Question about Pool & Spa
Should there be continuity between the common and high/low speed wires.
  • 3600 Answers
SOURCE: Replacement pump for spa (Waterway Executive Euro 2 speed 2 hp
V1 would be low V2 would be high U1 would be line and then ground. A picture would be helpful to be sure.
Posted on Jul 05, 2009
muralme
  • 20 Answers
SOURCE: I am Replacing a pump motor and I'm not sure of the connections
high speed phase neutral should go to High speed {phase} neutral low speed {phase} should go to neutral .....Low speed and high speed {phase} need not be connected
Posted on Jul 12, 2009
  • 64 Answers
SOURCE: Replaced Single Speed Pool Pump Motor with 2-Speed Motor
You will need a two speed time clock to really take advantage of real energy efficiency savings. Intermatic makes one that fits in place of the original t104 time clock. You will need to run an additional wire to the pump as well. You will have the ground. Then one common wire that is always hot whether or not you are on high speed or low speed. You could make this a white wire. Then a black wire for your high speed that is energized in high speed and a red wire for the low speed. It is important that the high and low speeds not be energized at the same time, otherwise you will hear a very unpleasant sound coming from the motor, and failure and shortened life of the motor will be realized. HTH
Posted on May 29, 2010
john224
  • 1378 Answers
SOURCE: I'm trying to hook up
Yes, it will handle the voltage...
It is odd indeed as a normal AOSmith two-speed motor will have quick-connect AND screw posts for line connection terminals. If you are certain there are only two screws yet the motor is a two-speed then the answer to the first question is yes; you'll need a female quick-connect terminal for your second line connection to the A terminal.
John
Posted on Apr 11, 2011
Testimonial: "Thanks. It's hooked up and working."
SOURCE: need wiring diagram for speed control switch. Northern Tool doesnt have it
No diagrams here! Do an Internet search using Yahoo or Google, and check for diagrams available manufacturer's website.
Posted on May 12, 2015
Replacing a waterway 56 executive spa pump 3 hp with 4 hp. how do I wire plug into 4 hp pump
The pump motor should have a label on the side of the motor showing a diagram for Common, High speed, Low speed and the right positions for the connections.
Common is always the white wire
High speed is normally red
Low speed is Black
Green wire is always green
Oct 02, 2015 | Waterway Pool & Spa
Pump won't work on low setting
Most multi-speed motors have have a winding that is connected in as many locations are there are speeds. (two speed - two connection points, etc.). It is possible the the low speed portion of the circuit (the switch, wire, any connections between switch & motor) has failed.
You can check out the switch with a meter to see if there is continuity from the common terminal thru the low speed terminal. Then, continue to the motor itself. The motor should have a wiring diagram on it that describes how to wire for speeds, directions, etc.
It may also be an open low speed winding in the motor. It happens. I strongly caution against testing for power on the tub. It is too easy to suffer an electric shock working around a pool / spa. You should be able to test with an ohm meter and power OFF.
Nov 13, 2013 | SpaBerry Pool & Spa
2 speed switch wiring dieagram
The motor will have wiring diagram and voltage on nameplate.
You can re-post question with information that shows on nameplate for more exact information, or keep reading below:
If motor is rated for 240Volts, then it will not work with 120V.
If motor is rated for both 120V and 240V, then either Low voltage or high voltage will work, and one wire will be common, and 1 wire will for 120 and other wire for 240.
If motor is rated 120Volt two speed, then one wire will be neutral, and 1 wire low speed, and other wire high speed. You can connect your wire to either low of high, and cap other wire.
If motor is 240volt two speed, then one wire will be common, and 1 wire low speed, and other wire high speed.
If motor is rated 3-phase, then all three wires are connected to the voltage shown on nameplate.
If motor is rated 3-phase two speed, you may need electrician to wire the motor correctly.
http://waterheatertimer.org/pdf/AO-Smith-motor-wiring.pdf
Jun 08, 2012 | Westinghouse Electric Westinghouse...
May 29, 2010 | Hayward 2HP Pool Pump Motor A O Smith...
Have three wires on my air handler blower motor and need to know what order they go in?
Chances are that you have a low speed, high speed, and common lead (wire). One of the three wires should be white, this is your common, or neutral. If you ohm the other two wires, one at a time with the white wire, you can determine which speed is which. The higher the resistance the slower the speed. High speed should go to cool, and low speed should go to heat. Hope this helps.
May 04, 2010 | Fluke Networks Fluke 902 True Rms Hvac...
Wiring diagram for flo-master 56 frame xp2. I have a new pump that was improperly wired from the factory.It is a two speed pump only running one speed. If I knew where the factory wiring should be...
The side of the motor will have a wiring diagram for how to connect the common, low and high speed leads. Your wire harness should have a white (common), black (usually low), red (usually high) and green (ground) wire. If high and low are backwards, switch the black and red leads.
Nov 23, 2009 | Aqua Flo Aquaflo Flo - Master Xp2 2 Speed...
Replacing plug on a 2 speed magnetek 1.5 hp motor
More often than not red is high and black is low. The white is the common and of course green is ground. If High and low are backwards, swap the red and black.
Jul 31, 2009 | Pool & Spa
The new switch is 2 layered - the old one isn't 2 layered
you have to find which wire does what on your switch.Its a three speed fan so you should have three wires that go from the switch to the fan,and one wire that goes from the switch to the hot wire from your house.What you need is a continuity tester.The switches common wire connects to the hot wire from the house.To find this wire you use the continuity tester.as you switch the switch the common wire will be either disconnected from all other wires,or it will be connected one at a time to each of the other wires.only the common wire will be connected to more than one other wire from the switch.If you don't know how to use a continuity tester.it is pretty simple.It has two leads that come from it and when you touch the two wires together the tester lights,or buzzes,or it changes a reading on a display,or all three.depends on what kind you have.what your doing is instead of just touching the leads together your doing it through the switch leads,and hence through the switch.anyway after you find the common wire the other three wires connect to the inputs of the fan.You really want to connect the first wire that connects to the common through the switch to the wire that turns the fan on low then the next wire to the medium then the high.It wont blow up or anything if its in the wrong order,but it wont switch from low to medium to high.
May 21, 2009 | Speed Ceiling Fan 3-speed Switch By...
Ge motor c474
Typical Diagrams Will Be As Follows
C - Common
H - High Speed
L - Low Speed
_____________
W/white - Common
B/black - High Speed
R/red - Low Speed
Apr 09, 2008 | Kitchen Ranges
Pool & Spa Logo
35 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
