Tv is stuck on aux
Push the "menu"button on the front of the unit. That will get you into the menus to adjust any setting, like caption, language (but that one is tricky if yours happenend to be set to a language you couldn't understand :P), brightness settings and the such are there too. The one you are looking for is "input", change THAT setting. with either volume up/down +/-, or channel up/down (+) (-). In the menu, change the "input" selection to cable or whatever you are trying to watch on the tv.
Hope this helped some, if so, please rate, thank you!
Channel setup
V-Chip Setup
Caption
ect.
Using the Volume + and - along with the Channel up (+) and down(- ) key's, will give you all the adjustments you may need without a remote control.key's, will give you all the adjustments you may need without a remote control.
