Please help me identify the module and I shall work from there. I am experienced enough for DIY as long as it doesn't hang on micro components (integrated electronics)
  • EmilEckhart Jul 24, 2009
    The model is Polaroid FLM-2601 and the question is to identify the remote module in the TV set. There was no mention of projection TV and you shall remove it from my profile
    Very good, thank you. If that doesn't work, lets see...
  • 10,594 Answers
I need to know model and brand of TV as well as problem in TV
Thanks.
Posted on Jul 24, 2009
  • Shahid Electronics
    Shahid Electronics Jul 24, 2009
    Click HERE to see IR Sensor module of FLM-2601 and its located at lower front of TV.
    IR sensor gets signal of remote and send it to system control for processing. System control section is located on main board of TV.
    Thanks.
The transmission wont shift and reverse wont work. It also bucks and tries to die.
Check Engine Light? When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, you may begin diagnosis.
Sep 07, 2011 | Hyundai Accent Cars & Trucks
My microwave doesnt work
If you hear an unusual buzzing noise, the magnetron (the component that actually generates the microwaves) or other electronic module may be broken. This is not easily fixed; contact a service technician.
Thanks,
micro
pls. rate..
Mar 08, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Check Engine Light on
When a 'check engine light' (MIL=Malfunction Indicator Lamp) is turned on, there is a DTC (Diagnostic Trouble Code) set/stored in the ECM/PCM (Engine Control Module/Powertrain Control Module). This code identifies which engine management system component/function experienced a malfunction. Once you pull/read this code, we can possibly help. But until then, it's anybody's guess.
Aug 29, 2011 | 2007 Hyundai Entourage Limited Minivan
My car doesn't have any power, it starts and drives but will not go over 25mph any suggestions of what it could be? I was thinking maybe a vacuum leak or the mass air flow sensor ??? IDK please help....
Aug 24, 2011 | 2002 Hyundai Accent
MARANTZ PM68 AMPLIFIER UNIT WILL NOT SWITCH OUT OF SAFE MODE. OUTPUT STAGE TESTED AND WORKING OK.
Clean the switches with an alcohol and needs also re soldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Again, since the unit still operates (sometimes) then it is highly probable that there are no defective components. As you have surmised, it is possibly a loose connection, solder joints are "connections" except that molten soldering lead is used to attach/connect the component to the board, "loose connection" in this sense is equal to "cold solder".
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click to rate.It is the only way i get paid for my work...
Hope this may help;
Regards,
VOTIT
Jul 29, 2008 | Marantz Audio Players & Recorders
Sanyo dta 150 audio system does not switch on. have checked mains fuse ok.
Need to clean and re soldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
Hope this may help;
Regards,
VOTIT
Jul 29, 2008 | Audio Players & Recorders
Wharpdale NE-3272 CD/DAB Micro System - This is brand new and switches its self off. Hiw can I get it to continue to play all day?
Need to clean and resoldering works.Cold solder issues - each component is soldered into small holes on the printed circuit board which in turn connects said component to the other components. Due to time, heat, use, some solder joints would be cracked or loose. It is possible that the cold solder is still minimally connected (hanging by a thread). When the receiver turns on heat would be generated which would be sufficient to further loosen up the solder joint to the point it no longer provides electrical contact. Jarring the unit creates movement inside enough to re establish the contact, sometime good enough sometimes not enough.
hope this may help;
Regards,
VOTIT
Jul 27, 2008 | Audio Players & Recorders
The cd player in my 2005 subaru outback will not play or eject all that comes up on the scren is error99
Again on the assumption of no defective parts, then seeking a more experienced buddy for the soldering might be to your advantage. This is of course in addition to the possible electrical hazards when repairing....If i have helped,please click fixya.It is the only way i get paid for my work...
Good luck:
Jul 22, 2008 | Audio Players & Recorders
My sons wharfedale wpc 286 portable cd/radio experienced a complete power failure. Checked the fuse in the plug and it was ok. Is their an internal fuse or could it be loose connection internally?
Good luck:
Jul 17, 2008 | Audio Players & Recorders
Display doesn't work some times comes on but not all the time
Good luck:
Jul 17, 2008 | Kenwood Audio Players & Recorders
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
