Question about Music
I have a George stuck piano Style MU 63680 - Music
    New Friend:
    Problem Solver:
  • 17 Answers
Well its made in Samick Korea in July 2011.
You can find it all here..
http://epiphonewiki.com/index.php/Epiphone_Serial_Number_Decoding
Posted on Apr 21, 2017
We bought this upright piano for our daughter to learn on but I can't seem to find any info on it. Serial number 23930. Any info would be fabulous. Thank you.
Remove the front of the piano. Remove the middle C key complete from it mounting pin. You may find the production date and its full service history written in pencil on the side of that key. A piano tuner told me this after I told him that I had removed all the keys to clean them and I was surprised to see the whole history. It said it was standard practice.
Here is some other information.
Concord Mission Style Upright Piano ' The Antique Piano ...
antiquepianoshop.com/product/192/concord-mission-style-upright-piano/ The Concord Piano Company was controlled and manufactured by the famous George P. Bent Piano Company of Chicago, and they built pianos for several ...
Concord ' The Antique Piano Shop
antiquepianoshop.com/online-museum/concord/ (SEE ALSO: CROWN, GEORGE P. BENT) The Concord Piano Company was ... and manufactured by the famous George P. Bent Piano Company of Chicago.
Upright Piano Value ' key-notes
www.key-notes.com/upright-piano-value.html Jun 16, 2014 - Question: I have a Concord upright cabinet grand piano, serial ... Albert's reply: Piano values are based on information such as manufacturer, ...
Piano Manufacturers in Illinois between 1842 and 1908
https://sweeneypiano.com/.../manufacturers/il_piano_manufacturers.cfm The names of Piano Manufacturers and the date year the company was established in the state of Illinois between 1789 and 1911. ... Company, Chicago. Foley & Williams Piano Manfacturing Company, Chicago ... Concord Company, Chicago.
Jan 19, 2016 | Music
How do I fix a stuck piano key on a upright home piano
You'll likely need to try removing the keys, so you can see if something is stuck underneath it. That would be my first move.
In order to do this, follow these steps:
The front panel and the keyboard fall are designed to be easily removed for tuning purposes anyway.
To check it out....The front panel likely has a little clip either side near the top on the inside. Just undo these clips and lift the panel out. The keyboard fall should then be easy to lift out too.
There may be a long wooden rail which you need to take out also. Once inside, the keys themselves can be carefully lifted off the central spikes on which they sit.
Remember how you did this so you can get them back in again.
Since your piano is so old and worn, Often times, the wooden rail in front of the keys (just above your knees when you are playing) bows inwards a little due to age and temperature/humidity fluctuations. This then causes the little white front bit of the keys to jam against the wood and you have to physically lift the keys back up to return them.
If this is the problem you will need to take out the keys and shave some wood off the inside of this rail to allow the keys to move up and down freely again.
Or sometimes you may find you have a small object caught under a key or two. Much simpler to remove and free up your keys, if this is your problem..
Hopefully, this is all you will find wrong with your piano.
If all else fails...
I wouldn't attempt to tune your piano by yourself. I would seek out an experienced piano tuner for that.
But it is worth attempting to repair it first before you go that far.
Good luck !!
Feb 26, 2015 | Music
How so I fix a stuck piano key
It would depend on why it's sticking. First thing to check is the key bushing felt, then see if the key has swollen and is rubbing the ajascent key. Past that, you'll need a repairman.
Curious on the value on a Baldwin upright serial #1484454 style 2056A
I hope this helps. I can tell you that pianos age like people. How old is your Baldwin? Baldwins also are not made anymore, but I don't think that makes them particularly prized. Alot depends on its condition. I do not know to what the serial # and style # refer. If by upright you mean not a spinet or console, this type is usually found relatively inexpensively (<$1,000), especially if it is not a player piano. I would suggest that you take several good pictures of it to a local piano store for an estimate.
Jan 28, 2015 | Music
How to I get access to the inside of a Roland HP1700L digital piano?
George, I would recommend getting a tech to do this one- a Roland is an expensive instrument, and I would seriously rather someone else was to blame if something happened! :)
Nov 20, 2014 | Roland Music
How to fix a corrupted display?
If everything else works fine then it likely just needs the display replaced.
Apr 24, 2014 | Yamaha FC4 Piano Style Sustain Pedal
I have 2 digital pianos and an xk3 Hammond but i find the xk3 is out of tune to the pianos. is this possible can you help me please Gordon
Ooften there is a setting for the pitch. Set it to A at 440 Hz which is usual standard. HOWEVER make sure it is really a pitch difference as the ear can be fooled by the "hammond" type sounds.
Dec 29, 2010 | Hammond XK-3 Lower Manual - Pro Style...
The keys in the middle range of my Yamaha electronic piano P-200 seem to be stuck and are very difficult to play - takes a lot of strength to get any sound. Could humidity be a problem? Could piano...
Although the keys have a weighted feel, this is not because of a system involving connection t hammers as in an acoustic piano. This is done mechanically, however, which would indicate a need for cleaning. If you have an authorized Yamaha service center in you area they would need to do the cleaning.
Oct 30, 2010 | Yamaha Music
Music Logo
Top Music Experts
Michial Gueffroy
Are you a Music Expert? Answer questions, earn points and help others
