Question about Drills
I need a wiring diagram for a older 6/12 volt sun 360 battery charger or just a pic of the inside
frankzen
  • 19 Answers
SOURCE: Hi. I need a Sears Craftsman 16 volt battery
www.craftsmancordless.info
Posted on Apr 04, 2009
SOURCE: Zivan NG3 battery charger diagrams
your NG3 should have been preprogrammed for the type of batteries you are charging. The NG3 has the 3 wires from the power cord. Here is what I have done:
Brown from charger goes to black wire
Blue goes to white wire
yellow green goes to green ground.
Posted on May 30, 2009
  • 53 Answers
SOURCE: wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Posted on Nov 05, 2009
SOURCE: I need wiring diagram for a Broaster pressure fryer Model 1800E
I have a service manual for the 1600 and 1800 Broaster and it has wiring diagrams in it
Posted on Dec 18, 2010
SOURCE: My son removed the batteries
The red and blue posts are jumpered on the right side if you are looking from the front. (There is just a wire connecting these two terminals)
The other red post has red and turquoise wires. The other blue post has white, blue and black wires going to it.
Sometimes easier to find solutions under Homelite brand. Exact same mower.
Posted on Sep 29, 2012
Do you have a wiring diagram for a Schumacher se-1010-2 battery charger?
What did you find on Google and forum sites are also a great sourse of information.
Sep 16, 2014 | Schumacher SE-1010-2 12-Volt 10-Amp Dual...
Wiring diagram se-4020 battery charger
try this web site
http://www.manualslib.com/manual/523935/Schumacher-Se-2254.html Schumacher SE 2254 Owner Manual
Feb 08, 2014 | 10/40/200 Amp 6/12-Volt Manual Battery...
Wiring Diagram For 12Volt Monster Trax Convertible Car 12-Volt Battery-Powered Ride-On
type: redman 12v red convertible schematics or wiring diagrams search google images I found the pics!
Sep 20, 2013 | 12Volt Monster Trax Convertible Car...
Scooter wiring diagram
Bad connections on the battery posts is most likely. If the circuit breaker was bad you'd get nothing at the battery . The charger voltage is 29 volts when not connected to the batteries. 26 or more when connected and on.
Jun 30, 2013 | Pride Mobility Revo 3 Wheel Electric...
Wiring diagram battery pack aspire 5580
Are you asking for the wiring diagram inside the main Battery?
If so, due to very possible injury, or death to you, there will be No solution.
Now, if you are talking about what is the polarity for the plug of the AC adapter, (Charger), that plugs into the DC Power Jack on the laptop, (DC _IN), then I'm on board.
The Center Hole in the plug end is the Positive ( + ) connection.
This is where the Positive (Red) probe lead of the multimeter goes.
The cylindrical outside metal shell is the Negative connection.
The Negative (Black) probe lead of the multimeter touches here.
Voltage is 19 Volts DC.
Wiring diagram for the inside of the AC adapter itself?
No gottom.
Regards,
joecoolvette
Oct 22, 2012 | Acer Aspire 5580 Notebook
I need to know how to wire the batteries together on my shoprider jimmie chair so they will charge
If the charger is 24 volts and you have 2 12 volt batteries they have to equal 24 volts , so wire the batteries terminals red to black and connect the charger to the other terminals red to red and black to black.
Feb 10, 2012 | Shoprider Jimmie Power Wheelchair
Both Battery clips have come off of Schumacher SE-5212A Charger. Need wiring diagram to make sure I replace them correctly to the battery cable wires.
use a voltmeter. turn on unit to a low setting, place volt meter leads on broken wires one on each. if the voltage goes positive on meter. the positive clamp goes on the wire that the positive(red) voltmeter lead is on and the same for the negative.
Good luck
Jun 28, 2011 | SE3010 2003010 Amp Manual Starter and...
I need to find an 1998 oldsmobile regency wiring diagram for free online the battery does not stay charged i have tried switching batteries and still does the same thing its only staying charged for the...
if the battery cable end have corosion on them the current is not able to charge battery. If you put a multimeter on volts dc 20volts and the car is running and charging properly, the meter should read approx. 14.73 volts. Clean the inside of the cable ends, and the posts on the battery with a wire brush, then coat all of them with some vaseline. Hook them up and tighten. If that doesn't work you will probably need the diagram, to trace a dead short.
Aug 29, 2010 | 1998 Oldsmobile Regency
Mar 11, 2009 | Ryobi Multi-Volt Battery Charger
NO SOUND
HELLO MR GRUMPY I HAVE A SOLUTION FOR THIS IF YOU CAN DO IT YOURSELF ALL YOU NEED IS A PP9 6 VOLT BATTERY 2 WIRES AND 2 PINS THIS INJECTES 6 VOLTS ..... THE 360,S SOUND COMPATABLITYS ARE __Audio __Multi channel surround sound output __Supports 48khz 16-bit audio __320 independent decompression channels __32 bit processing __256+ audio channels ....__..........................................__PLEASE DICONNECT ALL RF LEADS /POWER SUPPLYS/WIRED PADS FROM 360 BEFORE TRYING THIS AND ANY DISK IN THE CONSOLE TAKE 360 APART TILL YOU HAVE THE 360 BOARD IN FRONT OFF YOU USE THE GRAPH ON THE BOARD I HAVE POSTED AND FIND THE PART ON THE PIC LOCATION 8N/8P MEANING 8 POSITIVE 8 NEGITIVE ......__NEXT BATTERY WITH 1 WIRE COMING FROM NEG AND 1 WIRE COMING FROM POS YOU ONLY HAVE TO TOUCH POS WIRE TO POS LOCATION ON BOARD AND NEG TO NEG ON BOARD BOTH AT THE SAME TIME NOW PUT YOUR 360 BACK TOGETHER ....WARNING DONT PUT NEG TO POS OR VICE VERSA I WONT BE HELD RESPONSIBLE FOR ANY DAMAGERS ETC
Jun 01, 2007 | Microsoft Xbox 360 Console
Drills Logo
56 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
