Question about Comfort Zone Heating & Cooling
Comfort zone quartz infared portable heater model # CZ-1500WT. When power is turned on all it shows is A05, won't do anything else
2 Suggested Answers
  • 4736 Answers
SOURCE: I have a comfort zone
Unless you want a new house, stop using that heater immediately. There are severe internal electric problems with your heater. Since it's already 3 years old, I'm not sure it's worth trying to repair. With what you described, I'm surprised it didn't trip one of you circuit breakers.
Be safe, Don't continue to try to use this heater.
Posted on Jan 20, 2011
Comfort zone infrared heater keeps flashing A05 what does this mean?
A05 code is over heat error, unit has to be cleaned thoroughly. take unit apart and clean, I use a rag,brush,vacuum and compressed air. .
press the helpful button and check links below on disassembles.
Comfortzone CZinfrared removing cabinet how to
Comfortzone CZinfrared panel removal How to
Comfortzone CZinfrared bulb replacement How to
Jan 30, 2016 | RTO Comfort Zone Electric Portable Space...
What is the A05 message mean?
A05 overheat condition, you must clean thoroughly,
I have a code A05. What does that mean?
Hold the two buttons on right with power on to reset.
Dec 19, 2012 | Comfort Zone CZ1500WC Infra-Red...
I have a Comfort Zone CZ1500W showing an AO5 error code. I have 9 ohms across each element. The fan thermostat reads open. When I bypass it the fan runs, but no heat. The element thermostat reads
Everytime I turn on the CZ heater, the display reads A05 and then it goes away when i set the temp. As far as I can see and feel, I'm not experiencing any issues with the heating, fan, or thermostat or the extension cord running hot. I'm concerned that something could be wrong or unsafe, with Comfort Zone filing for Chapter 7, anyone know who is offering support or a number I can contact?
Dec 02, 2011 | Comfort Zone CZ1500WC Infra-Red...
CZ 1500 infa-red black plastic cabinet portable heater(3 years old) won't start. Is it a fuse problem since the outlet is powered? Its been shutting off on its own and needing to be started the last
No not a fuse, maybe the transformer or high limit switch. This could be a couple different things. First we need to make sure that there is not a short. The unit should be taken a part to make sure that there are no shorts.
Nov 10, 2011 | Comfort Zone CZ1500WC Infra-Red...
I have a comfort zone heater 1500W Portable Quartz infrared heater CZ-1500WT For the first two years it worked perfectly - two weeks ago the electric plug end that goes into the receptacle gets...
Jan 18, 2011 | Comfort Zone Heating & Cooling
Flashing A05 message
Hi. Did you see it http://www.fixya.com/support/t6866069-comfort_zone_infrared_hearter ? It's you possible decision...
Ted Infrared Heaters Guide
Dec 04, 2010 | Comfort Zone NEW 09 Electric Portable...
My comfort zone infrared hearter has a display message of A05 and will not run, what does that mean? How can I fix it?
Hi. I have the Comfort zone 1500 (cz 1500) and just ran into this AO5 problem. Turns out the thermostat was set lower than the actual room temperature. I just turned up the heater temp and it kicked right on. Hope this helps!
Nov 16, 2010 | Comfort Zone Heating & Cooling
Need manual for serial # E0825340 model CZ 1500 wt
my comfort zone cz1500wt shuts off when turned on code A03 appears on the display
Oct 25, 2010 | Comfort Zone NEW 09 Electric Portable...
Heating & Cooling Logo
44 people viewed this question
Top Comfort Zone Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Comfort Zone Heating and Cooling Expert? Answer questions, earn points and help others
