Question about Pocket Health & Beauty
Pocket scale reads full, won't calibrate. ES-100
SOURCE: CALIBRATION OF POCKET SCALE
Press and hold 'CAL' key to calibrate the scale. www.luxford.cn
Posted on Dec 14, 2007
blueextc3221
  • 15935 Answers
SOURCE: Tanita BD-590 calibration
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
  • 2509 Answers
SOURCE: I have fuzion rogue -650 digital pocket scales but
You can use the weight of coins to calibrate the scale. Since I don't know where you are here are some examples.
use the newest cleanest ones you can as they do wear and change slightly
http://www.usmint.gov/about_the_mint/?action=coin_specifications
http://www.royalmint.com/discover/uk-coins/coin-design-and-specifications
Posted on Jul 19, 2014
SOURCE: How do I change my 100 gram weigh max scale from
a scale is calibrated at half it's capacity. when you use a 50 gram weight to calibrate it, it can still measure 0-100 grams properly.
Posted on Aug 15, 2014
  • 10 Answers
SOURCE: I am having trouble calibrating a US-Magnum 1000
Ty for response. Are they color coded (yellow, red, white) and are they hooked up correctly? Have you tried plugging them in differently- do so if not just to see. Do you know how to get to your video card properties/settings? If you right click an empty spot in desktop there should be either a nvidia or an ati control panel option depending on video card. Do you know what video card you have (or the card that the vga cables are plugged into on pc)?
Posted on Oct 21, 2014
How do I fix a manlloro digital pocket scale when it reads HHH?
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
Jan 03, 2015 | Health & Beauty
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Pocket scales read hhh turn
Try this - While it is off, press and hold both the mode and the tare* keys at the same time and press the On/Off key - Release the keys and observe the display - cycle through a series of numbers. Press the mode key once and observe the display "CAL 0" "100.00" then similar numbers as before. This step calibrates
Check here - http://wiki.answers.com/Q/How_do_you_calibrate_digi_weigh_scale_DW-100AX_or_fix_errors_such_as_F--H_or_ERR?#slide=1
Apr 12, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My digiweigh scale reads HHH. What does this mean and how do i fix it?
It worked on mine,
I pushed Mode, Power, Tare at the same time.
It came up in Cal mode.
I added penny's till it was 995 or so then added small pieces paper to it till it was 100 then up popped passed. I turned it off then it works fine now.
Thank You!!!!!!!
Oct 19, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Operating instructions for Volt -100 pocket scale
If you don't have the measured weights that sometimes come with scales or can be purchased individually, I'd recommend using a United States nickel/5 cent coin. They are supposedly an exact 5 g's each, and a Volt-100 scale requires 100 g's for recalibration. Therefore, you can recalibrate your scale using 20 nickels. I also use a Volt-100 and so far this has worked for me exactly; the most it's ever been off is .02 g, which is basically nothing.
What you do is remove your batteries, (I'd replace them with brand new ones if you have the option) then place the scale on a completely smooth, perfectly level, flat surface. Power the scale on, make sure it is reading 0.00, hold the M (mode) button until CAL comes on the screen, release the button for a quick second, then press it again one more time (quickly, don't hold this time), and then wait until "100.00 g" is flashing on the screen. Then you're going to place your 20 nickels on the scale as smoothly and with as little jostling or movement as possible. After a moment, the screen should read out "PASS". You then power the scale off (don't weigh anything before turning it off as it can possibly adjust the calibration you just set or weigh out heavily or light) and to test out your newly calibrated scale, turn it back on and weigh one nickel. It should be exactly 5 g's, with no more than a .02 digression in either direction if done properly. Good luck!
Jul 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Scale is reading F--H
Mine did this also, I got a replacement and it also read F--H. I took all the screws out - they hid them under the bar code sticker and under the stick-on faceplate where the buttons are - then found that the screws on the load cell which is sort of like an aluminum tuning fork had been tightened so much that the cell was reacting to the screw force, not the scale pad. Release all the pressure and you may be able to make it come alive again. One of my two is working now but calibrating is another thing all together because the linear counting depends on the loadcell screws being set just right.
Jun 03, 2011 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
When I check my scale with 100lb weight it reads 100 kg or 220 lbs??
you need to turn the calibration setting to 100 lbs, then it will be calibrated
Mar 17, 2011 | Detecto Model 6855 Bariatric Scale
Scale displays OUT2
you need just to recalibrate it:
The procedure is standard for semi-all models of pocket scales, but the way how to get to calibration mode differs from model to model (or vendor to vendor).
In brief:
1.While turn-on get to the calibration mode (by pressing and holding the ON button, or holding TARE while turinig on) You should hold this "magic" combination until the LCD will show a number (large number - it was more than 2000 in my case). This number is a raw data from the sensor.
2.Now release the "magic" button.
3.Press it one more time, the display will show 2Ero and then 100.0
4.Now put calibrated weight of 100 grams on the scale and wait 3 seconds.
5.Press "magic" button again.The display will show CAL and then PASS.
6.Now remove the weight and turn off the scale.
7.Thats all - now you can use your scale as usually.
Jul 26, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Health & Beauty Logo
48 people viewed this question
Top Pocket Health & Beauty Experts
richie46
Are you a Pocket Health and Beauty Expert? Answer questions, earn points and help others
