Question about Sharp Office Equipment & Supplies
I have sharp m236 but copy paper line page prints
kehalim
  • 55 Answers
SOURCE: why do all pages print onto one page when i hit the print button in a multipage document
I guess you are using word. In that case the default driver you use and comes standard with windows is flawed. Download a new one from HP.
Posted on Oct 24, 2007
Cogz
  • 1326 Answers
SOURCE: toshiba 2060 marks on papaer
There is no such paper for copiers that I know of in 18 years. What you can do is try to run some blank pages throw the copier. This can tell 2 things if the line gets lighter in may be in the fixing ***'y and the upper fusing roller is shoot, needs to be replaced and or if it dose not clear up you may need a cleaning blade for the drum(OPC) and or the drum and blade as a set. It depends on how old the parts are? You may need to replace all 3 items and a general cleaning. Here is a idea for you are you running LTR or LTR-R you may be able to switch the paper arould to avoid the line all togather. Good Luck.... You may need a service call on the copier. With the age of the copier I might just go with the cheap fix first.
Posted on Mar 12, 2008
Cogz
  • 1326 Answers
SOURCE: Black Lines
Do the black lines only show up when useing the adf???? Or do they show up on both the adf and the copyboard glass??? If it is only when using the adf...... The fix is easy.... you have to clean the smaller piece of glass that is to the left of the copyboard glass with windex or rubbing alchola. If it is with both you may need a new drum and blade or a new ufr... Good Luck
Posted on May 21, 2008
  • 37 Answers
SOURCE: Black line down the paper on copy mode. Ok in print mode.
There is most likely something on your scan glass that is blocking the scanner. Clean of both pieces of glass that are there when you flip open the ADF, or top cover. Try to copy again. If it is still there then there is either something on the scanner piece that moves back and forth to scan or one of your scan LEDs is burnt out and the scanner will have to be replaced.
Posted on Dec 17, 2008
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
Black line on paper.when copy. sharp ar-m236
COULD BE A MARK ON YOUR CARRIAGE.I COULD CHECK THAT FIRST
Nov 19, 2013 | Office Equipment & Supplies
Yellow lines printing on paper
Check out my youtube video for cleaning the internals, it will probably help get rid of the lines on your Sharp copier.
How To Remove Lines from copies prints on Sharp copier
Oct 23, 2013 | Sharp Mx-4501n Color Laser - Printer /...
1 black line at the end of paper
if u take copy from adf scanner then clean the scanner glass. if the line is coming on print & copy both then check drum is there any line
Dec 19, 2012 | Sharp AR-5316 Advanced Digital Imager...
I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Apr 15, 2009 | Sharp AR-235 Copier
Sharp AL-1631 Copies has begun to print verticle lines on page.
if the drum already been scratched out,so there is no solution to repair it,u have to change the drum.before change the drum check the copier glass surface if any dry up material,wipe it with dry cloth.
Dec 09, 2008 | Sharp AR-5320 Black and White Copier
Print Black Page
Is the scanning lamp coming on ? No, replace lamp
is there a print in the background? Yes, check Seperation unit ( inside under the drum, usually three thin wires)
Nov 19, 2008 | Sharp AR-M450N Copier
UX-B700 fax/printer
Sounds like you may need to clean the optics. Open up the area where you insert the original to copy, there you will find a small long glass that needs to be cleaned, I would suspect there is white out on this causing you lines or it may just be dirty.
Hope this helps...
Lbcoaster
Jul 07, 2008 | Sharp UX B700 Plain Paper Inkjet Fax
Sharp fax printing problem
Curfman.....your scanner has gone bad
kireeti....open the document feeder and check for obstructions or a switch actuator stuck down.
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
26 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
