Question about Garden
Replacing cutter belt on ranger rover auto drive ride on mowermodel 1866 can it be fitted without dismantling under carriage etc
2 Suggested Answers
  • 45551 Answers
SOURCE: Replacing cutter belt on ranger rover auto drive ride on mower mode 1866 is there any adjustment tensioner or should it fit in very easy
there should be a spring loaded belt tensioner involved
Posted on Apr 21, 2017
How to replace cutter belt Lawnflite ride on mower 903 auto drive , it came off and don't have operator manual for configuration
There are idler and tensioner pulley's, you sould maybe go to a dealer they could maybe help with the proper routing.
Apr 18, 2015 | Garden
Installing a belt
First thing is to draw a map of where the existing belt goes.. Up under the bonnet with a permanent marker is a good place. Release the adjuster/tensioner pulley/s and take the old belt off. . Fit the new belt ensuring that it sits properly in the pulley grooves and re-tension the pulleys
Jan 15, 2014 | 1995 Land Rover Range Rover
Error 03130031 - 2F13
Error 03130031-2F13
1. Check for abnormal carriage drive load
a. Faulty carriage idler pulley (broken spring hook, dropped belt teeth)
b. Faulty linear encoder sensor
( soiled or flawed linear encoder, or improper mounting position / tension )
c. Soiled carriage rail ( unlock the purge unit and move it by hand)
* Never oil the carriage rail!!!
d. Improper carriage belt tension
e. Foreign matter inside the rail (cutter, cleaning brush, bearing out of position)
2. Check carriage motor drive at electrical fault
a. Drive signal / voltage error
Check main controller J3101-1 for 32v during initial operation at start up
b. Upgrade firmware if it is v1.31 or any earlier release
c. Poor connector contact / wiring
d. Faulty motor (replace the carriage motor and / or the main controller )
If the error occurs before the start of printing, the main controller is most likely faulty.
The problem is reported to have occurred as a result of a faulty cutter, depending on the version of firmware.
or>>>>>>>>>
If Replacing the Print head does not resolve the problem. Try re-seating the Flex Cable, cleaning the Linear Scale and the Carriage Rail may clear the code.
Bushings in Carriage Unit get lubricated in the factory.
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 27, 2011 | Canon imagePROGRAF IPF710 Printer
I have a victa corvette cox made ride on mower
Being cox made I'd go looking for cox manuals for the same era. Victa just rebadged others mowers.
Nov 18, 2009 | Garden
Rover racher auto drive no forward drive reverse
band is out in training time to rebuild training
Aug 29, 2009 | Garden
Belt diagram for craftsman mowermodel.944.603241 14 hp 42''
Make sure you have the right belt and to install new belt place the inside of belt (V) in the pulleys and the outside of belt (FLAT SIDE) up against idlers. When on properly belt should be snug.
roundo4
Aug 11, 2009 | Garden
Honda HTR3009 riding mower runs great but won't engage in any high speeds. It slowly goes forward and in reverse - no power. When cutter is engaged, it won't move at all. What might be the problem?
sounds like your drive belt is slipping.
look under your engine (you may have to raise the cover to engine to do this), see if the belt that is around the pully which is on your engine drive shaft is on correctly or is in need of replacing.
Jun 24, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
