Question about Garden
How to replace deck engagement cable - Garden
2 Suggested Answers
  • 57 Answers
SOURCE: craftsman 42 inch deck won't run
Check proper belt routing. These models are a little tricky. Also check tensioner spring.
Posted on May 18, 2009
I need to replace the deck engagement cable.
Craftsman Mower Deck Engagement Cable install - YouTube
? 6:26
www.youtube.com/watch?v=q6cKjePhdqw
Jun 27, 2013 - Uploaded by redneckcomputergeak How-to install a cable engagement on a craftsman lawn tractor. Craftsman, Poulan, AYP, Husqvarna part 175067, 169676 Deckclutch cable with ... seat, but other than that the video was a HUGE help in replacing that cable.
Sep 25, 2015 | Garden
Can I get a picture of a 46" deck layout for a black mtd yard machine so I can c how the deck engagement cable go
Only seen one or two H decks here.
if it is this cable
then it connects to the RH brake assembly and the PTO engagement plate. There is also a spring that connects at the same point on the engagement plate to the right hand frame.
Apr 18, 2015 | Mtd Garden
Clutch cable routing for a craftsman 971289010 lawnmower
The PTO cable will come out the chassis straight down from the engagement lever on the right side of the dash panel. Will be fastened to the frame on the right side in front of the rear wheel with a zip tie. Loop over the brake rod and attach to the deck on a tab at the rear center of the deck. A hair pin will secure it there. The inner cable continues from there under the belt and the spring hooks into the engagement bracket. There may be two hole for the spring to hook into. They are marked 38 or 42.
Sep 02, 2014 | Craftsman Garden
Husqvarna problems
Your deck either engages with a cable or an electric clutch, which one is it. Cutting deck engaged when started is a switch issue.
Jul 27, 2014 | Husqvarna Garden
Sears troubleshooting
It is likely that the pto engagement cable has broke and needs to be replaced. Lower the deck all the way down. With the engine off, kneel on the right side of the mower. look under the mower and find the end of the cable on the deck. It will be near the center rear of the deck and will have a spring on the end of the cable. Once the cable is located reach up and operate the pto lever and watch the cable. The end of the cable should move with the lever, pulling the idler pulley back and tightening the belt. If this movement does not happen replace the cable.
Jul 21, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
My YTS 3000 will run but the blades won't engage. Engagement lever is really hard to push up but when I try to engage blades, nothing. Could it be the cable?
Find where the cable is connected to the deck. Have someone move the lever and watch the end. Does it look rusted or bent?
Unclip the cable at the deck. Then try the cable. If it moves freely there is something rusted, bent or broke on the engage pulley mechanism on the top of the deck.
Nov 02, 2013 | Craftsman YT 3000 42" Kohler 22 hp Gas...
How do you replace the deck engagement cable on a cub cadet ltx 1040
there is a pin,like the ones that hold the deck on,on the end of the cable,pull it up and off to get the cable out,
Aug 11, 2012 | Garden
I bought a new belt for my2005 lt 1000 42" deck
for a deck no.. Most everything on the deck is done by springs.. what i would do is look at the deck make sure nothing is rubbing the belt making it rip apart.. or make it to not engage.. i would with the engine off engage the blade and disengage the blade make sure all the brakes are pulling away from the pulleys and making sure all the arms are moving to tighten the belt.. if nothing is moving then i double check the cable or however engages the deck (all mowers are different) and if need the part. If the cable is not broken and is still on deck make sure all springs are lubed. If you have any questions please dont hesitate to ask
Jul 16, 2011 | Craftsman Replacement Belt for 42" Deck
I have a 18.5 hp 42" electric start craftsman mower. when i went to engage the blades the lever was harder to move than usual and once it was engaged nothing happened. blades not turning! please help.
When you move the lever and engage the blades you are also engaging the belt that drives the blades and sits on top of the mowing deck. Chances are that belt either came off one or more rollers, or broke. The only way to check it out is to get down and look on the top of the mowing deck. Get back and let me know what you find.
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
