Question about Toro Garden
My toro 6.5 mower will not stay running - Toro Garden
  • 15 Answers
Try removing the jet in the bottom of the carburetor and cleaning it out. At the same time put a rag underneath the carb when you remove the jet so the gas in the carb can drain out. It may have old gas in it or the jet may be plugged with dirt/debris.
Posted on Apr 23, 2009
  • 41 Answers
SOURCE: Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
Posted on May 14, 2009
#1 Taper
  • 1040 Answers
SOURCE: Toro Tecumseh mower won't start or stay running
Sounds like you need to clean the carburetor. If you need tips on how to do this, just let me know.
Posted on May 31, 2009
  • 17 Answers
SOURCE: My Toro lawn mower won't stay running. It will
You need to check a few things. The spark first, you need to check if it is running correctly, does it have spark, by doing this: take out the spark, put it against a metal surface and pull the pull start if it spark, your good if not you need a new spark plug. Clean out your airfiilter it migth help too. Buy some carb and choke cleaner squirt it up theough the airfilter hole, and start the engine, this will clen the carb. yOU MIGHT NEED TO TAKE OUT THE CARB AND CLENA I OUT THROUGHOULY!!! Try that and it whould work after all these steps!
Posted on Aug 11, 2009
SOURCE: mower will not stay running
cleaning the carb might work soak it in gas foe a lil wile and it may fix the problem
Posted on Sep 09, 2009
Toro recycler lawn mower
if old gas was left in the engine a good carb cleaning will need to be done
May 11, 2012 | Toro Power Lawn Mower
Where is my drain plug on my toro lawnmower
there is one on the bottom of the engine i just run mine out of gas the turn it on it's side and drain it from the dip stick tube
Apr 12, 2012 | Toro Power Lawn Mower
I have a toro lawn mower. For the last 3 seasons the carb get srcewed up. Usually early in the season. The mower just stalls, and then will not stay running. It seems like it just runs out of fuel. What...
If replacing the carb fixes the issue it is likely just dirty or bad fuel in the old one. make it a habit of running your mower out of fuel at the end of the season and ALWAYS use a fuel stabilizer in your outdoor power equipment fuel
May 26, 2010 | Toro Lawn Mower With Toro Power Tools
Toro super recycler mower will not stay running, has fuel and oil and air filter was just replaced
Try replacing the fuel and spark plug. Gas may be bad. Get some fresh from the station not from the can sitting in the garage.
Drain the fuel system and put the fresh gas in.
Good Day.
Oct 30, 2009 | Toro Lawn Mower With Toro Power Tools
10 yr old mower, has not been started for 3 or 4 yrs, won't start
Remove the fuel filter and fuel line and replace then try it, if it still does not stay running you will have to change outthe primer bulb. If you need more innformation let me know. Aslo please rate this as this is a free service and thanks for using Fixya.
Aug 18, 2009 | Toro Lawn Mower With Toro Power Tools
My lawn mower will not stay started
You need to check the fuel line for cracks/breaks. Check the fuel filter if it has one. If these two things are o.k., then you will need to clean the carb. It probably has debris in it.
Jun 07, 2009 | Toro Lawn Mower With Toro Power Tools
May 31, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
