Question about Asko Washing Machines
Asko washer washer has no power: dryer works fine
  • 604 Answers
Circuit breaker,post one question only
Posted on Apr 21, 2017
Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as,, etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
May 16, 2010 | Asko Dryers
Asko 12505 has no power
i assume you checked the fuses with a meter?how old is the unit?
Sep 16, 2007 | Washing Machines
Asko dryer has no power.Washer ok
By-passed fuses,dealer said he's done hundreds.Saved me a service call.This is the 1st and only problem we've had in 10 years! We love our Asco.
Feb 16, 2010 | Asko Dryers
Power light is not turning on. I have replaced the 2 15 amp fuses in the washer (not ASKO fuses) and I have confirmed that the beaker panel is working fine and the dryer which is linked to the washer is...
There is need to check if there is power getting at the fuses and power getting to timer control board.That is done reading volts with a multimeter.
For safety reasons I need to remind that all test with live power must be done by a trained repairman.
If there is no power at all and you already replaced the two fuses, then problem can be power cord, internal wiring harness, control assembly .
Sep 08, 2009 | Asko Washing Machines
I need to know if a new Asko Dryer will stack with my old washer
The exterior size hasn't changed and the plug to run the washer is the same so I don't see a problem. A good retailer can check this for you , but I haven't seen any difference in the stacking kits.
Feb 12, 2009 | Asko T712 Electric Dryer
Asko stackable dryer/Bosch stackable washer compatability
If you arer going to replace the washer with a Bosch Axxis model, it will simply plug into the back of the dryer (if it is electric) because normally the dryers are 220 VAC. Works A-OK.
Nov 23, 2008 | Bosch Axxis WTA 3510 Electric Dryer
My Asko W620 washer won't spin the first time through.
Try Googling (asko)(W620)(manual) without parens.
Jul 22, 2017 | Asko W620
Asko 7005 and washer 10505
1) there is a reset button on the back panel of you dryer it is in the middle black rubber...
2) you really can't the asko washer needs a 240v to run... You can hire an licenced electrician to wire a 240v plug for your asko washer if you do not want to plug it into the dryer
Jul 01, 2008 | Asko W6021 Front Load Washer
Washing Machines Logo
37 people viewed this question
Top Asko Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you an Asko Washing Machine Expert? Answer questions, earn points and help others
