Question about Whirlpool Ovens
Whirlpool model GS563LXSQ 0 oven will not light. I replaced the ignitor and it still won't light. The broiler will not ignite either, although it clicks a few times. The stovetop works fine.
I had a technician out who's ballpark quote was $500.00 to replace the board. When I mentioned I'd buy a new oven before I'd do that, he said new one's aren't as good. Does anybody have any advice?
SOURCE: My Oven and broiler won't heat but stovetop burners work
I have a Frigidaire Model Number GLGF377ASF. The stovetop burners work just fine but the oven and broiler do not work.
Posted on Dec 08, 2008
  • 21 Answers
SOURCE: Amana arg7800ww oven will not come up to temperature.
Your gas valve has a thermocouple circuit that will not let gas flow until the ignitor is hot enough. A failed ignitor can still glow but not be hot enough to open the gas valve. Replace your ignitor.
Posted on Jan 13, 2009
meztang
  • 112 Answers
SOURCE: stove top ignitors do not ignite but oven does.
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 17, 2010
SOURCE: oven glowplug lights but gas will not turn on
Even though the ignitor (glowplug) is heating up, it more than likely still needs to be replaced. They do become weak over time. An oven gas valve requires a certain amount of current moving through the coil in order to open the plunger. The he circuit goes through the ignitor, and the hotter thee ignitor gets, the more current flows through it. As the ignitor weakens, it does not allow sufficient current through the circuit to open the valve. Replace the ignitor and you'll be baking in time for Thanksgiving. Use caution when installing the ignitor, as they are extremely fragile. Also, do not touch the actual element section of the ignitor when installing it.******Remember to remove power from the range before making this repair.
Good luck, and gobble, gobble.
Posted on Nov 18, 2010
heatman101
  • 43501 Answers
SOURCE: Oven "bake" burner wont ignite on a gas oven.
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Posted on Dec 27, 2010
Frigidaire plef398dca
Hello Bill Robbins - From what you are describing it sounds like a wiring failure or a communication break failure between the power board and UIB has occurred. Error code F5, typically indicates that the EOC will need replacing. A certified technician will need to test the wiring harness between the ESC, UIB and EOC.
Jan 21, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Hit "bake" or "broil" button and temp setpoint
Hi
This Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Sep 29, 2011 | Whirlpool RBS305PD Electric Single Oven
Just installed a new oven control board. Clock works but I am getting E0 F3 when I push "Bake".
Hi
F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 02, 2011 | Ovens
Whirlpool gas oven Model sb160peeb5 Broiler lights but the oven does not.
Sounds like you need a glow coil ignitor. The broiler and the oven have seperate ignitors. You can pick up one from First Source parts house.
Jul 16, 2011 | Whirlpool Ovens
Oven won't heat up, you can see a little orange light glowing and it heated a little bit, but now the light does not come on at all. Also, not sure this is a double oven, but it does have the broiler...
heatman101
Jun 15, 2011 | Magic Chef 9112 Gas Double Oven
Broiler won`t lite.i replaced the ignitor but it doesn`t glow at all.sounds like an electrical problem
heatman101
May 11, 2011 | Ovens
Hotpoint oven model rgb745wea1ww oven doesn't light. Broiler and stove top work fine.
heatman101
Jan 04, 2011 | Hotpoint Ovens
I own a Kenmore elite Model 790.4660 electric range. When I attempt to use the oven there is a beeping message "F30ERR" Thank you. Mark
Thank you for question. I understand your concern with your Frigidaire range. Without knowing the model number I can't be 100 percent certain but F30 generally implies an open oven temperature sensor probe. The oven temperature sensor probe is located inside the oven cavity in the rear upper left or rear upper right hand corner. It can generally be removed and disconnected from inside the oven cavity.
Check the wiring harness connections between the control board and the oven temperature sensor probe connector. Check the resistance or the sensor at room temperature with an Ohm meter, if less than 996 ohms, replace probe. Check with meter, for shorted probe harness between control & probe connector.
. I recommend calling a service technician to diagnose and repair your range.
If you do not feel confident repairing this problem yourself, then you can have it repaired at your home by a Sears technician. Here is a link for the website:Sears Home Services
Dec 29, 2010 | Kenmore Ovens
Ovens Logo
60 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal De
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
