Pairing or powering up my fire stick. It is plugged in batteries are in correctly
Tip
Amazon fire stick reset
make sure that your wifi is a good signal,if you are using a lower tier internet service then it wont work,call your internet provider and verify that your internet is sufficient,also use 5ghz wifi,not 2.8ghz.
if this doesnt work for connecting then,
reset this way,
straight from amazon,reset firestick,
Please unplug the Fire TV stick from power source and then plug it again after 5 seconds.
Once the Fire TV stick is back on, please take batteries out of the remote and re-insert
also,xfinity remote controls work with firestik tv in place of the original remote,program it for a vizio tv and forget the original remote!
on Apr 03, 2015 | Amazon Fire TV Stick
I need the fire tv stick default password to connect to my computer and phone wirelessly
The requested password is for your router not the Fire Stick itself. It should be on a label on the Router or on the instructions wen you received it. Instructions for pairing are on Page 33. 'Can't connect to internet' is on Page 35.
[PDF]Fire TV Stick User Guide - Amazon S3 https://s3-us-west-2.amazonaws.com/.../Fire+TV+Stick+User+Guide.pdf
  1. Cached
  2. Similar
Differences between Amazon Fire TV and Fire TV Stick on page 17 ..... site)Amazon Instant Video Settings (https://www.amazon.com/video/settings) to reset your Parental Controls PIN. ..... This password is not your Amazon account password. fire tv stick default password Google Search
Jan 04, 2017 | Computers & Internet
Connecting fire stick to tv. i am a prime member with amazon
Setting up Amazon Fire TV Stick hardware
  1. Plug the micro-USB power cable into your Fire TV Stick and the other end into the plug adapter and into the wall.
  2. Plug your Fire TV Stick into an HDMI port on your TV (a cable is included to extend the HDMI reach if you've got a particularly tricky TV).
  3. Next, turn on your TV and switch the input to the right HDMI port
  4. You won't be able to interact with Fire TV Stick until you pair a remote. Thankfully, by just inserting the batteries into the included remote, it should pair automatically. If this fails, you can download and use the Amazon Fire TV remote app on your phone.
  5. Now it's time to set up your wireless network. Fire TV Stick should automatically detect your Wi-Fi. Select your network and enter any passwords.
  6. Your Fire TV Stick will then check for updates and download anything it doesn't have before letting you continue. Depending on how new your Stick is and the strength of your connection, this could take some time.
  7. If you bought your Fire TV Stick from Amazon, it will have arrived already logged in and set up with your account, which is handy. If not, don't worry, it's very easy to set up a new account on Fire TV, requiring nothing more than your Amazon login details.
  8. Once done, you'll be treated to an unskippable introduction to your Fire TV Stick, taking you through the basics of what the system can do and how to make the most of its features.
  9. From here, you can set up parental control settings before you start using your Fire TV Stick as intended.
Now you've set your Fire TV Stick up, here's how to install Kodi on it.
How to set up your Amazon Fire TV Stick
Dec 23, 2016 | Televison & Video
Hi, I purchased a firetvstick but it does not respond after plugged into my smart tv. help
Check list:
1) Do you have your fire stick powered?
Connected via usb cable to a power adapter
plugged into a power strip that has the power on,
power switch is off....so on.
2) Do you have your TV input set to the correct HDMI input?
Depending on the model you may have 2 to 4 HDMI inputs.
This is the most common error.
Please make sure the input is set to the correct input
of where your fire stick is plugged in to.
3) If you have power and the input in your TV is set.
And you still have nothing.
Then your firestick might be defective.
4) If it is working, read the instructions carefully.
connect your fire stick to your wi fi and register your fire stick.
Then enjoy!!
Aug 30, 2016 | Amazon Fire TV Stick
How can I get my new Amazon fire tv stick to install? Every thing is plugged in correctly and powered up but the screen says it "Can't contact Amazon.com so try a new router or wireless network"
Check this first:
  • Connect your Amazon Fire TV device to one of these network or router types:
    • Open, WEP, WPA-PSK, and WPA2-PSK encrypted networks
    • B, G, and N routers on 2.4Ghz
    • A and N routers on 5Ghz
    • Hidden networks
  • Enable wireless connectivity on your Amazon Fire TV device. From the Home screen, select Settings > System > Wi-Fi.
  • Make sure you know your network password (if required). If you see a lock icon, a network password is required. This password is not your Amazon account password.
  • Make sure your Internet connection is not down. Restart your router and modem to solve most Wi-Fi network issues.
  • Do not place your wireless router or Amazon Fire TV device in a cabinet, as it impacts your Wi-Fi signal strength.
Also, try this for Fire TV Stick:
  • Use the included HDMI extender to optimize the location of your Fire TV Stick. The HDMI extender can improve your wireless connectivity by positioning your Fire TV Stick further from the TV.
  • Plug the power cord into the included power adapter and then into a wall outlet to ensure the device receives enough power for optimal performance.
Still having trouble?
  • Restart your Amazon Fire TV device. Disconnect the power cord from your Amazon Fire TV device for three seconds, and then plug the power cord back in.
Tip: You can also restart your Amazon Fire TV device with your remote. Press and hold the Select button and the Play button at the same time until the Amazon Fire TV device restarts (about five seconds). Or go to Settings > System > Restart.
May 06, 2015 | Computers & Internet
Went to settings and accidently turned off blue tooth wi fi now my fire stic remote will not respond air won'' scroll up or down and I can't get back to settings
When I went to settings I accidently turned off blue tooth wi fi now remote will not allow me to do anything It will not scroll off home screen
Will not connect to tv do you have to disconnect cable to get menu screen on fire stick
plug stick into hdmi on tv,tune tv to hdmi 1 or 2,plug power cord into stick and outlet,push center button for 5 seconds
Mar 08, 2015 | Amazon Fire TV Stick
Starter problems
petrol or diesel ???please use queens english??starter spark plugs ??now do you mean pre heaters or glow plugs,hot fingers,fire sticks the correct name is pre heater plugs if its what i think you mean.So come on learn the queens english so we can all understand from the american colonies to new zealand
Jan 10, 2009 | 1997 Chevrolet Cavalier
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
Electro Med Services...
