Hdmi mother board fo tv - Televison & Video
Tv picture ok but alot of times if channel is hd it will break up and shows a black screen with weak or no signal
This could be an issue of not enough signal from your HDMI cable, make sure that cable is ok, if possible hook another TV up and see if it works ok
Another issue is a bad main or mother board, the one the HDMI plugs into, there is an IC on that board that does nothing but process the high def signal, that isn't a part you can change yourself you would need a replacement board.
Nov 11, 2017 | Televison & Video
Samsung TV LN46B530P7FXZA version AA01, ser num AUCU3CUS300985R,
Change the video board. It seems like it is blocking power. The relay signifies that power is working properly.
Nov 14, 2016 | Samsung Televison & Video
Samsung Tv #un46c8000xf changes video sources.
The mother board is faulty. You have to change the main board. If you wiah to get some details about flat panel TV repair then check the below link.
http://electro-medical.blogspot.com/
Jul 06, 2016 | Samsung Televison & Video
Tv has new power supply board and is dead
Have you checked the fuse? Did you verify that the power cord is good (check with multimeter to ensure that it is supplying the correct voltage)?
Apr 19, 2016 | Philips 29PFL4908 29 720p Widescreen LED...
I have sound butvideo is just multi coloured verticle lines
HI,
When you make any connections to the Lcd tv or led tv you have to make sure that all the devices are unplugged. if it would lead to major problems. they to check by using another hdmi port in you tv. Normally all tv has more than one hdmi port. also check the tv is it showing good picture while using cable box. If all the inpout it shows the the line then the t con board o the mother broad is faulty
Remove and reconnect all the connections on the t con broad. if the problem exist even after that you have to go for a new t con board . in some tvs the t con board is not replaceable as it is integrated to the lcd panel.
check the video it will help you to identify the t con board
LCD TV Repair Tutorial Con Board Common Symptoms Solutions How to Replace...
www.electro-medical.blogspot.com
Sep 26, 2015 | Televison & Video
Is it possible to turn a malfunctioning 55" tv into a monitor by bypassing the motherboard?
Check and see if you have the following:
HDMI input on the back of your TV.
The ability to switch from standard input to HDMI.
If both are true, you can plug a HDMI cable into your TV, change the setting to HDMI (port # if you have more than 1) and you will bypass the Channel selector part of the mother board.
Give it a try and let us know.
Semper Fi,
Z
Aug 03, 2017 | Insignia Televison & Video
HDMI from Virgin cable box to Samsung 400px monitor
should have vga cable and sound cable is the same as the mic cable normal'y green jack on mother board, vga is standard flat screen for computer plugg'es into tv comp or aux will have on tv menu hmi aux,comp
Jan 02, 2014 | Samsung SyncMaster 400PX 40 inch LCD...
Does my laPTOP HAVE HDMI HOOKUP FOR TV
No, HDMI is not supported by the mother board. Sorry.
Jan 05, 2013 | Acer Aspire 5250-BZ455 -25793
Whe is the mother board on a vizio gallevia tv
Usually there are only about 3 or 4 boards in an LCD TV. the mother board will be the large one that usually also has the HDMI and AV connectors on it. It will not be the one that the power cord plugs into.
Sep 20, 2012 | Vizio VO47L 47 in. LCD TV
Bad hdmi port
If you have a bad HDMI port you have to abandon it because it is part of the motherboard and in most TV's cannot be replaced on site by a technician. The mother board has to be shipped back to the factory or a very good service center for HDMI replacement. Ask for a quote before you decide to get it fixed.
Jul 06, 2011 | Samsung PS42A410 42 in. HD-Ready Plasma TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
