Question about Sharp Office Equipment & Supplies
Sir I have sharp m237 print paper back side line
SOURCE: Black line prints on back of paper
I have the same problem and I have not found any fix yet.
Posted on May 15, 2008
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
Bubbabear64
  • 2794 Answers
SOURCE: IP Address on a Sharp AR-M237
The easy way to do it is to set the copier up for AUTO DHCP.  That way the copier will connect to the router and assign a free IP address to the copier.
Then go into internet explorer and type in the ip address of the copier.  If you can get a control panel screen of the copier to appear.  It worked.
Once you get the IP address, take it off of AUTO DHCP and type in the IP address that the router assigned to the copier.
Posted on Oct 16, 2008
Sharp Tech
  • 63 Answers
SOURCE: Sharp AR-M237 EXPANSION MEMORY 8MB: AR-MM9 installation procedure
You are needing the installation manual for this. Please contact me so I can e-mail you the pages that you need. administrator@aokoffice.com
Posted on Oct 15, 2009
  • 34 Answers
SOURCE: Copier Sharp AR-M237 a Misfeed Occurred message
First try a different tray to see if it works, if it does than the paper tray you are using may have dirty feed tires or look for something obstructing it.
Posted on Mar 24, 2010
Testimonial: "Thank you so much for the help , I have tried the Bypass Tray but still getting the jam code."
Sharp AR-M237 driver
You can download any driver you need from the link below.
Also, there are instructions for installation linked on the page.
Sharp Print Driver Download 64bit and 32bit Free Printer Driver Download
Jun 29, 2014 | Sharp AR-M237 Digital Copier
Cover door spring replacement
It helps to have a small tool called a spring hook. Other than that it will function if you tape the cover closed.
blog.equipmybiz.com
May 10, 2013 | Sharp AR-M237 Copier
Sharp AR-M237 a misfeed has occurred, top feeder. there is no paper have did as the information states and still will not clear.
Is the jam indicated inside the copier or on the document feeder that scans the paper across the glass ?
Mar 19, 2011 | Sharp AR-M237 Copier
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
For Sharp AR-M237 Copier/Printer. Tray 1 is showing up as paper size A4. How do we change it to 81/2 x 11?
1. push "custom settings" button
2.select the "tray settings" button on the screen itself
3.select the tray you want to change the paper setting
4.Select the size and type of paper that is loaded in the tray.
The currently selected paper type will be highlighted.
• To change the paper type selection, touch the appropriate type
key.
• To change the paper size selection, touch the appropriate size
key.
• To change the displayed size selections to AB sizes, touch [AB
? INCH].
Message will appear asking you to check the paper in the tray.
hope this helps!
Ryan
Oct 27, 2010 | Sharp AR-M237 Digital Copier
I have an AR-m237 that tray 1 will not pull paper, tray 2 works fine
is tray 1 recognized if not the little switch on the back of the machine behind tray one in blown, other wise you have to see if the rollers turn
Jul 08, 2010 | Sharp AR-M237 Copier
Mar 24, 2010 | Kyocera CopyStar CS-3060 Black and White...
Sharp AR-M237
please clean the sensor and feed the paper
Mar 17, 2010 | Kyocera CopyStar CS-3060 Black and White...
Pages come out black
It could be toner build up on the fuser rollers. If the jam was pulled from the fuser section.
Where was the jam at?
Nov 20, 2008 | Sharp AR-M237 Digital Copier
Faxing
You need Option, AR-FX7 (FAX) installed, real easy to figure out, look at the side, if you see a telephone line, with line and telephone connections (not the Network connection) then you have a fax.
Next your arm237 will also need to be able to print from the nextwork.. if this is all together..
you will need a driver called, PC to Fax for the AR-M237.
which you can find at www.sharpusa.com
Then you will have to set up the computer in the printer folder to PC to Fax.
Sep 29, 2008 | Sharp AR-M237 Copier
23 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
