Question about Cub Cadet Garden
Cub cadet 2166 how to replace fuel line
Mower stall after 20 minutes when going uphill
4 Suggested Answers
panilling9
  • 284 Answers
SOURCE: engine stalls when electric PTO clutch is engaged
check your spacers to be sure you havent locked the clutch assembly directly to the motor shaft
you should be able to turn it fairly free less some clutch drag
Posted on May 26, 2009
  • 146 Answers
SOURCE: Cub Cadet 2166 series. Mower will not engage.
Unfortunately, the circuit is a little complicated - it involves the "PTO switch" (the switch you pull on to engage the mower), a "reverse switch" that senses if you've put the mower in reverse, and a relay operated by the reverse switch. The reverse switch is there to disengage the blades if you try to reverse while mowing. A failure in any of those items, or the connectors and wiring between them, will prevent the blades from engaging. Unless you want to "shotgun it" and replace parts one-by-one on a guess (which many repairmen to do save time, but at your expense) you need to use an ohmmeter or test light to trace and isolate where the failure is.
Posted on Jul 10, 2010
  • 112 Answers
SOURCE: Cub Cadet XT1 Kohler Engine Stall
Most likely your cap is not venting properly, replace the cap.
Posted on Sep 03, 2016
Testimonial: "I have tried that. Any other solutions?"
Mower quits running when going at a incline or uphill.
Check the gas level.
ride on stalls on incline - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jun 16, 2009 - When its at a certain angle the engine will stall -or- run terribly ... a little water in ..... I am still perplexed by the uphill/slope mower going down. Craftsman Lawn Tractor Stalls Going Downhill
Apr 4, 2010
Old Wheel Horse Problems
May 21, 2008
Hydrostatic Drive Problems??
May 30, 2006
Problem with garden tractor fuel filter
Jul 2, 2005
More results from forums2.gardenweb.com
Sep 25, 2015 | Garden
When I am cutting the grass, when I try to go uphill the machine stalls . I am able to start it up again but a few minutes later the same thing happens.
Check the oil level...some engines have a low oil shutdown float inside the crankcase ..going up hill for an extended period of time allows the oil to flow to the side of the crankcase activating the float and tricking it to think the oil is dangerously low and shut it down...if it does it should have a small wire on the side of the crankcase..try operating on hill for shorter times..and make sure your crankcase is full...good luck..
Aug 01, 2015 | Simplicity 42 Toro Timecutter 20hp Kohler...
Changed blade belt on husqvarna cth194 had difficulty restarting engine but got it going. When blades engaged going uphill lawnmower starts to struggle and threatens to cut out. this is a two month old...
I do not think this is a belt issue, i had some problems like this, it turned out to be a fuel issue, with the fuel tank completley full it was ok, as the fuel level became lower the mower stalled, the problem was the fuel tank did not have enough fall for gravity to allow the fuel into the carb, we ended up fitting an electric fuel pump.
Aug 10, 2013 | Husqvarna Garden
Troy bilt RZT 50
Is this a twin cylinder motor if it is it sounds like a bad spark plug
Oct 15, 2017 | Garden
Mower has difficult time moving forward
Is the mower blades engaged if so check spindels if not check the transmisson but check all pulleys first
Sep 23, 2017 | Craftsman 20 Hp 42" Deck Lawn Tractor
Toro Proline 52" stalls out after warming up
Do you know if that unit has a fuel pump or not? If not, then engine vacuum is what draws the fuel in ... but only IF the hoses involved DON'T have any cracks or splits, and they fit TIGHT on the ports to which they connect! Try using an eye dropper and squirt a little gas in the air intake under the air cleaner. Does it fire then?
Apr 19, 2017 | Garden
Lawn-Boy 20" mower stalls when hot and blade clutch engaged
probably the valves have unseated the hotter it run the worser it get warranty defect take to dealer tell what it doing tell him you think its un seated valves and cover under warranty
May 20, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Runs but stalls going uphill. takes forever to
Have a compression check done on the engine
May 11, 2010 | 2002 Pontiac Sunfire
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My poulan pro 6.75 self-propel mower stalls frequently
Replace the coil. Remove the top cover so that you can see the flywheel. There will be a horseshoe shaped peice with the plug wire attatched to it along with a small whir plugged onto it. Remove the two screws holding it on and unplug small wire and disconnect plug wire. When you put the new one on place a business card between coil and flywheel, this will give you the proper spacing, reconnect small wire and plug wire, reassemble top covers and you are good to go.
Aug 14, 2009 | Garden
Garden Logo
200 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
