Question about Kenmore 43142 Front Load Washer
Making a severe clunking sound when spinning/washing cycles. Is it the bearing ?
  • 867 Answers
Sounds serious, like transmision problem.
Posted on Jul 24, 2009
My Kenmore stackable washer makes very load noises in the rinse and spin cycle but still works. Anyone have idea why it's making so much noise
Try spinning the drum by hand when empty, the faster the better. Does it sound noisy or is there a grinding sound? It should sound silent or whir as everything turns. If noisy then it may well be the drum bearings. If it clunks then it may be one of the arms that holds the drum in place has broken.
Oct 05, 2015 | Kenmore Washing Machines
My Maytag MAH-24 Washer suddenly started making a clunking grinding sound in the middle of the spin cycle.
The rear tub bearing is going out, and the cost starts normally about the 450 and up range,
May 27, 2012 | Maytag MAH2400A Front Load Washer
I have an LG washing machine Model WM1814CW. It makes a loud clanking sound in the spin cycle and the back of the drum has a thick black greasy substance on it & has leaked onto the floor. What could...
Thanks for choosing FixYa and welcome to the site. It sounds like it is your spin bearings. It would explain the grease and the noise also. The spin bearings have to do with the spinning of the washer. Usually, if there are loud noises associated with the washer, it is either the motor drive or the spin bearing.
Apr 22, 2011 | LG WM2432CW Front Load Washing Machine
Admiral Washer makes loud steady noise during spin cycle but washes clothes & completes cycle. Possible bearing problem?
If a front loader type, try lifting up on the drum. If it clunks and seems to move somewhat easily, it is probably the front bearing on drum rear support shaft--a major tear-down to replace. If a top loader, try tipping the basket (that spins) in several directions--if it makes clunking sounds, try removing the agitator and check the tub mounting bolts at the bottom center for tightness. If ok, tip the tub again and watch for movement. It may have a bad bearing below the tub at the center area. Remove the tub bolts and pull the tub out revealing the drive hub underneath. Don't know if you would have to drop the transmission to repair what you find. Good luck!
Mar 17, 2010 | Washing Machines
I have a kenmore washer model 41743042200 when it is in the spin cycle it sounds like a bearing is going bad. Can someone confirm what the problem may be. Washer works and sounds normal in all other...
The washer may emmit a low whisteling sound during the spin. It is causd buy the air whisteling thru the holes in the wash drum. The bearings are not easily serviceable, you can check them by grasping the agitator and shaking it slightly back and forth. If you feel a little clunking then you may need the spin busnings replaced ($15-20 parts and a $80 tool)or a new machine.
Nov 21, 2009 | Washing Machines
Ge profile prodigy make clunking before spin cycle
Is there a humming sound? Check you have the hot and cold water supply turned on. Check the water inlet hoses are not kinked.
May 03, 2009 | GE Profile Prodigy WPSE4200A
Clunking during spin
see if the shocks are not broken. if you spin the wash basket by hand and hear a grinding noise, then your bearing would most likely be bad
Dec 17, 2007 | Frigidaire GLTR1670A Front Load Washer
Kenmore 43142 Front Load Washer Logo
126 people viewed this question
Sal De
fordexpert
Robert Rankin
