Question about Cuisinart Blenders
How to repair BFP-CH 10 Cuisinart blender that starts and stops on its own in less than a minute
4 Suggested Answers
  • 94 Answers
SOURCE: I have the red Cuisinart
if you over loaded these machines there is a thermal fuse one time shot will blow . it is not resettable , you can buy them @ Radio Shack 8 amp should do fine . it might be stamped with the rating value too. need a test meter to check component very small .187 diameter & .750 length apx
Posted on Mar 14, 2010
SOURCE: Cuisinart BFP-703CH Chrome Blender does not start
I had the exact same problem with my Cuisinart bfp-703ch blender. When I plug it in, the lights come on but the motor wouldn't run. After reading some posts I almost decided to throw it away. But my brain started to itch and I gave it a shot anyway. I eventually found the problem to be with the Thermal fuse. If you overload/overheat the blender, this fuse is going to blow off.
To replace it, I opened the bottom panel and followed the wires that come from the circuit. Once of those wires eventually will lead to the thermal fuse. It may help you if you unscrew the circuit board. Then I detached the fuse with pliers, got a replacement thermal fuse from Radioshack and connected it back on. I also had to solder it to make sure the connection is more robust. And Voila!!! my motor started working again.
Posted on Dec 23, 2011
SOURCE: my cord to my bfp-703 cuisinart blender melted can it be replaced ?
Unfortunately it cannot. Cuisinart does not sell parts direct to consumers. However, their products carry 3 year warranties. Contact Cuisinart directly and they will be able to assist you with getting the unit fixed.
Posted on Apr 09, 2012
Why is it leaking all the time?
gasket is the most likely candidate. The gasket is either cracked, damaged or gone. If it is missing then it most likely fell off when cleaning. Unscrew the base and see if it is in there. It is also possible it is not seated properly.
Mar 07, 2016 | Cuisinart BFP-10 7-Speed Blender
My cord to my bfp-703 cuisinart blender melted can it be replaced ?
Apr 08, 2012 | Cuisinart BFP-703 Blender
My Cuisinart bllender stopped working. THe lights still work but the blender just wont start??
Hello, andre
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about blenders andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances5.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Aug 22, 2011 | Cuisinart BFP-703CH Chrome Blender
Manual is destroyed. Need new copy for Cuisinart PowerBlend Blender/Food Processor
The Instruction Booklet for your Cuisinart BFP-703 SmartPower Work Top Blender can be found here:
http://www.cuisinart.ca/pdf/ibs/en/BFP-703CHC_en.pdf
Thank you for using FixYa!
Jul 30, 2011 | Cuisinart BFP-703 SmartPower Work Top...
Apr 15, 2009 | Cuisinart BFP-703CH Chrome Blender
Parts for Cuisinart CB-600 SA Blender
You have a Sam's Club variant of the model:
The blender parts are the same for that model as for the CBT-500 - food processor parts are the same as for the BFP-703
All available from www.cuisinart.com
-Tha Mp3 Doctor
Jan 26, 2009 | Cuisinart Blenders
Broken gear on BFP-703 base
The drive is replacable and available from Cuisinart, you will have to sign a waver to get the part. the drive is screwed onto the motor shaft with reverse threads. the plastic drive will have to be completely broken off of the unit to expose a brass"nut" which was internal to the drive. depending upon your model you may have to remove the lower half of the base unit to access the lower part of the motor shaft. there will be a slot in the end of the shaft for a large flat blade screwdriver. this is used to hold the shaft still while turning the drive "nut" with a vice grip pliar or similar. the new drive is just threaded onto the shaft and normal operation tightens it.
Feb 14, 2007 | Cuisinart BFP-703 Blender
Blenders Logo
108 people viewed this question
Top Cuisinart Blenders Experts
Hjalmer Lamminen
Hjalmer Lamminen
Oloyede Monsuru
eyecam
Are you a Cuisinart Blender Expert? Answer questions, earn points and help others
