Question about Husqvarna Garden
How to take a a husqvarna 455 rancher to fix the bar chain oil leak problem
    Top Expert:
  • Husqvarna Master
  • 79,865 Answers
Try removing and cleaning the chain oiler first.
Posted on Apr 20, 2017
Changing the chain on chainsaw
remove the 2 nuts holding the sawdust strut/sidecover and remove side cover. remove chain and bar. clean the chain slot and oil holes on bar. install new chain over bar and place remainder of chain over chain sprocket.back off chain tightener until chain and bar fit. reinstall side cover.
Nov 24, 2013 | Husqvarna 455 Rancher 555cc 35 hp 20"...
Husqvarna 455 rancher, chain getting too loose to tighten after one days use age. Bar oil topped off with every fill up of gas. Bar cleaned in the groove, etc. New chain. The bar will no longer adjust to...
indicates incorrect length chain in use
the adjustment slots should be about 1/3 when fitted moving close to 1/2 when adjusted
the correct adjustment is when the chain in the center of the bar is lifted up the bottom segments of the chain are still in the bar groove
make sure that the oiler hole is not blocked from saw dust and chips
Aug 08, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
I have a rancher 455 and it's not suppling enough oil to the bar. Is there an adjustment for this?
The 455 has a 3 position adjustable oil pump, the adjuster screw is up under the crankcase, sprocket side, you need a flat blade screw driver.
Oct 11, 2011 | Husqvarna 455 Rancher 555cc 35 hp 20"...
No chain oil feed
not sure if the 455 rancher is the exact same as my rancher but when the oil feed on my saw seems slow i remove the chain and bar and clean the chain grove. pay special attention to the end that is near the motor there are a couple of places that allow the oil to flow from the saw body to the chain groove and then subsequently to the chain
Feb 25, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 Rancher - oil coming out of muffler and not oiler. Just emptied gas and remixed new batch so that should not be issue. It was working fine until I took off chain cover to clean and got brake...
Re-clean the engine case and loose parts. Start the engine with the bar removed--oil should ooze out of the side port where the bar fits to, but nowhere else. Clean the bar drive end oil passages--especially the two small channels that go out to the chain groove on both sides. If you seem to be pumping excess oil out, there should be an oil volume adjustment screw either in the back case or just underneath the case near the lower run of chain. Turn the screw CW to lessen the volume of oil. Hope this helps!
Jun 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Turning up the bar oil?
An “OM, 455e Rancher, 455 Rancher, 460 Rancher, 2009-09, EN, FR, ES” Follows (may not be your saw):
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2009/HOUS2009_1151382-49.pdf
An excerpt from page 38 of the above OM follows (forcing it may render it inoperative):
Adjustment of the oil pump
Adjustments are made by turning the screw using a screwdriver or combination spanner.
The machine is supplied from the factory with the screw set to position 2.
Turning the screw clockwise will reduce the oil flow and turning the screw anti-clockwise will increase the oil flow.
Recommended settings:
• Bar 13"-15": Position 1 (full CW)
• Bar 15"-18": Position 2 (center)
• Bar 18"-20": Position (full CCW)
These recommendations apply to Husqvarna’s chain oil, for other chain oils increase the oil flow by one step.
WARNING! The engine must be stopped when making adjustments.
All OMs and IPLs can be found here:
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification http://www.husqvarna.com/us/homeowner/support/customer-support/)
15 = week produced – March
00198 = 198th unit Husky produced that week
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Apr 27, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher chainsaw does not pump oil to the chain
If you look under the machine by the chain you'll see a flat head screw (next to the sprocket) which controls the bar and chain oil flow . Try to turn the screw and check if there's any oil flow to the chain . If not you will need to replace the oil pump (part # 537 10 55-02 which will cost you about $35.00) Hope this help
Aug 23, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Bar oiler not working
The chain oil pump must be worn. The pump is fitted behiend the clutch and chain drive.Remove this by turning clockwise.
May 16, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Garden Logo
53 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
