Question about Sharp Office Equipment & Supplies
I have Sharp ar m236 error l3 - Sharp Office Equipment & Supplies
007tech
  • 95 Answers
SOURCE: I have an error code of L3-00 on my Sharp AR 168D.
L3-00 indicates scan carriage motor trouble. The carriage with all the mirors on it is not moving at all (scanning) or is not moving at the required speed so it does not reach its "home" position. If restarting the copier does resolve the issue....
A few things to check... When you turn copier on does carriage move at all? if not then the motor could be bound up (not turning) - also make sure the cables pulling the carriage are properly wound. remove the main glass and make sure there are no obstructions in the way of the carriage (a loose cable maybe or dirt) can you move the cable by hand freely? if the motor locks up it could be really hard to move the carriage.
The carriage seems to be moving freely (by hand and when you turn the copier on) it could possibly be the "home position" sensor that is faulty and not reading the correct position of the carriage.
You can the copier in test mode to check either the motor or sensor. press the following keys one after the other # * C * then press start/enter , press 1 and start/enter again, sub code 1 will test the motor and sub code 2 will test the sensor.
So it could be a bad motor or sensor or the MCU board that drives the motor (or may just need a good cleaning).
Good Luck.
Posted on Mar 26, 2009
tehnik_bdg
  • 91 Answers
SOURCE: I need to obtain a meter reading for sharp ar-m236. How do I do that?
Simply press and hold the copy mode then you get the meter reading and toner percentage status
Posted on Apr 16, 2009
  • 990 Answers
SOURCE: sharp AR-M236 Fault U2-40
Hello sir; This error code require reset the procedure as follow;
press "#/p" " . " "clear" " . " then enter 16 press start enter 0 press start again, press "clear all" machine will back to normal.
Posted on Aug 04, 2009
  • 3741 Answers
SOURCE: sharp ar-m236 error code H4-21
-H4-21 means: Sub heater lamp abnormally low temperature detection. The setup temperature (about –25°C: Sim 43-1-1) is not reached within the specified time (about 32sec) from turning on the power ON SW. (When the temperature falls below 140°C in the standby mode.)
-Causes:
Sub heater thermistor defect
Sub heater lamp failure
Sub thermostat failure
Control PWB failure
-Check the sub heater lamp blinking with SIM 5-2-2.
When the lamp blinks normally: Check the thermistor and the harness. Check the MCU PWB thermistor input circuit.
When the lamp does not light: Check for disconnection of the heater lamp and thermostat. Check the interlock switch.Check the power PWB and the MCU PWB lamp control circuit.
Clear the display of self-diagnostics with SIM 14.
The H4 errors will not reset by themselves. You must enter service mode to reset this error even if the problem has been repaired. The reset process is outlined below (DO NOT USE ANY OTHER FUNCTIONS IN SERVICE MODE):
Press the following sequence: "#/P" "*" "C" "*"
Type in 1 4
Press start
hit 1 for yes
hit start
Unit should power off and the restart.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Dec 28, 2009
  • 35 Answers
SOURCE: sharp copier ar-m236 error h4-21
try to reset by programming...here u just do ..p * c * (p star c star ) u will go in simulation mode .then press 14 ,start .mechine will ask you yes or no ? u just press 1 for yes .and press start ...your mechine will work..if same problem prsist try to check fusing unit...dont forget to thanks to me
Posted on Feb 10, 2010
I have Sharp copier AR-M236 with error code:f2-04, how can i remove this error?
The error code usually refers to a faulty toner cartridge. If turning the machine off & on doesn't reset the machine then you may have to replace the toner cartridge.
Hope this helps.
Dave.
Oct 09, 2017 | Sharp Office Equipment & Supplies
Call for service error code u2-40 on sharp copier AR-M236
That means there is a bad CRUM chip or the developer unit isn't connecting properly.
Aug 20, 2011 | Sharp AR-235 Copier
That error is a bad CRUM. Replace developer unit use only Sharp supplies. The chip on the developer unit doesnt match with the machine.
Aug 22, 2010 | Sharp AR-M237 Copier
Please i need to reset my sharp ar-m236 password how do i do that
You can reset the nic card password by ressetting the nic card to factory defaults, custom setting, key operator, 00000 , print settings , network settings, reset the nic, default password is Sharp
Mar 15, 2010 | Sharp AR-M237 Copier
Sharp AR-M236 Fault U2-40
Aug 04, 2009 | Sharp AR-235 Copier
Apr 15, 2009 | Sharp AR-235 Copier
How can I inter to s.p program for sharp ar-m236
Basicly there is not a trick to the S.P. mode. You go in to it & touch The S.P. on the display and then turn the main power switch off and then back on and that is that is needed. But if that did not work you will need to go deeper in to the problem.
Dec 16, 2008 | Ricoh Aficio 1035 Copier
Error: Printing data is inaccurate, printing processing is stopped Printer error page is printed with this error prints fine from the webpage printer is installed on windows 2000 over a network
I got the same error with another type of sharp photocopier AR-M257
My error, I was installing the wrong driver.
I installed the Sharp driver with the PS at the end.
You can download from here depending the version of the Windows you have
http://www.sharpusa.com/products/business/copiers/business_copiers_drivers/
Good luck!!
Aug 22, 2008 | Sharp AR-M207 All-In-One Laser Printer
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
