Question about Konica Minolta Office Equipment & Supplies
I have Konica Minolta m2550 misdeeds Jam m1m2
  • 3 Answers
SOURCE: konica minolta 2430 DL paper jam
Place a few papers in the tray.
Open up the top, pull out the main (green handle) thingy.
In the very bottom you will see a bar with a single large round rubber wheel in the middle, and white gears on both ends of the bar.
Manually turn the right side gear toward you.
As you do this, you will see the paper lift up and as the rubber wheel turns you will see that it has a notch on the bottom side.
Turn the gear, and watch the rubber wheel until the notch on the rubber wheel is facing up and away from you (and the paper is fully engaged).
Then put the green-handle thingy back in, close the printer, and it should work.
Apparently this resets something.  I have done it a number of times - usually after a paper jam.
Posted on Oct 30, 2007
  • 145 Answers
SOURCE: konica minolta is getting error c2557, before this it was saying
c-2557 code has to do with you black toner bottle.
how handy are you?
Posted on Mar 18, 2009
  • 48 Answers
SOURCE: KONICA MINOLTA magicolor 2490MF paper jam. It
I believe the duplex door is in the back of the printer.
Posted on Jun 01, 2009
  • 210 Answers
SOURCE: konica minolta pagepro 1400w paper jam
have you tear the paper when removing? there is a small paper left still inside the paper path. open the back side and the top part and check for small paper. I hope that will solve your problem and if think the problem still there the problem is one of the paper sensor actuator is broken or out of place.
Posted on Jul 09, 2009
  • 132 Answers
SOURCE: Konica Minolta bizhub 180 printer
Open all covers and clean again. Look for small piece of paper somewhere on paper path.
Posted on Nov 16, 2010
Consistent paper jam on konica minolta bizhub c451e
Please look the jam code, then only b easy to provide solution.
To check Jam code follow these steps.
Here you will find Jam code E.g J2202 like that.
Post again with jam code, I will give u solution
Dec 23, 2016 | Konica Minolta bizhub Office Equipment &...
Adf konica minolta bizhub 350. theres adf working good but no printout. a few minute machine says jam paper at adf. actualy original it was throw out.. help me please...
Konica Questions answered here ' FixYourOwnPrinter
Aug 22, 2008 - Am working on a Magicolor 2300 DL that sometimes fails to lift the paper tray ... good afternoon I have a konica minolta bizhub c550 when I open the ... I'm no printer tech, but in most other lasers (HPs, etc) the paper tray lifts, .... It seemsthere is a "waste toner sensor" which only lets the printer print out a few ...
Konica Minolta paper jam adf scanner Questions & Answers ... > Forum > Tags > paper jam adf scanner
Question about bizhub 350 All-In-One Laser Printer ... Konica Minolta bizhub 250 jammed but no paper ... Good luck. ... ...paper is there if the switch is working the adfboard is fualty or the cable between the machine and adf broke from all the ...
Konica Minolta bizhub document feeder not working ...
Jan 23, 2016 | Konica Minolta Office Equipment & Supplies
"Dirty" could be one of 3 things... Transfer belt, Imaging unit and fuser unit. Make 5 copies in jam the machine by opening a cover. remove pages and see where the "dirt" originates from.
Jan 08, 2014 | Konica Minolta bizhub Office Equipment &...
Konica minolta 7416MFG saying paper jam but i removed sll the papers without tearing
the door or cover is not properly closed or it may still have piece of paper inside it.
May 14, 2010 | Konica Minolta magicolor 2430 DL Laser...
Feb 18, 2009 | Konica Minolta magicolor 2490MF Laser...
Konica minolta bizhub 162 photocopier paper jam problem
tenho um problema de paper ja open 1st side cover,m o que fazer
Sep 02, 2008 | Office Equipment & Supplies
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
