Question about Garden
Replacing cutter belt on ranger rover auto drive ride on mower mode 1866 is there any adjustment tensioner or should it fit in very easy
    Top Expert:
  • Garden Master
  • 46,784 Answers
There should be a spring loaded belt tensioner involved
Posted on Apr 21, 2017
How do I change the deck cutter belt?
Un do the tensioner and idler pulleys ( the back axle might be slotted where it bolts on to the frame for adjustment) fit new belt and refit pulley,s.
Apr 15, 2016 | Garden
How to change drive belt
  1. Step 1 - Loosen tension and remove belt. Locate the adjustment fastener and loosen it. ...
  2. Step 2 - Inspect drive and drive pulleys. Check the drive and pulley wheels. ...
  3. Step 3 - Select correct replacement belt. ...
  4. Step 4 - Install V-belt. ...
  5. Step 5 - Correctly tension new belt. ...
  6. Step 6 - Start the engine.
Mar 24, 2016 | Huskee Tractor Replacement Riding Lawn...
How do you replace the drive belt on a time cutter z5000 model no 74370
Release tensioner adjuster fit new belt and readjust,could have slide slots holding the rear axle also(adjustment.)
Jul 09, 2015 | Toro Garden
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Zt2560
Remove blade drive belt. turn each blade by hand. Sounds as if you have bearing problems. Each spindle has an upper and lower bearing of the same size. They are notorious for going out! You can get them at most any auto parts store. Also check the tensioner pulley bearing. They go out quite often. As for the jerking, make sure the two drive disengage rods are fully in. Check tension on drive belt and belt. These belts get worn quickly. Be sure to blow the trash and dirt from your mower after each use. Especially the Hydraulic motors and the mower deck. This will save you lots of trouble. If you wash the mower, be sure and run the blades and Hrdroes to get water dried from bearings and pulleys and belts.
Oct 04, 2014 | Swisher Zt2560 Zero Turn Radius 60" Riding...
Installing a belt
First thing is to draw a map of where the existing belt goes.. Up under the bonnet with a permanent marker is a good place. Release the adjuster/tensioner pulley/s and take the old belt off. . Fit the new belt ensuring that it sits properly in the pulley grooves and re-tension the pulleys
Jan 15, 2014 | 1995 Land Rover Range Rover
Clutch chatter - Replacing the drive belt helped a little. Is there a way to adjust the clutch?
there is no clutch as far as I know on ride on mowers, there is just a tensioner pulley that works off the brake/clutch, to adjust it you have to depress the brake/clutch to take the tension off the belt then adjust the belt tensioner to apply more pressure on the belt. Also check the tensioner pulley as I have found that they split in two and the belt becomes loose as a result.
Hope this helps
Oct 20, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
I have a MTD 0675 g Ride on mower, with a 18hp Briggs IC engine. I have recently re bearing'd the cutter deck and fitted a new belt. I cant work out how to adjust the belt-tighten it a little as it slips...
check to see if the belt is in the correct routing, most belt tensioners are able to be fitted with a factory belt in a couple of different routing methods, however only one is right to keep the belt from slipping, look for a belt routing diagram on the mower deck they are the best source fot this information.
Jan 07, 2011 | Garden
Rover racher auto drive no forward drive reverse
band is out in training time to rebuild training
Aug 29, 2009 | Garden
Replacing the belt on a Murray Riding Lawnmower.
The simplest way, is to take hold the belt, with the tension from the engine pully/clutch mechanism, then to follow the shape around the rest of the cutter mechanism. (You don't have to worry which direction the belt travels,)
Bearing in mind, the tensioner direction.
Then, you will see the correct route, very quickly:)
Hope you can manage, with that.
Jul 23, 2009 | Garden
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
