Question about Ricoh Office Equipment & Supplies
How to Update the BCU software version to the latest version.for Ricoh aficio 3235c
SOURCE: Software update ruined my playstation 3!!!!!!
I have the same problem. Ps3 stuck on blank screen. I try to reset it and still nothing. Turn off the wireless and still nothing. Please help.
Posted on Oct 17, 2008
M2Tech1
  • 313 Answers
SOURCE: error code SC998 on Ricoh Aficio 1045
The error code 998 is usually for the dimm or application boards read errors try taking the memory out and the app board out and reseat them again.. then go into the service mode via yellow clear button and then enter 107 then hold down the stop button till the panel changes and turn off the copier wait for 5 secs then turn back on.. If you dont know where boards are take the back panel off and on the right hand side there is a box with a steel plate on the dimms Ram..and app boards are there.. Good Luck A..
Posted on Jul 30, 2009
270rexton
  • 762 Answers
SOURCE: i want to update my nokia 7610 phone software
Use Nokia Software Updater (can be downloaded from Nokia.com).
Posted on Aug 24, 2009
  • 398 Answers
SOURCE: Ricoh Aficio SP C811 DN only prints one copy
Sounds like under printer prefferences is set to sample or some such. -Carl (you are using a postscript driver right?)
Posted on May 17, 2010
toy_ladi
  • 484 Answers
SOURCE: Magellan Maestro 4040 update
There is no recent software updates for your magallen maestro 4040.
You just have to wait till a new one comes out.
But the most recent for now is the rev 2.26 version you are having.
When there is a new software update, you can find out through this link,
http://www.magellangps.com/support/product.asp?prodid=1873
Take care
Posted on Jul 04, 2010
Minha Ricoh SPC 430DN deu erro SC 563, podem me ajudar. Sou do Rio de Janeiro - Brazil
  • Code: 563
  • Description: Pressure roller overheat 3 (software error)
    The detected fusing roller temperature stays at 230°C or more for 1 second.
  • Causes: • Defective PSU • Defective BCU
  • Remedy: 1. Replace the pressure roller thermistor (center). 2. Replace the PSU. 3. Replace the BCU.
Ricoh Aficio SPC430DN Error Codes List page 11 from 17
Esto dice que es posible que el Photo Conductor Unit Copier Drum es malo o el Color Copier BCU Engine Control Board es malo.
Jan 26, 2018 | Ricoh Office Equipment & Supplies
How to update Ricoh aficio 3235c firmware
https://www.youtube.com/watch?v=q3J9vMTkDz8
Apr 14, 2017 | Ricoh Office Equipment & Supplies
I have 5 machines Ricoh aficio 3235c showing a massage loading toner and then black toner is empty Althought the toner is full????
This is one possibility, but there are other solutions if this don't work.
The black toner is not set message is displayed. The black toner is not set message is displayed even though the black toner is set.
[Cause]
There is a problem with the BCU lift. The communication with the ID chip is faulty.
[Action]
Apr 01, 2017 | Ricoh Aficio Office Equipment & Supplies
How to make reset for sc 544 for Ricoh Aficio SP 9100DN
Reseting SC 544 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Heating roller overheat 1 (hardware error)
During stand-by mode or a print job, the detected heating roller
temperature reaches 220 °C.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
Related SC code: SC 543
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Jun 08, 2016 | Ricoh Aficio SP 9100DN Laser Printer...
Solid black image on Ricoh 3235C
Check exposer lamp to see if it comes on first. try printing counter report if same problem. Then could be drum unit or not getting a charge to roller on drum. then board could be bad.
Jan 26, 2014 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Aficio 3235c is receiving data but does not print
Check to so if red light on next to print button.if so push it to see what screen is saying. If not then it could be a bad print file. Will need to clear printer que out on all computers and restart them and then turn copier off and back then try something that printed before
Nov 25, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
Faulty gradation print on RICOH AFICIO 3235C
check your driver, postscript? Or quality settings of the printer from the start menu
May 26, 2013 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
My Ricoh Aficio 3235c overlaps clolours when printng
With out seeing copy here is my thought either bad drum if it is streaks down copy or laser unit for yellow is out of alignment . In user tools there is a maintance tab go into it and do color alignment if it fails then could be transfer unit or laser unit for yellow will need to have a copier tech come out to fix it.
Oct 30, 2012 | Ricoh Aficio Type R1 3228c / 3235c / 3245c...
I want download the engine firmware ricoh aficio 850 1085 105e
When I can download the firmware cicu / bcu 8.1 by ricoh aficio 1085?
Mar 27, 2009 | Ricoh Aficio 450 Copier
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
