Question about Panasonic Televison & Video
On 12th April we stopped being able to get I-player to work. The site comes up as it should, we select the programme, then the screen goes blank and returns to the main channel.
Panasonic 2011 flat-screen with LAN adaptor.TX-L32DT30 B.
jaysicksix6
SOURCE: nec flat screen goes blank after 20 seconds
i got the same prob.supposedly its the cap(capacitor) ,the one for the power suppy near the cord input.im getting my shit fixxed.and i will let you know.
Posted on Nov 02, 2007
SOURCE: Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
Posted on Sep 13, 2008
SOURCE: XM radio express blank screen
Take your battery cover off, then take your battery out. Let it sit for 10-15 seconds, then put your battery back in and put the cover back on. It should work fine. Mine did the same thing over a month ago, and it works fine now with no problems again. I CAN SEE!!!! yeah.
Posted on Feb 22, 2009
  • 80 Answers
SOURCE: Creative Zen MP3 won't charge with mains adaptor
Don't worry that doesn't mean that your mp3 player is faulty, if there is any fault it is from the charger but since the usb charges it well, just continue to use it. It doesn't mean the player is faulty, IT HAPPENS.
Posted on Feb 17, 2010
SOURCE: Panasonic TX P50V10B Plasma TV
In order to get any of the Freesat channels, you need to connect a Satellite dish to your TV. If you have a Sky dish, you simply need to run an extra Cable from the LNB from the dish and connect to your socket on the back of your TV.
In order to get Freeview channels and Analogue channels, you need to connect a aerial to the back of the TV.
There is a menu option for the TV to start straight to the AV input (your Sky HD box). It is Menu > Setup > Other Settings > Power on Preference. Select 'AV' for your TV to start on Sky HD.
Also even if you have your TV to start on TV, when you turn on your Sky HD box, it should automatically switch to the Sky box.
Posted on Feb 20, 2010
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
Thermostat is not coming on we are in san antonio is there help out there for us
Reasons for a Blank Screen on a Honeywell Thermostat ...
homeguides.sfgate.com > ... > Real Estate Rental & Lease Basics
Honeywell and other brands of programmable thermostats typically show a blank ...and the batteries can no longer provide power to the screen, it will go blank. ...electrical system, a blank screen indicates there is no power going to the unit, ...
programmable thermostat troubleshoot - YouTube
? 3:35
https://www.youtube.com/watch?v=pNVTAUcBx-U
Sep 26, 2011 - Uploaded by Maxxmentum
Programmable thermostat started to fail and behave erratically after being in service for a few ... My thermostat works but the remotes have stopped working. .... Honeywell CM907 Digital Programmable Room Thermostat user ...
HEAT WON'T TURN ON How Test if your Thermostat is ...
? 2:36
https://www.youtube.com/watch?v=lSJn69EAcAw
Nov 16, 2014 - Uploaded by You can Fix It!!!!
Heater fails to turn on it does not mean you have a faulty heating system ... 4th - Check programming on a programmable
Jan 10, 2016 | Honeywell Programmable Thermostat Heater
I've got a panasonic sd256 but started the programme on bake instead of bake raisin and now it won't let me alter the setting. How can I stop and start again
Hold the select stop start button until the display goes blank then press the select button.
This works on my SD256
Sep 09, 2013 | Kitchen Appliances - Others
By mistake, I selected RGB connection while setting up in sony DVD NS730P. Now the screen goes blank means output switched from DVD component connection to RGB port. How to return back to DVD componeent...
Please press the DISPLAY when the player is in stop mode.
The Control Menu appears.
Press the up/down arrow to select SETUP, then press ENTER.
Press the up/down arrow to select the RESET and then select Yes from following message.
Press ENTER.
It will reset the player.
Jan 13, 2011 | Sony DVP-NS730P DVD Player
Sony 60in Grand Wega Channel Guide comes up/Screen goes Blank
u may have a bad cable box ( drectv) try a dvd player on the tv if it work fine that means u have a bad cable box ( drectv)
May 08, 2009 | Sony Grand WEGA KDF-60WF655 60" Rear...
Pc wont always turn on and keyboard and mouse wont always work
Sounds like your OS has had some vital system files deleted. you may need to reinstall your OS.
Jan 28, 2009 | Compaq Presario 5000 PC Desktop
Blank blue screen nano.
  • First of all do a reset by holding down the Select and Menu buttons.
  • When it's restarted it if it hasn't solved it press and hold the Select and Menu buttons but as soon as the screen goes dark press and hold the Select and rewind buttons. This puts the iPod into diagnostics mode.
  • From there go to 'IO' on the list using the wheel and Select then to Display and keep clicking select as it goes through the different colours and graduations. Hopefully you see them all
  • when it comes to the end it will ask yo to press Menu, so do that.
  • Click Menu again and again until you see reset at the bottom of a list. Go to this and select it.
  • It will now reset and all will be good in the world.
If that hasn't fixed it then it's likely the ribbon for the LCD has become dislodged or damaged. If it has, let me know.
All the best
Sean
PiDigital
Nov 29, 2008 | Apple iPod nano
My problem is when i am watching a programme i downloaded onto the bbc iplayer or sky player 10 minutes into watching the programme my laptop goes away from the programme i am watching to the acer...
All you need to do is disable the screensaver.
Click anywhere on the desktop that in not occupied by an icon. Select properties, go to screen saver, select none, the hit ok. Your screensaver will no longer come on when you're playing your videos.
Thanks and please take a moment to rate as fixya.
Nov 24, 2008 | Acer Aspire 5315 Notebook
HTC p3300 often hangs up(black screen, no response to any buttons) when programms with high mem. are running e.g media player
try getting a new battery
charge it while its off!
when the charge LED goes off its done..
Nov 10, 2008 | HTC P3300 Smartphone
Televison & Video Logo
22 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
