Question about Bosch Dishwashers
Our Bosch dishwasher had an odor. What can we do to help?
SOURCE: Bosch dishwasher will not drain - causing moldy odor
Have Bosch water stand in bottom drain. #SHU3302vc/U12
Posted on Apr 01, 2008
odiebugs
  • 949 Answers
SOURCE: bad odor when open door after cycle
This is just a suggestion, run a cycle and after a few mins of it washing, open the door and add a cup of bleach and let the washer run. See if this helps.
Posted on Apr 09, 2009
  • 457 Answers
SOURCE: I have a BOSCH model 53L06UC dishwasher and was
every bosch dishwasher unit is different. you can get odor from different source. #1 solution to fight odor is the proper maintenance. every month run the cycle with just a cup of vinegar on a hot wash. i am a old bosch tech and alot of people dont add the jet dry properly. this is for drying,spots and-cleaning you must add the jet dry or rinse agent (same thing)into the compartment. close compartment,then lower and raise door 3 times,then fill again repeat until you cant add anymore then it is filled.if this help please send me a 4 thumbs up post. thanks
Posted on Mar 01, 2010
SOURCE: Bosch Dishwasher odor
I have a new Bosch dishwasher which smells up the whole kitchen when the door is opened (between washings). Someone should ban their sales.
Posted on Apr 02, 2010
  • 97 Answers
SOURCE: Bosch dishwasher model she6af02uc/03 odor
try running some bleach in the wash cycle
Posted on Aug 28, 2012
I had a Bosch dishwasher installed 6mos ago. Awful odor coming from it. Any ideas re: odor source?
this is decade food. you need to put a cleaner in the tray like calgol in the system this will clean the system use it regularly, there are other branded of dishwasher cleaners make sure its on the hottest wash first time don't put items in the washer and when done leave to dry. do this every month and it will not smell. will keep the washer clean and fresh.
Jun 29, 2017 | Bosch Dishwashers
Aug 28, 2012 | Bosch Dishwashers
Standing water just below the filter has unpleasant odor.
Here is a tip that I wrote that will help you with your dishwasher not drainingproblem...
Dishwasher Problems - Water will not drain out
heatman101
Sep 17, 2010 | Bosch Evolution 500 SHE45M05UC Stainless...
Terrible odor
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
heatman101
Sep 08, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Continuous Odor in the machine
I would check your drain line. If its connected to the disposal make sure its elevated you may be getting back flow from the disposal into the dishwasher. Hope this helps _MJ_
May 20, 2010 | Bosch 24 in. SHU43 Built-in Dishwasher
Feb 28, 2010 | Dishwashers
Bad odor when open door after cycle
Apr 09, 2009 | Bosch 24 in. SHU66C05 Stainless Steel...
Odor 2 days after cycle
After you have unloaded the the dishwasher, prop the door open with the upper rack out.
Let the inside air out. After a short time the remaining moisture will evaporate. Stainless steel dishwashers are prone to an odor if you do not use the machine daily. There are after market products that are citrus based that will help. Check with Bosch.
Jun 14, 2008 | Bosch Evolution 500 SHE45M06UC Built-in...
Hello Mimhoff it depends on how much water is down there. The sump area always has a little water in it to prevent the circulation pump seals from sticking. Usually around 1 to 2 inches. If there is more than that, check the slots at the bottom of the sump on the left side for being clogged and check the end of the drain hose to make sure it is clear. If you are getting a moldy/odor from the dishwasher, try running Dishwasher Magic or Tang thru the dishwasher. This will remove any build up of food or detergent from the dishwasher. If you are running the dishwasher every few days and just scraping your dishes, then either leave the door ajar or run the rinse & hold cycle to help keep the odor down. Bosch doesn't reccommend running bleach thru the dishwasher as this can cause damage to the rubber seals. However 2 tablespoons of bleach once a year won't hurt.
Feb 01, 2008 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Dishwashers Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
