Question about Keurig Coffee Makers & Espresso Machines
Keurig cleaned etc. Menu light keeps going off as does reservoir
4 Suggested Answers
  • 2039 Answers
SOURCE: The add water light stays on not matter how much water is in the reservoir
lot of time you have a magnet in the water tank fill it with water and gently tap the side of machine the magnet is block or jam on empty
THANKS FOR USING FIXYA
PIERRE
Posted on Feb 24, 2008
SOURCE: my Keurig b60 is spitting water into reservoir instead of kcup
I had a similar problem except there was no water going into the K-cup. I fooled around with the machine for awhile but I had no luck. Figuring I had nothing to lose, I broke out a can of air that one uses to clean computer keyboards. I sprayed the air into the nozzle that puts water back into the reservoir and air came out of the water intake hole but not the needle that puts water into the K-cup. This meant that there was a block between the the needle and the reservoir. I plugged the water intake hole with a towel and my fingers then sprayed the air into the same nozzle. All of a sudden, a large blast of water came out of the needle. The machine worked after this. Just be careful not to put your hand in front of the needle because the water might be hot. Also, unplug your machine before doing any tinkering. Hope this might help some people.
Posted on Feb 28, 2011
heatman101
  • 43501 Answers
SOURCE: My keurig keeps spitting the water back into the
Hi, Place your finger over the tube going back to the tank and force the water through the needle...
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Sep 11, 2011
De-scaled by using vinegar as suggested now every cup tastes like vinegar
Keep filling your water reservoir with water and running it through, until it clears up, it might take a few fill ups of your water reservoir to get the vinegar taste out.
Oct 08, 2016 | Keurig B70 Platinum Brewing System B-70
How do i clean a keurig coffee maker?
Use white vinegar only. Do NOT use wine vinegar, flavored vinegar, balsamic vinegar, etc. Buy the cheapest one that you find in a supermarket. Fill the reservoir up halfway and run it through until empty. Then flush with plain water with TWO (2) full reservoirs of plain tap water.
Sep 18, 2014 | Keurig Coffee Makers & Espresso Machines
My keurig keeps spitting the water back into the water reservoir and not brewing a full cup. I have cleaned the needles and have not descaled. How do I fix it??
heatman101
Sep 11, 2011 | Keurig B60 Coffee Maker
I have the Platinum keurig and the water is going back into the reservoir and not into the cup??? is it beyond repair?
Are you getting a message saying to "de-scale" it may need a good cleaning. That's usually the issue & the quickest fix. If the Keurig (or any other coffee maker) gets lime/calcium build up on the internal components it will ignore whatever has been programmed into it & just keep cutting off, keep making partial cups & just not working properly. Run some white vinegar thru it - fill the reservoir with a strong vinegar/water mix, remove any kcups/my kcup filters, also remove the reservoir carbon filter ( fyi - that's not going to eliminate any lime/calcium in your water - it's just to eliminate any bad tastes/odors) and "make" how ever many cups it takes to empty the reservoir.Depending on the build up - you may need to do this 2 or 3 times. Also run about 2 more reservoirs of just clear water to help rinse out the vinegar mix (otherwise your next cup of coffee will not be what you expected).
This may eliminate your problem & should be done every 2-3 mths. If that doesn't solve it - your Keurig may already be too far gone. Good Luck.
Jul 09, 2011 | Vacuums
Keurig B70 won't stop cycling water. it just keeps draining the resevoir. Water is cold, not heated.
heatman101
Feb 02, 2011 | Keurig B70 Coffee Maker
Today,my keurig started to short cup me, and shortly after that, it will not brew anymore! I noiced while de scaling today( recommended per keurig), that more water is pouring into the water resivor, vs...
The water pump is probably starving for water:1. Remove the clear plastic reservoir and set it aside. 2. Look into the hole that the reservoir sits on. You will see a fine plastic screen that keeps debris from getting to the pump. 3. Clean off the screen. You may have to disassemble the bottom of the machine and remove it to do it right. 4. Put everything back together and the short-cup problem will be history.
Nov 08, 2010 | Keurig Platinum B70 Coffee Maker
My Keurig B60 does not run at all. The screen comes on and says: Not Ready and also says auto off set. The cup lights do not flash. I cannot get the menu to come on. Unplugging it and plugging it in...
Not sure if this will help, but I had the same problem over Xmas. This was posted 8 Jan, and I cut/pasted it here. Sounds complicated, but it's not. Just print it off instead of trying to remember it! I'd be interested to see if you had the same 'codes' as I, and if your machine had hot water when it ran... I have not done anything since that post...
Patient: Keurig B60
Symptom: "Not ready" light is on. Reservoir is filled and needles are clean, so problem is not user related.
Internet search yeilded some hope for another Keurig machine. While turned off, simultaneously press and release the small and med button, then menu three times. You get into a programming/diagostics menu. As you scroll (via the menu button) mine says Ready 602, Brew 265, Autooff 099, Set 007, Set/set 099, Descale 099, and Menu 000.
While at 000, press the med button but do not release. Press and release menu and immediately press small, then let go of small and med together. Pump runs and water is circulating, but is cold. Not sure if it should be cold (just a test routine, etc) or whether the heater is blown or something more troublesome.
Anyone have any ideas/experience with this information (I have no problem in ripping the machine apart if I have to. It can't be that complicated!).
Jan 31, 2010 | Keurig B60 Coffee Maker
Continually running/heating
Coffeemakers have two heating elements: a brew element and a keep-warm element. When the water reservoir has run empty, a thermostat switches power from the brew element to the keep-warm element.
The keep-warm element will cause the thermostat to stay in this condition until more water is added [or power is cut off] which will cool it down to switch back.
However, if the keep-warm element has quit working, the thermostat may be reactivating the brew element. With no water in the reservoir, the brew element will heat up till the thermostat trips again, then cool down, etc. This cycle will repeat until power is switched off.
Mar 31, 2008 | Keurig B50 Coffee Maker
PIERRE
Feb 24, 2008 | Keurig Elite B40 Coffee Maker
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
