Question about Cycling
Shelby 26" bike,received for Christmas in 1949 or 1950. Serial no. 49. 75076 Shel.Co., Black with Red trim on the back & front fenders, has a Spring for a floating ride,chrome, any information?
fastboyz
  • 674 Answers
SOURCE: Front end damage repairs
hey vail pass can get a little scary at times i just love it up there.
check this site out it should get you some parts that are close to you
carpart.com
Posted on Oct 27, 2008
SOURCE: Schwinn women's 26" Windwood front fender doesn't fit correctly.
You have it on backwards.  I had the exact same problem.  Turn the fender around so that the arms that connect to the axel are pointing forward.  They are going to be almost parallel to the ground.  Easy Peasy lemon Squeezy.
Posted on Mar 28, 2009
  • 75 Answers
SOURCE: HOW TO TAKE CHROME TRIM OF THE SIDE OF 1987 MONTE CARLO
on each end of the peice there will be a bolt on the in side of the car you need to remove the inside panels on do the bolts then the rest are plastic clips
Posted on Aug 15, 2009
  • 3600 Answers
SOURCE: would like to change chrome winow trim to black on
It ccan be done but you need a tool to remove the trim not all the trim is replaceable and you can buy from the dealer the parts you need to do it but you don't want to do it yourself unless you don't mind getting your paint scratched up.
Posted on Aug 30, 2009
  • 3600 Answers
SOURCE: need to remove fender trim to get to wheel well to
There are several screws inside the fender well that have to be removed and one in the pinch molding of the car that has to be removed the ones near the engine are snap in plugs and can be removed if you use a flat tip screw driver to remove the plastic push in locks. Remove them to get to the antenna.
Posted on Sep 05, 2009
The age of a shelby bike serial no c14449
You need to do your own research - Google "Shelby bike serial number" or read my tip:
How to determine the year value etc of your bicycle
Oct 11, 2017 | Cycling
Shimano fd-m510 front derailleur spring is stuck
Not a problem that can be diagnosed without eyes and hands on the bike. Post a clear video, or better - take to a bike shop or bike co-op.
Jun 12, 2017 | Mountain Shimano Deore Fdm510 Front...
I have a Huffy bike with a 48cc motor on it. The chain hits my fenders and now keeps popping off
which chain is falling off. the one from the motor? if so check to make sure the sproket (ps i cant spell) and gear fom motor is lined up. on mine i remember having to flip the rear sproket. are you using the chain tenchiner pulley? i think the one that comes with the kit dosnt have a deep enough gruve. i got rid of it all together, and just made the chain fit with like 1.5 to 3 inches of play. ive seen people use the tenchiner from the rear shifting gear on a mountain bike. thats what i suggest. if its the chain from your pedals thats falling of the the guys from the bike shop are messing with you or the alined the wrong chain. or maybe you need to resize the chian they just got the wheel straight.
May 02, 2012 | Huffy 26 in. Cranbrook Cruiser Bike
My 2005 Avensis sedan front windscreen washer does not work - wipers do still opperate. Where is the fuse for this located and what else could cause this problem?
PROBABLE CAUSE Impact to the front bumper pushes the bumper back far enough to break the washer pump hose fitting. CORRECTIVE ACTION Replace the windshield washer reservoir and washer motor with updated parts. REPAIR PROCEDURE 1. Turn the ignition switch to ACC (I) to unlock the steering column. 2. Raise the vehicle on a lift. 3. Remove the right front inner fender. Unhook and pull back the bumper for better access. CLIPS (6 places.) SCREWS (6 places.) RIGHT FRONT INNER FENDER 4. Release the hooks on the upper right side of the front bumper. 5. Remove the clip from the filler neck, then remove the filler neck. FILLER NECK CLIP WINDSHIELD WASHER RESERVOIR CLIP WASHER MOTOR CONNECTOR BOLT BOLTS WASHER TUBES 6. Remove the right front fender trim, and disconnect the washer hose from the 90-degree fitting. CLIP FRONT FENDER TRIM FRONT HOSE 7. Disconnect the 2P connector and the two washer tubes from the washer motor. 8. Remove the washer reservoir clip and the three bolts, then pull out the reservoir. 9. Assemble the new reservoir components, but do not install the filler neck. 10. Trim 85 mm off the end of the 1,260 mm washer tube only. 11. Route the washer tubes on the reservoir. NOTE: The black fitting is for the front windshield nozzles, and the white fitting is for the rear nozzle. 85 mm 12. Install the reservoir. 13. Connect the rear tube to the straight fitting in the wheelwell. 14. Connect the 2P connector to the washer motor. NEW RESERVOIR Connect the rear washer tube. CLIP BOLT 9.8 N•m (7.2 lb•ft) 15. Install the filler neck with the original clip. Connect the front washer tube to the 90-degree fitting. Then reinstall the front fender trim. WASHER FLUID DIPSTICK 2P CONNECTOR FRONT FENDER TRIM FILLER NECK CLIP
May 15, 2011 | Toyota Passenger Cars & Trucks
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
Need a manual for Technics Receiver SA-160
Go and google it as you can buy it on line ... how tough can it be the hook up speaker wires? The small speakers are front and back, left and right in pairs. red wire to red jack on back , black wire to black jack. big speaker goes to sub wolf. jack in back. Now get those wires and play your Christmas music. note jacks may be marked fr fl rr rl sub
Dec 10, 2009 | Audio Players & Recorders
Mar 15, 2009 | Schwinn Windwood 26 Women s Cruiser...
I just purchased a 1990 nissan 240sx and want to replace the radio with a new cd receiver. how do i remove the old radio? it is an am/fm with a cassette player below it.
Just remove these trim pieces (start with the ash tray) I have also included the wiring list
Wiring
Constant 12V+: Red/Black
Switched 12V+: Blue
Ground: Chassis
Illumination: Red/Blue
Dimmer: Red/Yellow
Antenna Trigger: Black/Red
Antenna Left Rear
Front Speakers 4" x 6" Doors
Left Front (+): Blue/White
Left Front (-): Blue/Yellow
Right Front (+): Brown
Right Front (-): Brown/White
Rear Speakers 6 1/2" Rear Deck
Left Rear (+): Red
Left Rear (-): Green
Right Rear (+): Blue
Right Rear (-): Pink
Please rate this a fixya
Feb 02, 2009 | 1990 Nissan 240SX
Cycling Logo
60 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
