Question about Icon Computers & Internet
I want to make a new icon - Icon Computers & Internet
Trash icon
The trash symbol will only show up when you push and press/hold the icon you wish to delete....as soon as you have pressed the icon long enough the trash icon will show up on the bottom in the middle of the screen...then you drag your icon you wish to delete to the trash icon.
Apr 19, 2014 | Visual Land New Prestige 7" Tablet Blue
Tip
How to Change the ICON of an EXE file
Some times it becomes necessary to change the ICON of an executable(.exe) file so that the exe file get’s a new appearence.Many of the Tools such as TuneUP Winstyler does this job by adjusting the Windows to display a custom icon to the user.But in reality when the file is carried to a different computer, then it shows it’s original ICON itself.This means that inorder to permanantly change the ICON, it is necessary to modify the executable file and embed the ICON inside the file itself.Now when this is done the exe file’s ICON is changed permanantly so that even if you take file to a different computer it show’s a new icon.
For this purpose I have found a nice tool which modifies the exe file and will embed the ICON of your choice into the file itself. ie:The tool changes the exe ICON permanantly.
I’ll give you a step-by-step instruction on how to use this tool to change the icon.
1. Goto www.shelllabs.com and download the trial version of Icon Changer and install it (Works on both XP and Vista).
2. Right-click on the exe file whose ICON is to be changed.
3. Now you will see the option Change Icon…Click on that option.
4. Now the Icon Changer program will open up.
5. Icon changer will search for all the ICONS on your system so that you can select any one of those.
6. Now select the ICON of your choice and click on SET.
7. Now a popup window will appear and ask you to select from either of these two options.
  • Change embeded icon.
  • Adjust Windows to display custom icon.
Select the first option (Change embeded icon).
8. You are done.The ICON get’s changed.
on Dec 20, 2009 | Computers & Internet
When i download itunes on my vista home premium acers aspire laptop, all my desktop icons convert into itunes icons and only run itunes. HELP!
go to the control panel select default programs. select itunes on the left and choose defaults for this program. let it load the list and then untick the boxes
Dec 02, 2011 | Computers & Internet
I need to reset password without cd
Instructions
  1. Select the "System Preferences" icon on your Dock, which is the gray image of a cog wheel. Otherwise, click the Apple icon on your desktop screen's menu bar.
  2. Click the "Security" icon in System Preferences, and select the FileVault tab at the top of the Security window. Click the lock icon at the bottom of the window, and enter your system administrator password to unlock the settings.
  3. Select the "Change" button in the FileVault section, and enter the old password. Enter the new password in the "New" field, and enter the same new password in the "Verify" field. Click "OK" to save the new password.
  4. Click the lock icon at the bottom of the FileVault window to re-lock your system preferences.please remember to comment on these post just by saying how helpful it is to you
Nov 25, 2010 | Apple iBook G4 Mac Notebook
My mac book pro now has two safari icons. one on the dock and one on the screen. i can't get rid of one of them, please help.
If you want to get rid of the Safari icon on your dock:
just click on the Safari icon and drag it away from the dock, then let go of the icon.
It should just disappear.
If you want to get rid of the Safari icon on your screen (I'm assuming on your desktop):
-open a new Finder window (Finder> New Window)
-click on the Safari icon on your desktop and drag it to the Finder window, where it says "Applications", then let go of the icon
- it should disappear from your desktop
May 16, 2010 | Apple safari
My icons on my desktop are gone. How do I restore them or put new ones on Windows 98?
Hi hkotterlei
To create new icons, do this
I stopped using Windows 98 ages ago, So, the following instruction is from memory only.
From the Starts -> Program List
  • Locate the program for which you want an icon
  • Right click on it
  • A pop up menu appears
  • Select Create a desktop icon
A desktop icon will be created and placed on the desktop
You can go to that icon on the desktop and rename it by right clicking and ....
Do the above steps for any other programs for which you want an icon on the desktop.
Hope this will help you.
If it does help, please give a rating.
Have a very good day
luciana44
Nov 15, 2009 | Microsoft Windows 98 for PC
New, first use - Do not get new Mac icon on desktop
you get icon on dock if you want more icon on dock , simply hold the click on an application drag it to the dock.
if you want icon on desktop that is a crazy thing . you find all your icon in application folder in macintosh hd.
plz rate it.
Aug 27, 2009 | Verbatim 500GB USB Desktop 500 GB Hard...
Calibrateing
With Windows XP in the lower-right corner of your screen is the Notification Area where there are a bunch of little icons. There should be an icon that looks strikingly similar to your Kodak 5100 AIO printer. Double-clicking this icon will bring up the printer's status window. In the top right-hand corner of this window there are three icons. The first from the left is the maintenance icon that looks like a crossed hammer and wrench. After clicking this icon it should become obvious how to calibrate your new ink cartridges and printer heads.
Dec 03, 2008 | Kodak EASYSHARE 5100 All-In-One Printer
Theres a new message icon but really i dont have a new message
BABYBRAINS - you should master clear the phone this will erase all data , pics , vidz on your phone but will remove the annoying icon.
LOTTIE86 - take the phone and have the firmware reflash if master resetting is not helping.
Apr 29, 2008 | Motorola Mobility L6 Cellular Phone
How can i install icon pack in my windows xp sp2
Change Folder Icon:
  1. Open Windows Explorer
  2. Right klick your folder of choice
  3. Choose Customize tab in the new window
  4. Choose a new folder image for Windows Explorer’s “thumbnail” and/or “icon” view
  5. Navigate to your new icon/image of choice and choose it
Regards
Balisonu79
Feb 15, 2008 | Microsoft Windows XP Professional With...
Computers & Internet Logo
21 people viewed this question
Top Icon Computers & Internet Experts
James Grady
Level 1 Expert
Donna Sander
Are you an Icon Computer and Internet Expert? Answer questions, earn points and help others
