Question about Toro Garden
I have a Toro wheel horse mower and need to know how to replace the deck engagement cable I cannot see how to remove the fuel tank to get at it
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
  • 148 Answers
SOURCE: need a manual for a LT1000 craftsman 19 1/2 HP 42 inch mower deck
You can download a free copy at www.managemyhome.com or you can go to www.searspartsdirect.com and buy a copy along with look at the diagram that you need.
Posted on Jul 23, 2009
SOURCE: Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Posted on Aug 02, 2009
SOURCE: Toro model 20038 self propel problem
Try taking the back wheels off and lubricating the joint cogs and wheels with ,say, 3 in 1 oil . The dealer recommended doing this once every couple of years as preventative maintenance when I bought mine , and it has solved sticking problems for me .
Posted on Sep 12, 2009
  • 8404 Answers
SOURCE: NEED MANUAL FOR TORO WHEEL HORSE GARDEN TRACTOR 416-8
As far as I understand, fixya.com does not stock or sell this mataerial. The purpose of this site is to get direction on a course of action to follow ...
Here is my suggestion ... if you have looked in the manuals section of fixya.com and not found what you are looking for, visit the manufacturers web site which is probably www.toro.com/wheelhorse or something very similar ... Google it to find it ... or you could search www.archive.org
Thanks for using fixya.com
If this helps you, positive comments are appreciated
a
Posted on Oct 26, 2009
Toro 52" need a spindle shaft for the deck,part no.78-6710 hard to find & very expensive,maybe there is some used ones around the countryside in Oz on a retired mower deck?
there is three on ebay by your part number. Toro Wheel Horse Mower Spindle Shaft 78 6710 $54 is about average for this type of repair. But if yours is straight and just wore at the bearing area you can JB Weld it back to size .
May 14, 2016 | Toro Garden
Belt diagram install
seems like everyone does but no one knows there model number... darn
Aug 25, 2014 | Toro 3 Standard Blades For Wheel Horse 50"...
Toro wheel horse 14 38 hxl
check your wiers that go to you solinoid but first try to jump your mower usind jumper cables put the red cable on the bottom bolt of your solinoid and find a good ground for the black cable then let you car warm up then trun the key on your mower to start and it will start
May 12, 2013 | Toro Garden
Toro wheel horse rider recycler 8hp-25inch cut model#56132 how to remove mower deck
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Apr 30, 2011 | Toro Garden
WHAT CONFIGURATION DOES BELT GO BACK ON TORO RIDE ON. TORO WHEEL HORSE 15-44 HXL
You can go here and get a manual. Theres a $2 charge but it's worth it and will certainly help you.
Jan 15, 2011 | Toro 3 Blade Set For Wheel Horse 42" Deck...
Repace large belt on toro riding mowermodel14ap80rp744
Not sure what the problem or question is. How to replace the large belt?
Aug 19, 2010 | Toro 3 Standard Blades For Wheel Horse 50"...
I have Toro Wheel Horse riding lawnmower model # 70040 - 790000
need the ser number of the unit. the pulley don't split its one part, i need the ser number . this is no easy job. good luck
Oct 13, 2009 | Toro Lawn Mower With Toro Power Tools
Install belt on toro mower model 70041
For removing/replacing the deck belt, the general method is:
  1. turn off engine, remove key and set parking brake
  2. disengage blade by putting blade engage lever into off (disengaged) position
  3. lower the cutting deck to the lowest position (closest to the ground)
  4. relieve the belt tension (depending on the model, use a 3/8 inch ratchet set to tighten in the square hole of the idler bracket)
  5. remove and replace the belt
NOTE: it's not necessary to completely remove the cutting deck.
Useful diagrams for removing the cutting deck, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14794
For deck belt diagrams, http://216.213.143.2/ProAuthor/ManProc.cfm?ManualID=425&ProcID=14796
If the transmission drive belt needs to be replaced, several components must be removed and special tools (i.e. air/impact wrench) used in order to change the tractor's transmission drive belt. See an Authorized Toro Service Dealer to have your drive belt replaced.
Sep 09, 2009 | Toro Lawn Mower With Toro Power Tools
Mower Deck not level
there is a geared bolt at the deck suspension un lock it and rotate it will raise and lower the deck
Jul 31, 2009 | Toro Co M/R Blwr/Trmmr Rear Bag Kit
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
