Are there any codes for a Sherwood receiver (RX-4105)to go into a comcast remote??
  • emraqfmfl Jul 24, 2009
    I tried the solution the other expert said to do, and nothing is happening. I did exactly has directed. Please help!
    I have tried 2 different "experts" to no avail. I think since you are charging me 12.99 I should get better service....there has to be a code. Please advise!
  • 6,784 Answers
HI. unfortunately, Sherwood corporation dose not have an affiliation with comcast Inc. this code you seek is not available at this time. Sherwood has been contacted and, this situation should be resolved soon i would imagine. We have searched all detailed literature containg all comcast codes and the Sherwood code is not listed.
There are others that are not listed as well. Sherwood, unfortunately, is among the manufactures that are not listed.
I do apologized for this disappointing endeavor.
Posted on Jul 24, 2009
  • 10,594 Answers
I do not see any code for Sherwood receiver in Comcast remote. Check its manual that has long list of all available codes for that remote.
Please ask Comcast for remote code as they might added it recently.
    Genius:
  • 1,043 Answers
Unfortunately Comcast has chosen not to support the Sherwood brand of Receivers with their Universal Remotes. You can try to have the remote scan for the code. Here are the steps to do that:
1) Turn on your Receiver.
2) On the Comcast remote press your AUX key once, then press and hold SETUP until the AUX key blinks twice, and then let go of the SETUP button.
3) Enter 9-9-1. The AUX key will blink twice.
4) Aim the remote at your receiver and slowly press the POWER key then the AUX key.
5) Keep doing that until your Receiver turns off. This means your remote found a code for the Receiver.
6) Press SETUP once to lock in the code. Your AUX will blink twice.
It is possible that the remote will not find the code for your receiver. If this is the case, you may want to look at buying one of the Universal Remotes that already have the Sherwood Receiver code built in. Many of them will control the Comcast box as well. Good luck, and I hope that you are able to find a code.
How can I get a RX-4103 remote?
Ask them direct. I don't see any aftermarket replacements or second hand.
http://www.sherwoodusa.com
Nov 22, 2015 | Sherwood RX-4105 Receiver
I have a Sherwood RX-4109 receiver. The right side channel has low volume and cracks, can it be fixed?
show me a picture so I can tell if it is even worth fixing. you may be better off getting another one.
Aug 13, 2014 | Sherwood RX-4105 Receiver
I have a Sherwood RX-4105 Receiver and I am getting no sound through my speakers and the connection with the wires is good so its not that. Any Idea on whats wrong?
when you turn your computer you should hear a sound of a relay initially and after about two seconds another sound, is the closure of the speaker relay models if you do not hear the sounds, the team has some short audio output.
Sep 07, 2013 | Sherwood RX-4105 Receiver
I want to hook a amplified antenna to my sherwood receiver what kind of cable or wire should i use?
You can use standard TV cable (RG-59/U) or for a long run the white RG-6/U which has lower signal loss
Feb 18, 2013 | Sherwood RX-4105 2-CHANNEL...
Does the sherwood rx 4105 receiver have analog or digital inputs
Unfortunately the RX-4105 is a stereo only receiver with only analog L/R inputs. You will have to find a stereo output & go in through one of the stereo inputs.
Feb 12, 2013 | Sherwood RX-4105 Receiver
I have a sherwood rc-107 and can't find the code for my grey comcast remote.
Hi John,
You may view the manual and code of your remote control, click this link http://www.comcast.com/corporate/customers/customer_support/remotes.html.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Feb 19, 2011 | Sherwood RX-4103 Receiver
Can I hook the reciever to mm bose subwoofer and 5
if bose unit has built in amplifier .Then your sherwood would have to have a variable RCA output jacks in order to work with sub.Then bose audio input RCA cable would connect there.If bose unit does not have built in amp .Then you would connect sherwood left/right speaker outputs into bose left/right inputs .Then other bose speakers will connect to bose unit
Jul 30, 2009 | Sherwood RX-4105 Receiver
Sherwood rx-4105 output transistors
You can also use 2SD2560 and 2SB1647 130watt 150volt 15amp transistor, but it may require some rebiasing the on output transistors. Sherwood have used these transistors in their older model receivers. I just replaced those transistors in my Sherwood RX-4105 Receiver, and they work good as well.
Before I install those transistor. I did a out of circuit 20volt 4amp DC current test to a 4ohm resistor @ 200watt load to compare 2SD2560 / 2SB1647 to the B2510/B1510 mounting them on 5 square inch, 1/8" thick piece of Aluminum, and the results of the test, the 2SD2560 / 2SB1647 heats up in 60 seconds to around 120 degrees F, and the B2510 and D1510 heats up in 30 seconds to around 120 degrees F.
Mar 13, 2009 | Sherwood RX-4105 Receiver
Need remote code for sherwood rx-4109
Comcast came and the receiver / tv was not capable of being run by another remote as far as volume, just off and on
Jul 20, 2008 | Sherwood Audio Players & Recorders
244 people viewed this question
 Grubhead
Grubhead
