Question about Cub Cadet Garden
My z force 60 cub cadet starts and runs until you drop brake or drivers arms or turn on pto then it kills.
    Habit-Forming:
    New Friend:
  • 46 Answers
Check in to the deadman seat switch. Sounds like the safety systems are kicking in, make sure your sitting on the seat. Check plug.
Posted on Apr 21, 2017
  • Scott
    Scott Apr 21, 2017
    I have seat switch out and taped down to do testing,switch is good.
  • Mike
    Mike Apr 21, 2017
    Gotta be another safety interlock then if it only does it when you try to use it.
M60 cub cadet zero turn. What causes it to shut off?
There is also a safety switch for each of control arms, they both have to be in the neutral position. You may have to adjust the arms.
Are you checking the resistance at the switches?
Jul 09, 2015 | Cub Cadet Garden
How to replace mower belt for ZTR cub cadet mower
Changing the Blade Drive Belts:
a.Set the parking brake. Remove ignition key and both spark plug caps.
b.Unscrew the wing nuts from the deck covers and remove both covers.
c.Using a 3/8" socket breaker bar or socket ratchet insert the drive end into the 3/8" square opening in the lower idler arm assembly and push the idler arm counterclockwise. While holding the idler arm back, loosen the blade drive belt from the pulley and slide the belt away from the pulley.
d.Remove tension of the PTO belt by moving the belt tensioning rod. Loosen the belt retaining bolt.
e.Pull the tensioner pulley away from the belt and remove the PTO belt then remove the blade drive belt.
f.Reverse the process to install the belt.
Jan 08, 2015 | Cub Cadet z-force 60
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet runs fine until I start the PTO, then it stutters and dies. If I shut off the PTO blade, it will pick back up and run again
I had a similar problem with my cub Cadet. It turned out that the Ignition Module on the engine was cracked. Motor started OK - but died as soon as a load (such as engaging the mower) was put on it.
These are not terribly hard to check, and/or change, yourself. Easy to get to once the motor shroud is removed.
My 25 HP Kohler engine has 2 modules. EXPENSIVE from the dealer - found MUCH better prices online.
Aug 30, 2013 | Cub Cadet Garden
Cub Cadet-Blades won't stay engaged
sounds like either a saftey switch problem or a bad drive clutch on the pto. usuallly the mower shuts down,not the blades, they may have changed this though. my best guess would be a safety sensor try calling your local cub dealer and talking to the repair person he can shed light on the problem.
Jul 24, 2009 | Mtd Garden
Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
108 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
