Question about Craftsman Garden
I have a craftsman model no. 917.374369 lawn mower. It runs for a while then quits.what is wrong
    Loyalty:
    Visited the website for 30 consecutive days.
  • Craftsman Master
  • 1,101 Answers
I would check the spindels on the mower deck see if one or both bearings are bad when they get hot they seize up putting strain on the motor causing it to shut down.
Posted on Dec 20, 2017
SOURCE: craftsman lawn mower
I had both my front wheels wobbly - so I cut shims from a tin can - wrapped the axle of the wheels with the shims and then inserted them back into the plastic bushes. It was a snug fit - but helped quite a lot.
Posted on May 27, 2008
  • 6 Answers
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
Posted on May 31, 2009
bargainbin2
  • 123 Answers
SOURCE: 13.5 hp Craftsman lawn mower 5-speed
Here is a picture to help you place it on right. There are two deck designs pick yours.
Posted on Aug 29, 2009
vincob
  • 718 Answers
SOURCE: my craftsman self propelled lawn mower no longer
if it is a belt driven drive check the belt for tension or break. or check the cable that engages the drive wheels.
Posted on Sep 04, 2009
SOURCE: possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Posted on May 08, 2010
MY CRAFTSMAN 6.75 HORSEPOWER 21" MULTI-CUT POWER PROPELLED ROTARY LAWN MOWER MODEL NO. 917.377972 WILL NOT START AND RUN . STARTS THEN QUITS HAVE TRIED EVERYTHING IT HAS BEEN A SHOP LAST TWO YEARS HE CAN...
If the carb is new, then make sure the fuel is fresh- LESS THAN 30 DAYS OLD!!! Is the plug good? Air filter OK? Good oil in the engine? Make sure that the shut off cable hasn't stretched. It may make contact and shut off the engine.
May 20, 2014 | Mtd 22" Yard Machine Push Mower
Won t stay running
could be a bad coil
Oct 15, 2013 | Craftsman Garden
Riding mower v twin acts like its running out of gas how to check what is wrong
Does it idle normally, but only start starving of fuel under load or high revs?
If so, check the fuel filter - just a simple plastic cylinder that the fuel line runs through before going into the carburettor. Quite cheap and easy to replace.
Aug 26, 2013 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 18.5 hp, 42"cut, riding lawn mower quits running after 10 minutes
ONE OF OR YOUR COIL PACK...(UNIT PLUG WIRE COMES FROM IS PROBABLY DEFECTIVE
Jul 29, 2012 | Craftsman Garden
Craftsman lawn tractor model no.917.289101 stalls out
Stall or quits? Will it run 15 minutes again after it cools down. Check
carb bowl for water. Loosen the bottom screw a little until gas come out and water will "roll" off the gas that drops out on the deck.
May 21, 2012 | Craftsman Garden
Craftsman riding lawn mower steering shaft fell. Mower will not steer. I just started mowing, and the mower quit steering. Looked underneath, and it appears the shaft came loose that is used to steer. Any...
Look under the seat of your tractor and note the complete Model number.
(usually begins with 917. _ _ _ _ _ _ )
Next, go to THIS PAGE and use the Model Number to find an exploded view of the steering components and how they assemble.
Hope this helps,
Dolf-
Oct 15, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
What year model is lawn tractor (mower), advice or solution
Hi there Avu
It's quite east to see when was your tractor was made, follow these simple steps and you'll know how to see what model it is
  1. Lift the tractor / mower seat (pull it up)
  2. You will see there's a small metal label with the serial and model number of the tractor / mower
  3. Check the serial number of the tractor / mower
  4. the first six digits of the number are you the model month day and year (i.e 090999XXXXXXX this tractor was made in September nine in 1999
Hope this helps
Attached is an image of the tractor seat and the metal plate
Sep 21, 2009 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Garden Logo
35 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dean Gruber
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
