Question about The Office Equipment & Supplies
After scanned will no appear in the image garden
When using ADF, a stripe appears on paper when copying and the same appears on a scan image, but the stripe does not appear on paper copying or on scan image when using the scan bed.
When you get marks from the document feeder it is dirt on the narrow optical strip that collects the image. Hinge up the rectangular lump at the top end of the feeder and clean the glass strip with alcohol hand sanitizer on a tissue and polish off. Whilst you at it clean the glass on the scan platen.
Apr 18, 2016 | Canon Pixma MX922 Inkjet All-in-One...
How to have white background on small documents
All areas outside of the document will be black only. I don't know how you were getting white background.
If you want white background around your scanned image, a) stick the check (in this example) onto a white paper and scan the whole sheet. Ensure double detection is off. b) You can also do this in software, by cropping a larger area outside the scanned image.
There are many options to view the scanned image like Actual size or Fit or Fit vertically or Fit width. The same image will appear different in each case.
S. Mohan, India
Jun 27, 2013 | Canon DR-5010C Scanner
I am out of ink cartridges (none in the printer) but I just want to scan something...how can I do this?
You can still scan using either the command menu on the scanner or the HP software from you computer. As long as you are not trying to print, having no ink should not effect the scanning.
If you have the HP solution center software, you can open that application and pick scan a document or scan a picture.
From the PSC 1610v controls follow these directions:
Scan to an application
You can scan originals placed on the glass directly from the control panel.
1. Load the original face down on the right front corner of the glass.
User Guide 59
Use the scan features
2. In the Scan area, press Scan To.
The Scan To menu appears. The Scan To menu lists destinations, including
applications, for anything you scan. The default destination is the one you
selected the last time you used this menu.
The Scan To menu can be configured. You can designate which applications and
other destinations appear on the Scan To menu by using the HP Image Zone
software on your computer.
3. To select an application to receive the scan, press until the destination you
want appears on the control panel display, and then press Start Scan.
A preview image of the scan appears in the HP Scan window on the computer,
where you can edit it.
For more information about editing a preview image, see the onscreen HP Image
Zone Help that came with your software.
4. Make any edits to the preview image in the HP Scan window. When you have
finished, click Accept.
For more information on editing a scan in the HP Scan window, see the onscreen
HP Image Zone Help.
The HP All-in-One sends the scan to the selected application. For example, if you
chose the HP Image Zone, it automatically opens and displays the image.
If you don't have the HP solution center, you can download it from this link:
http://www.hp.com/global/us/en/consumer/digital_photography/free/software/photo-creations.html
If you found this answer helpful, please remember to leave positive feedback.
Mar 01, 2011 | HP PSC 1610v All-in-One Printer
How to scan
Here is the manual:
http://h10032.www1.hp.com/ctg/Manual/c00238458.pdf
Page 45 will give you the scanning instructions.
1 Load your original face down in the right front corner of the glass.
2 In the Scan area, press the Scan To button.
The Scan To menu appears, listing destinations, including applications, for
anything you scan. The default destination is whichever one you selected the last
time you used this menu. You designate which applications and other
destinations appear on the Scan To menu by using the HP Image Zone on your
computer.
3 To select an application to receive the scan, use or to select it, and then
press OK or Start Scan.
4 Make any edits to the preview image in the HP Scan window. When you have
The HP all-in-one sends the scan to the selected application. For example, if you
chose the HP Image Zone software (Windows) or JPEG to HP Gallery
(Macintosh), it automatically opens and displays the image.
Jan 27, 2011 | HP OfficeJet 6210 All-In-One InkJet...
When scanning a reversed image appears.
hello,
SmarThru 4 will help you to solve your problem, just google it :) it's free :)
May 21, 2010 | Samsung SCX 4521F All-In-One Laser Printer
How to scan with mac
    1. Connect a compatible scanner to your computer. A list of compatible scanners is available in technical document 107203 "Mac OS X 10.2: Scanners Compatible With Image Capture "
    2. Install any necessary software drivers that came with the scanner.
    Note: Not all scanners require the installation of additional software drivers.
    3. Turn on the scanner.
    4. Press the scan button on the scanner. See the documentation that came with the scanner for specific instructions. Image Capture opens automatically and a preview scan appears.
    5. Select the area of the image you want to scan.
    Figure 1 Preview image with area to be scanned selected
    6. Click Options in the toolbar to adjust settings specific to your scanner.
    Figure 2 Options icon
    7. Adjust any settings in the drawer that appears.
    8. Click Scan.
The scanned image is saved in your Pictures folder in your home directory and opened in Preview.
Note: These are the default options. They can be changed in the Image Capture toolbar.
Jul 16, 2009 | HP Photosmart C6280 Printer
Help
Scanning
The following steps show you how to scan and save images.
1 Open the top cover of the All-In-One.
2 Place the item you want to scan facedown on the glass. Make sure the
upper left corner of the front of the item aligns with the arrow
3 Close the top cover.
4 Open the Lexmark All-In-One Center
The All-In-One Main Page appears.
5 Click Preview Now located in the upper right corner of the All-In-One Main
Page.
An image of the scanned item appears in the preview section.
6 Click and drag to select a specific area of the preview image to scan.
7 Click See More Scan Settings to review and change the scan settings.
8 Select your scan settings.
From the “Send scanned image to” drop-down menu, select a program to
send the scanned image to, or click the Creative Tasks section to display a
list of projects.
Oct 13, 2008 | Lexmark X1240 All-In-One InkJet Printer
Won't scan legal documents properly
Make sure that you set the paper size in the setup menu for legal - 8.5 x 14 for the manual paper feed.
Jul 01, 2008 | Samsung CLX 3160fn All-In-One Printer
I press scan it it wont scan my picture.
1. To load a picture, lift the lid and place the original face down on the left front corner of the glass, with the sides of the picture touching the left and bottom edges.
2. Close the lid
Scanning a text document
  1. Load the original.
  2. From the HP Director , click Scan Document .
  3. From the HP Scanning dialog box, select the desired options and Scan to destination.
  4. A preview of the image will appear in the HP Scan window. Make any edits from the HP Scan window and click Accept .
  5. Click Scan . The document will open in the selected Scan to destination.
Scanning a picture
  2. From the HP Director , click Scan Picture . A preview of the image will appear in the HP Scan window.
  3. Make any edits from the HP Scan window and click Accept . The HP PSC sends the scan to the HP Photo & Imaging Gallery , which automatically opens and displays the image. The HP Photo & Imaging Gallery has many tools to edit the scanned image. For more information about using the HP Photo & Imaging Gallery , see the onscreen help that came with the software.
Stopping a scan To stop scanning, press Cancel on the front panel. Hope this helps. Good Luck.
Apr 08, 2008 | HP PSC 1315 All-In-One InkJet Printer
22 people viewed this question
Top The Office Equipment & Supplies Experts
Gareth Cockram
Gareth Cockram
Tygh Duval
Tygh Duval
Jerry Greenberg
Jerry Greenberg
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
