How to solve the E 23 error on TOSHIBA TOP LOAD WASHING MACHINE model AW-D980SS
  • 1294 Answers
SOURCE: Frigidaire washing machine model LTF2940E
Check your outlet filters, clean out. The machine will not spin if the filter is blocked. Also check your inlet into the machine. Clean screens on both ends of the pipes. Refit carefully.
Posted on Nov 30, 2007
SOURCE: Washing Machine doesn't spin.
kitchen aid "quiet scrub" won't pump out the water? perhaps replace the unit or fix it?
Posted on Mar 17, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a model 27096 top load kenmore elite oasis ...
"F02" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1. Check the drain hose to make sure it is not kinked or clogged.
2. Check the electrical connections to the pump and ensure the pump is running.
3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 27, 2010
kalamazoo222
  • 285 Answers
SOURCE: i have TOSHIBA AW 8500
Toshiba does not seem to support washers in USA. You should go to Toshiba worldwide support at http://www.toshiba.co.jp/worldwide/index.html. Select your country and follow the steps to get a phone number. Talk to a CSR and they should be able to give you a part number and/or dealer near you.
It sounds like you need the Lint trap for your Toshiba AW 8500S washer. Good luck!
Posted on Nov 29, 2010
Chesc
  • 59 Answers
SOURCE: Defy - 13KG Laundromaid 1300
Here's a solution I've gotten from one of the experts..
"Clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters. The motor is unable to drain all of the water in the allotted time.
If you are unsure where the filter is, it is normally behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!"
Hope this helps.. Good luck! :)
Posted on Jun 09, 2011
Toshiba washing machine model aw-9771ubb error code e7-4
On washing machine error code e7_4 display and stop
Not working
Nov 10, 2016 | Washing Machines
Error e7-4 toshiba washing machine aw-b1000gb
Buy american LOL Toshiba is top secret stuff
Jul 02, 2015 | Washing Machines
How to fix error e23 on toshiba washing machine. machine runs for a whikle and then stops
Error Code ( E-23 )--------Clean the LID LOCK sensor,its almost located where you can see the LID LOCK came OUT and IN or Moving--which is functions to LOCK and UNLOCK the door cover ( Symptom ++ the LID LOCK will moving OUT and IN),open all the cover ,take out the LID LOCK sensor,open the LID LOCK sensor case until you can reach the COPPER connector which is act as the SWITCH .CLEAN the COPPER with paper sand or anything possible but not to damage the copper.After all put it back to the place intact.Hope it work,Mine worked with this procedure.+++++Toshiba AW-SD120S COST=== FREE OF Charge ( Do It Yourself )
Jun 10, 2014 | Frigidaire Affinity ATF7000E Front Load...
Toshiba washing machine AW-D80SMS error E61
Top Button washing machine error code e61
Sep 03, 2013 | Washing Machines
Toshiba washing machine model AW 9790s error code E1
E1 is the drainage hose error, check the drainage pipe hose is not blocked damaged or filled with water or frozen, or maybe the return sensor for the hose is switched sensing something is wrong with the pipe but isnt. check the drainage hose ensure all water is out of the hose. open and close the lid one, then press the start/hold button this should reset the error alarm.
I hope this was useful
Feb 15, 2013 | Washing Machines
Toshiba washing machine AW-1160SM error E7-1
my washing maction have a priblem E7 err
Jan 11, 2012 | Washing Machines
My AW-1170S toshiba washing machine was showing error code E9-5...what does it mean?
my AW-1170S toshiba washing machine was showing error code E7 -4...what does it mean?
Nov 13, 2010 | Washing Machines
E70 error code repeatedly comes up when attempting to start a load and you have to cancel and restart 4-6 times before the load washes; again at the end of a load it will come up with the E70 error and to...
Means you are not getting cold water into unit..Either cold water hose is connected to the wrong hose or cold water faucet is not turned on..You can solve this by connecting hose to cold water faucet and cold water inlet on washer..
Nov 06, 2007 | Frigidaire GLTF2940ES Front Load Washer
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
