Question about Sharp Televison & Video
What does FO mean when air conditioning shuts off.
It runs a few minutes then shuts off, and you have to push reset button. It is sharp brand.
KOakaKO
  • 135 Answers
SOURCE: Air condition problem
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The manual says to clean filter and unplug unit, then plug unit back in and code will be reset.
Posted on Aug 02, 2007
SOURCE: 2002 BMW 325 Air Condition Problem
It needs a new fan control. $80 online and 20min. labor. I just replaced mine in the same car.
Posted on Aug 05, 2008
SOURCE: Reddy Heater Model R150A fires up then shuts down
I think most of your reddy heaters need the oriface cleaned
Posted on Feb 23, 2009
  • 3 Answers
SOURCE: Sometimes air conditioning will blow
There is a pressure sensor welded into the pipe work for the aircon with two wires coming out of it.
Unplug this and bridge the wires together when the car is running with the air con on.
If it is a faulty pressure switch you will hear the clutch on the compressor cut in and out when you touch the wires together..If this works buy a new switch..but you will have to have the car regassed.
Cheers
Posted on Jun 10, 2009
jumptrout51
  • 3361 Answers
SOURCE: GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Posted on Sep 02, 2009
E- 1 flashing and air conditioner not running. I know your suppose to push the reset button and the on button in a certain order but the instructions are incorrect in the manual
Here is a tip that gives a further explanation of that E-1 code. The causes ofthe E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening withyour window air conditioning unit and give you some things to try to help youget your problem resolved.
E-1 Code on Window Air Conditioning Units
heatman101
Sep 27, 2010 | Sharp AF-S120MX Air Conditioner
I have a Sharp window unit that keeps shutting off it flashes E-1. what does that mean. How can I make it work?
Here is a tip that gives a further explanation of that E-1 code. The causes of the E-1 code can be varied depending or the brand of your air conditioner.
Read through this tip... it will help you understand what is happening with your window air conditioning unit and give you some things to try to help you get your problem resolved.
heatman101
Aug 28, 2010 | Sharp AF-S120MX Air Conditioner
The air conditioning takes to long to come on. where is the reset button?
usually a new aircon in its start up stage takes about 2 - 4 minutes before it runs, and then the compressor kicks and all is normal. after a few weeks the system will start normally. there are no reset button but the power button.
I hope this helps.
Jun 13, 2009 | Heating & Cooling
It turns off
The e1 code is a demand to clean the filter. It means the unit has been running for 720 hours. It does not mean anything is broken...unless it hasn't been running for 720 hours. That would mean the "clean the filter" timer is broken! There are 2 reset methods.
1) Unplug the machine. Hold down the power button while plugging it back in and wait until it beeps (for about 5 seconds). Let go of the power button. Unplug the machine again, then plug it in and try to use it as an air conditioner.
2) Unplug the machine. Hold down the Mode button while plugging it back in. Keep the mode button pressed until it beeps (for about 3 seconds). Let go of the mode button. The machine will start. Turn it off by pressing the power button. Resume trying to use it as an air conditioner.
If neither of these work, the "clean the filter" timer is broken and needs replacing.
Jul 23, 2008 | Sharp AF-S100FX Comfort Touch Air...
"Cool" mode shuts off
An E1 error is automatically generated after the AC runs for so many hours to remind you to clean the filter. The owners manual says to clean the filter and unplug the unit, then plug unit back in and code will be reset. However, a User review stated that his code was not reset until he followed a fairly simple routine. "Unplug the unit. Hold down the power button and plug back in. Wait to hear a "beep" and then unplug it again. Plug unit in again and it should restart without E1 code."
Aug 03, 2007 | Sharp AF-S85FX Wall/Window Air Conditioner
Aug 02, 2007 | Sharp AF-S120FX Air Conditioner
Televison & Video Logo
26 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
