Question about HP Garden
I ordered rebuild kit #MIA11477 (B&S #796184)from J Deere. It did not contain the jet, jet o-ring or float assy. I ordered kit #796184 Won't fit. Do you have a kit # or a replacement carb #.
JD LA110 mower: GX0110A057538, DOM 042307 19.5 HP B&S: 31P677 01 30 E1 062921ZD Nikki Carb: 797712 G02706 6803 D
  • 10865 Answers
SOURCE: float was sticking ,now will only run if i feed it
Here is a website that will tell you where to look for your particular engine number and how to obtain original tecumseh parts. good luck with it. if you need any other assistance please get back. i really do want to help you get your tiller running again.
Posted on May 27, 2009
SOURCE: mower surging
let it surge, it will usually get better as it warms up. These 6.5 Hp engines are fine except they have an cheap badly designed carburator. Nothing can be done about this problem. They all surge eventually.
Posted on Jun 16, 2009
  • 151 Answers
SOURCE: How to set up a carb with 31840 rebuild kit
what exactly do you want to know? Carb. mixture settings are as follows: L-head engines
Tecumseh carbs.........mainscrew 1 3/4 turns idle screw 1 1/4 turns
Walboro carbs........... mainscrew 1 1/2 turns idle screw 1 1/4 turns
L-head and OHV heavy duty engines 1 turns for both
Posted on Dec 27, 2009
  • 430 Answers
SOURCE: I can't seem to find carb. float adjustment info
The bottom of the float should be level/ parallel with the bottom surface of the carb.
Posted on Dec 30, 2009
  • 6468 Answers
SOURCE: what direction float assembly fits into carb.
it goes with the needle valve sitting into the little step on the float
Posted on Mar 26, 2012
1993 waverunner bogging down on take off. New rebuilt carb, will low oil level cause this? Is there a low level switch /?
Only of you have ran the engine out of oil...Sounds like the carbs may not be set correctly.. .Did a professional do the rebuild?..What exactly was "rebuilt".. were any parts replaced?
Sounds like the low speed (pilot jets/air screw passages may not be clean as they need to be??)
Please check the compression on each cylinder..remove the spark plugs... hold the throttle (carbs) wide open when you check this.. spin the motor for 5-8 seconds... you should get 120psi. minimum..(and less than 10psi difference).. if less, it might be time to actually rebuild the top end..(new pistons/rings/hone cyl.).. only bore it if absolutely necessary.. get it measured..
There are only 3 parts in a two-cycle carb that ever need to be replaced,,(unless they are actually broken) The needle and seat assy., the jet needle and the needle jet. ..see pic... parts # 41 = needle and seat assy. #6 = jet needle, #37 = needle jet.
The needle and seat regulate the flow of gas into the carb as the floats rise and fall..,, if they are damaged or leaking the carb will overflow with gas., the needle jet is a orifice with a specific size..The jet needle has a specific size, taper, and length..== The jet needle and needle jet work in unison to regulate the flow of gas from right off idle all the way to WFO..the needle jet/jet needle WILL wear over time causing the fuel/air mixture to become richer and richer and start fouling spark plugs..(this is more pronounced on 4-cycle ATV's)...
I hope this has shed some light on your carb situation...
Good luck...
exploded view of mikuni carb Google Search
Jul 10, 2017 | Yamaha Waverunner Xl 800 / Xlt 1200 Jet...
Hi, John and the usual suspects are:
1. Damaged or restricted fuel tank venting system.
2. Loose float bowl screws.
3. Damaged float bowl o-ring.
4. improper fuel level in the float bowl.
5. Worn or dirty inlet valve or seat.
6. Damaged or leaking float assembly.
7. Particle contamination in inlet fitting cavity.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Gas leaking main air jet XS11 com Forums
OEM parts for Yamaha
Mar 09, 2017 | Yamaha Motorcycles
1998 polars 500 dies wont start back
Try adjusting you mixture a little richer, 1/8 turn on the fuel screw. If this doesn't help get to idle, you will need to rebuild the carb. make sure you get a complete kit to include the float and throttle springs as well as jets and gaskets. Write down your initial mixture settings and try them again on your rebuilt carb. Should be fine. Bending float arms for travel length is tricky, be careful as they can easily break off making them useless. The rest of the process is pretty straightforward. Ensure you place the needle jet keeper ring on the correct groove and the throttle moves smoothly against the spring tension on the cable above the needle valve.
Mar 03, 2015 | ATVs
Backfire in a mikuni 42 on 1998 harley davidson after rebuild
If it's back firing through the carb, usually means it's running too lean, this can be from the float if equipped is set too low, and/or air leaking somewhere. If you made no other changes (new exhaust system for example) and it ran fine up until a problem required a rebuild, double check your work, jets are in tight, no extra gaskets or o rings left from the kit, float level, be sure everything is re installed tight and right. Carbs a fussy, they'll run forever but with little provocation give you a headache.
Oct 09, 2014 | Motorcycles
Won't stay running after prime runs out
starving for fuel. first check for bad/old gas, then restrictions in the fuel delivery including fuel line, filter, or buildup of debris in tank or any sharp bends or 90deg. fittings. then pull the float bowl and make sure the float is regulating fuel fuel into the bowl, but most likely your main jet is plugged. use a fine piece of wire like guitar string to runthru the jet located at the lowest part of the carb that hangs down into the float bowl. the jet will be on the side or bottom of this lower piece. put bowl back on, get gas to the carb and recheck starting problem. good luck. R
Aug 27, 2012 | John Deere Garden
Flymo 46s won't start. Starts to fire when turned
Possible blocked air filter, try as a test running the engine with filter removed, if ok replace with new filter.
May 02, 2012 | Briggs & Stratton Garden
I can't seem to find carb. float adjustment info or other info on carb rebuilds. I have a kit on hand.
Dec 30, 2009 | John Deere 3010,3020 Tractor Basic...
Need a rebuild kit for the hydraulic cylinder that lifts the snowblower - does such a kit exist and what is the part number?
there are rebuild kits for some but not all, check your local jd dealer, my family ownd a jd dealer until last year jd stuff aint cheap. personally id type hydraulic cylinders into google and buy a replacement
Nov 06, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Mower surging silver serieslawn boy 6.5 h.p. tecumseh motor model lev 120 spec 362006a. I cleaned out carb bought a rebuild kit replaced o rings in center jet and another under float also little metal...
Jun 07, 2009 | Tecumseh Lawn Boy Push Mowers Insight...
Garden Logo
19 people viewed this question
Top HP Garden Experts
Dennis Key
Dennis Key
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a HP Garden Expert? Answer questions, earn points and help others
