Question about Hotpoint WMA32 Front Load Washer
Hi, The dial doesn't turn anymore and you have to push it in hard and try and work out what setting it is on. Also the start/hold to reset button has to be pushed several times to get it to start and has now gone inwards.
  • Hotpoint Master
  • 3,463 Answers
You have probably dislodged the plastic moulding in the control module that hold the buttons in place, you will have to remove top cover, soap dispenser draw, and front panel to gain access to the control module.
Please rate my solution.
Thanks.
Posted on Jul 24, 2009
Won't start dial shows h:01
You have set the delay start. Press the button that says "finish in" or "delay start" (depending on the model) unit it is zero. Either that or you have entered the hardness setting and this should come off by just turning to the off position. Some of these d/ws aalso have a reset which is acheived by pressing two buttons simultaneously and this should be printed on the panel (dot under each button joined by a line) or hold the start button. (You haven't supplied the ENr so I have tried to give all possible scenarios) Post ENr if none of the above works.
Mar 19, 2013 | Bosch Dishwashers
My toyota corolla 2006 model has the maint. required lights on. what does that mean?
It means your car needs an oil change, based on mileage. If you take your car to get the oil changed, they can reset the light for you. If you want the light off now, try holding in the odometer reset button, with the key on but engine off, until little dashes appear then one by one dissapear. This procedure may need to be done either on the odometer total mileage or trip A mileage or trip B mileage.
Step 1: Have car off.
Step 2: Push and hold in trip reset button.
Step 3: While still holding button in, turn key to ON, but engine off. Wait for the little dashes to appear and disapear. If it doesn't work on the odometer setting. before turning key off, switch to Trip A setting. If the procedure doesn't work on the odometer setting or Trip A, try Trip B setting.
Step 4: Turn key off. Then start car. Maint. required light should be off.
Jul 15, 2011 | 2006 Toyota Corolla
Hi i have an electrolux ewf 1087 that wont start everytime i press start it goes straight to drain, like from 2 hrs, it will go down to drain for 2 seconds then down to 0, if you turn it off then on again...
Here are two reset procedures for the control panel that might get your machine working again:
  1. Unplug the machine for about 1 minute. Plug it back in and check the machine's operation. If this doesn't work, try the next reset procedure.
or
  1. Turn the dial to Off.
  2. Press and hold the start/pause button and the nearest option button. While holding them down, turn the dial one notch clockwise.
  3. The machine will beep or flash, when it does let go of the buttons.
  4. After you release the buttons, turn the dial slowly, stopping at each click until you get to "off".
  5. Now, turn the dial to any setting, then turn to off.
  6. Check the machine's operation.
Jun 18, 2011 | Electrolux Washing Machines
Whenever I try to make a call from my Nokia N70, it shows me 'Connection Error'. Others are not able to call me.I am unable to send and receive text messages also.Please let me know what kind of...
try a hard reset..dial *#7370# then input 12345 as a password..if it doesn't work turn off your n70, hold power button * 3 and receive call button at the same times, make sure your battery is full.
notes: it will erase all your data in phone memory
May 09, 2011 | Nokia N70 Cellular Phone
Yesterday I "self-cleaned" by oven.
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock. This should help fix the problem.
Feb 18, 2011 | Jenn-Air Ovens
We can turn on the camera, but the OK button does not wok.
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...
thank u!!!
rate me!!
Jul 27, 2009 | Kodak EasyShare CX7330 Digital Camera
I have a technika diswasher,not sure of the model, is approx 3 years old and has a big dial on the left hand side with 7 wash functuions and the power button is smaller and is on the RHS. I cant remember...
I have the same model. You just turn the dial to the setting you want, push the dial back in, turn the (right) power button on then turn the smaller start button on. I use different cycles all of the time depending on whats in the load and this works fine for me.
Apr 27, 2008 | Dishwashers
Blank screen
Try soft reseting your phone. If that doesnt work then try hard reseting.  To soft reset take the stylus pen and push in the little hole on the bottom of the phone. You should feel a little click and then your phone will restart. Wait until your phone  starts up again and if it still isnt working then do a hard reset.
 To hard reset, hold down the green send button and the red end call button at the same time and continue to hold them down as you then push your stylus pen into the hole on the bottom of the phone untill you feel the little click. Your phone should start to reset.  Be warned you will loose any information saved to the phones memory ie: phone numbers, pictures, personal settings. Anything saved to your memory card should be ok.
If your screen remains blank after trying both resets I would suggest taking it back to where you got it and and have them fix it or replace it.
Hope this is helpful.
Feb 12, 2008 | HTC Touch P3450 Smartphone
Camera "dead"
Did you try taking the batteries out? If not, try that and then put them back in again. This might reset the camera back to normal. Also, try turning the dial. Make sure it is at the camera setting, then try shutting it off. Further, move the dial to Set-up, and scroll down to the Reset all setting, press the right arrow and answer "Reset".
Sep 18, 2006 | Nikon Coolpix 5600 Digital Camera
Hotpoint WMA32 Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
