Question about Lands Phones
Phone stuck on parallel. How do I fix it? - Lands Phones
My Phones don't work. They only display PARALLEL SET ON. How do I fix this?
Try unplugging the device or pressing the reset button if available.
Mar 08, 2011 | Vtech CS5121-3 Trio Cordless Phone
What does parallel set on mean on a vtech phone
parallel i believe refers to the ability to use multiple handsets on one line and one call. This phone has the ability to isolate a telephone call so that only the original answering handset can tune into the conversation. If you only have one of these models then this setting has no real function.
Pls Rate This Post :D
Feb 11, 2010 | Vtech Digital Cordless Telephone VT-2568
What do parallel set on the phone mean
my phone has been stuck on parallel on for 4 days now and i cant remove i have removed battery unpluged entire phone for 12hours and still cant call out and no one can call me
Nov 02, 2009 | Vtech 5.8GHz Cordless Phone with Digital...
I attached one t7630 to another (parallel). The
Parallel is just a method of connecting phones. It has its own set of programming, both extension number, class of service, and ringing.
If you have access to system programming, you can add this phone to an ICD group with the other extensions. If not, you'll have to get in touch with your installer/dealer to make the changes.
Carl
Sep 24, 2009 | Panasonic KX-T7630 Corded Phone
Parallel set on
I have the same problem, how do I get it off ?
Mar 28, 2009 | Motorola Mobility E51 MD7161-3 Quad...
A new phone system I have bought requires the jacks in my home to be in parallel. If I remove the cover from a phone jack, is there a way to tell if it's hooked up in a parallel circuit? If it's not in...
A parallel phone system means all phone jacks are connected in a series. From phone jack A to phone jack B to phone jack C. That means if jack A is not functioning properly or has a short ,all other phone jacks in that series will cease to function. The other type of system is a home run system.Meaning all phone jacks are ran independently outside to service provider NID Network Interface Device. This is the best to trouble shoot because if one jack fails the others will continue to operate independently. The best way to check is to remove the lead from one side of the phone jack, after carefully removing from wall. Check for a dial tone at other phone jacks if no, replace lead at the initial jack. If dial tone returns you have a series system.
Oct 13, 2008 | Lands Phones
Philips dect answer machine cd2352s/05
Answer machine cut off , it may related to parallel phone detection, setting. So try not parallel any other phone with the DECT phone.
Jun 14, 2008 | Philips DECT 2252S Cordless Phone
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
