Question about Sharp Multi-System Mini Component System Shelf System
  • 82 Answers
Check for an open fuse in the power supply.
Posted on Mar 27, 2008
Sharp XLMP 130 power button Blinking Red Light - Nothing Works
??? ?????? ??? ??? ?????? ?? ?? ??? ???? ?????? ?? STK 412-490 ?? ???? ???? ???? ????? ?? ?? ???? ?? ??? ??????????? ? STK ?????? ?????? ??? ??? ??? ?? ????? ??? ??????? ???? ???? STK ????? ???? ??? ??? ??? ?? ???? ?????? ??? ???? ??? ?
Jun 08, 2016 | Sharp XL-MP130 170-Watt 5-Disc CD Micro...
My Teac AG-V3020 makes clicking relay sound when attempting to power up.
recheck your connections it appears that something is cross if so recorrect the connections on your system
Nov 29, 2014 | Teac Audio Players & Recorders
Sharp model lc-20sh1u won't turn on, just makes a clicking sound and indicator light flashes red.
The clicking sound may be a power relay coming on and then off--problem indicates a trouble in the main power supply.
Nov 02, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
My sharp XLMP 130 all of a sudden started blinking red four times and then one long one - nothing works??
The problem is with the "power on" relay (RL841) located on the power supply board. Unplug the unit and take off the side panel and top cover. Remove the screws to remove the CD changer. There is a small black rectangular relay just below where the AC cord is soldered onto the PC board. Carefully remove (actually break it off carefully and gently & throw away) the plastic top housing of the relay. Plug in the unit and with a pencil or stick, manually actuate the coil armature while pressing the power on button on the front of the unit. I can almost assure you your unit will return to normal operation. Put it all back together and you're done. The blinking red 4 times followed by a long pulse indicates a power failure. The start up capacitor had drained and couldn't provide enough voltage to pull the relay coil in all the way.
Aug 04, 2010 | Sharp XL-MP130 CD Shelf System
Power won't shut off. Hello message and scramled lights comes on as soon as power off is pressed on Sharp XL-DK225
The stereo is in Demo mode. Press the "x-bass/Demo" button on the bottom of remote to turn off Demo.
Apr 24, 2010 | Sharp XL-DK225 Shelf System
No power to the fuel pump fuse 07 sportster 1200
Power to the fuel pump comes from the system relay via the fuel pump fuse. The power to the relay contact is from the ignition switch via the ECM fuse. The relay is activated with power form the ECM itself and is also controlled by the "stop/run" switch on the right handlebar control, so make sure it is switched to "run".
Apr 22, 2009 | 2006 Harley Davidson XL 1200 C Sportster...
Will not play , loud clicking noise. No lights nothing.
Ther clicking is probably coming from a relay and it is cycling because either the power supply itself or possibly an audio output power module has failed, the latter will overload the power supply so it tries to protect itself by interrupting either the AC or a DC voltage supplied by it.
This problem will likely require the hands-on of technical help.
Jan 01, 2009 | Sharp XL-HP515 CD Shelf System
Sharp Multi-System Mini Component System Shelf System Logo
159 people viewed this question
Top Sharp Audio Players & Recorders Experts
Are you a Sharp Audio Player and Recorder Expert? Answer questions, earn points and help others
