - Printer can print but not Scan!MP800R: I can use the printer for printing al right, but when I try to scann I get a message that I should close the printer, and read the manual...
Error code:201 occurs due to USB conflict or software not running properly....
Solution#1: Take out the scanner from USB port... shut down the computer.... then restart the computer and plugin your USB plug in anyother USB port(not the ealier one).. Then check if that works.
Solution#2: Click on Start > Click on Run > Type Services.msc press ok.... on the services window check for "Still Image Service" right click on it and select properties .. then click on stop then start(if it is already stoped then click on start).... also make sure the Startup Type: Automatic....
Jul 17, 2009 | Canon Office Equipment & Supplies
Not able to scan in
Mar 06, 2009 | Canon imageRUNNER 3300 All-In-One Laser...
Printing photos
Apr 08, 2008 | HP DeskJet F380 All-In-One Printer
Epson DX4000 printer
Try this. Removed the color cartridge. Open the printer settings under Quality and check the box that says print in "greyscale" or "black and white.
This will rule out and color cart problem and also change the printer settings. You will have to change this back to print in Color,
Hope this helped........
Feb 06, 2008 | Office Equipment & Supplies
Fujifilm finepix A500
This camera does not have the facility to take "black & white" photos. However it is easy to convert the colour pictures to black & white using software once they are on your PC. Here is a great FREE utility that will do what you need: If you need any help with it let us know. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 25, 2007 | Fujifilm WL-FX9B 0.79x Wide Conversion...
Trouble printing to photo paper
The paper you print on is not relevant. What happens is the green tint is the actual printer delivering all the colours to give a 'composite' black. On shiny photo paper this is emphasized where as on plain paper the colour is absorbed and shows as intended. So what can you do? Move away from black and go for a tint such as sepia.
Jul 03, 2007 | Canon PIXMA MP830 All-In-One InkJet...
22 people viewed this question
Top Black Office Equipment & Supplies Experts
Walter Dominguez
Level 1 Expert
Lawrence Oravetz
Are you a Black Office Equipment and Supply Expert? Answer questions, earn points and help others
