Question about Garden
Mower cranks over fuel pump working spark to plugs mower won't start?
    New Friend:
  • 29 Answers
The above answers are good places to check, however, any combustible engine needs three things in order to work. Fuel, air, and compression. If the above answers check out, you may have a compression problem. To check, remove spark plug and put one of your fingers over the hole the plug came from and have someone pull on the starter rope or turn on starter, if electric start. Your finger should be forced out of the hole. If not, then you probably have internal engine problem, which could be several things. Valves and or piston would be prime suspects. Sticking valves caused by bent valve stems. Valves not moving due to bad cam. Worn piston rings. Broken piston rod. Etc. These, however, usually give an early warning before giving out. When last used, was there any unusual noise? This implies that there is no or very little compression felt from spark plug hole. Hope this further helps diagnose your problem. Good luck.
Posted on Apr 21, 2017
  • 8 Answers
SOURCE: lawn mower wont start. changed air filter, spark
Does it turn over? If it does, what happens? Does it sound normal when its cranking? I need more information to help. Is it a push mower or riding mower? Does it start by key or pull start?
Posted on May 01, 2010
  • 10 Answers
SOURCE: Have John Deere 165 riding mower. Strong crank,
Has it been outside? May be water in the fuel.
Posted on Jul 25, 2010
  • 2239 Answers
SOURCE: mower won't start spark plug turns black
Black carbon fouling on the plug is a sign of the engine running too rich, start by replacing the air filter and plug and try again.
Posted on Jun 17, 2012
SOURCE: Snapper Big Six Mower. New spark plug, cleaned carburetor&fuel tank, new 91 octane fuel mower starts with engine starting fluid but won't stay running
Try taking the float bowl off and clean out the orfus. It will eather be in the nut holding the bowl on or in the end (sides) of the pickup tub the nut scews on.
Posted on Jun 30, 2012
  • 4 Answers
SOURCE: cub push mower starts but won't run. i changed fuel and spark plug. what next?
MAKE ADJUSTMENT TO CARBURATOR,TURN SET SCREW COUNTER CLOCKWISE, HALF A TURN,TRY STARTING MOWER,IF IT STARTS TURN QUARTER MORE,THAT SHOULD DO IT, GOOD LUCK
Posted on Aug 10, 2012
Testimonial: "I'll try this solution tomorrow. thank you for the help"
Lawnboy mower model 10743 will not start
When choke not on all the way coil willnot activate and throw spark ps carby should be cleaned out properly because fuel will off evaporated leaving oil guming up needle/seat
Jul 03, 2016 | Garden
Ferris mower cranks but won't start
FIRST DO HAVE GAS IN TANK,CHECK TO SEE IF VTHE BLADE SWITCH IS ON.NO THAT OUT OF THE WAY STILL NO START YOU WILL NEED TO CHECK FOR SPARK AT THE PLUGS,CHECK WITH A PLUG TEST LIGHT,IF YOU HAVE SPARK AN FUEL,PULL THE FUEL LINE FROM THE FUEL PUMPTO THE CARB,HOOK UP A TEMP LINE PLACE IN A POP BOTTLE AND CRANK IT OVER,IF YOU HAVE NO FUEL ETHER YOUR FILTER IS PLUGGED OR THE VACUME FUEL PUMP IS BAD.STEVEH
Apr 16, 2014 | Ferris IS2000 61"" Zero Turn Lawn Mower...
Cub push mower starts but won't run. i changed fuel and spark plug. what next?
Aug 10, 2012 | Cub Cadet Street Sign- tractor lawn riding...
I have a snapper 28 hi vac riding mower that won't
first try and start it with carb cleaner or starting fluid with the air filter out if it fires then its a carb/fuel problem if not it could be a spark problem remove the plug connect hte wire back up and crank the engine over while looking for spark if no spark disconnect the kill switch wires from the side of the engine should be a single wire near the throttle cable if spark with that off the problem is in the wiring or safety switch if still no spark its the coil
Apr 23, 2012 | Briggs & Stratton Garden
My 1976 sears 18 hsp riding mower quit running now it just cranks but won't fire it has a onan engine
check for spark then spray a little carb cleaner or starting fluid in the carb if it fires its a fuel problem filter pump carb
Apr 10, 2012 | Craftsman Garden
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Lawn mower won't start with out being jump started . Changed battery. After jump starting mower and while mowing engine stalls while mower deck engaged . If mower deck is shut off before it looses...
HI jLAFORCE 1.
Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
Top 5 Mower Troubleshooting Tips ' Briggs & Stratton
https://www.briggsandstratton.com/eu/en.../top-5-mower-troubleshooting-tips.html
Lawn mower won start Google Search
Nov 30, 2017 | Simplicity Vacuums
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Garden Logo
29 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
