I replaced the control module, due to unit having extended run time and not sanitizing. While waiting for the replacement part I re-soldered the circuit board where the relay had overheated and melted one pin connection. Did this possibly cause the dispenser to malfunction or coincidence?
SOURCE: hobart lx18 no power to detergent pump, during the
you have to go into program and activate the detergent pump.sounds like somebody deativated the det. program
SOURCE: SHU5315UC control panel
My bosch dishwasher finished a load and noticed for a period of time it was making a humming noise,i opened the door and it contnued until i pressed off.With the power button on the noise continues with door open or closed,maybe its the pump the continues working.It shouldn't activate any cycle until you close the door.What could be the problem.
SOURCE: I have to replace a
The solder joints should be flush with the circuit board. Depending on your board clearance, you may be able to get away with a little protrusion, but try and make it as flush as you can.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Wash Cycle Options
Delay Start (model dependent):
This option allows you to delay the start time of your dishwasher up
to 19 hours.
Sanitize:
The Sanitize feature is available only in the Heavy, Auto, Normal and Half Load cycles. Press the
"Sanitize Option" button to activate the Sanitation features during these cycles. The technical sanitation
measures may also improve the drying results. The sanitize LED or The "Water Pipe" symbol will light when sanitation
requirements are met.
Note: The dishwasher automatically defaults to Auto Wash when turned off and back on. If you used the sanitize option
in your last cycle, the dishwasher will default to Auto Wash with the Sanitize option selected when you turn it on.
To achieve proper drying, always use a liquid rinse aid, even if your detergent contains a rinse aid or
drying additive.
Note: The dishwasher indicates low rinse aid by turning on the Refill Rinse Aid indicator LED (for units without
a display) or The "Spray Looking" symbol (for units with a display).
If this light is on, you need to refill the rinse aid dispenser
I got the idea that the "squiggly arrow" has something to do with the sanitize feature also. If you post your model number "on the inside right hand side of your dishwasher door" I'll go get your manual and post the link here. Hope this helps so far! :)
