Question about Philips Televison & Video
I have model #42PF7220A/37 flat screen Philips TV. I am attempting to watch a DVD. Page 22 of the manual says to press the AV+ button. I do not find an AV+ button on this Phillips remote. Drawings of the remote in the manual do not match the actual remote. Also, the menu button doesn't work. Batteries have been tested and are good.
1. How do I watch the same movie on both screens on the Philips PET9422 37 9 in. Dual screen DVD players? 2. I bought a refurbished model but did not get a user's manual. How do I get one?
hi,
You can do the following to watch the same moving in both the screen.
1.Connect the AV out of both the unit together. with supplied av cord
2. If you want to watch the movie played on the first unit then put the DVD/AV IN switch of first monitor to DVD and the DVD/AV IN switch of second one to AV IN.Now you can watch the movie played on the first monitor on both monitors.
3. IF you want to watch movie played on the second unit then put DVD/AV IN switch of second monitor to DVD and the DVD/AV IN switch of the first monitor to AV IN. Now you can watch the movie played on the second monitor on both monitors.
I have the manual of the same . As it is large pdf file can't sent through fixya. If you can sent your email id through fixya will sent you the manual
ok
Jun 11, 2011 | Televison & Video
Red lines on plasma screen.
you may want to check out your buffers.
for cheap buffers check out hssparts.com
thank you
Dec 11, 2009 | Philips 42PF7220A 42 in. Plasma Television
Menu screen keeps coming back while cable show is playing
First verify the exact Model Number of your TV. Mine is a 42PF7220A/37.
go to:
http://www.p4c.philips.com/cgi-bin/dcbint/cpindex.pl?ctn=42PF7220A/37&scy=us&slg=en
On this page I found listed under "Software & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
I downloaded the compressed file and extracted it to a USB Flash Drive.
After you extract the file you will have 2 files...."autorun.upg" and a "readme.txt".
Print out the readme file the delete it off the USB Flash Drive
Make sure the USB Flash Drive has only one file on it (autorun.upg)
Then just follow the instructions from the "readme" file.
Fixed the "Menu" problem for me.....
Sep 22, 2009 | Philips 42PF7220A 42 in. Plasma Television
Menu screen keeps popping up
You can start here: http://www.support.philips.com/support/catalog/catalog.jsp;jsessionid=87CE21B6A8264B83B8D00501ADACA8BF.app107-drp1?_dyncharset=UTF-8&country=&categoryid=FLAT_TV_CA_US_CARE&userLanguage=en&navCount=1&groupId=TV_GR_US_CARE&catalogType=&navAction=push&userCountry=us&title=Flat+TV+(plasma%2C+LCD)
Enter the exact Model Numbere in the search text field.
go to:
I downloaded the compressed file and extracted it to a USB Flash Drive2.gif.
Make sure the USB Flash Drive2.gif has only one file on it (autorun.upg)
Aug 08, 2009 | Philips 42PF7220A 42 in. Plasma Television
Bottom half of the screen goes black frequently.
go to:
On this page I found listed under "Software2.gif & drivers" the Firmware Upgrade Software 42PF7220A/37 v1.5.0.0
Make sure the TV is turned off.
Put the USB Flash Drive in any of the USB ports on the TV.
Turn the TV power on with the Power Button on the righthand side of the TV.
The TV will display an Update screen.
Let the TV run through all 3 processes.
Turn the TV off and remove the USB Flash Drive.
Power the TV back up.
Hopefully the Updates fixed the problem.....
Jul 27, 2009 | Philips 42PF7220A 42 in. Plasma Television
I have a philips 42pf7220a/37. when i turn it on the picture is fuzzy and red.
Any luck with fixing your Model#42PF9630A/37 as I am having the same problem with mine?
Thanks
Feb 23, 2009 | Philips 42PF9630A 42 in. Plasma Television
No sound on the hd setting on my lcd phillips hd tv
look in the owners manual about installing devices or components--- sounds like you have something hooked up wrong that is not allowing the video and sound to work--- if that doesnt work--- try using a combination device and hooking the two items to it--then run that device's wires to the television
Dec 03, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
37PF7320A 37 problem hooking up dvd
Connect the DVD to the back of the set on AV2 red white and yellow rca cable . Then to the other end to the DVD red white and yellow. Turn the DVD on and press play. On the tv remote below the number 7 there is an AV button. Press that button and put the tv to AV2. Your DVD picture should be there.
Jul 04, 2008 | Philips 37PF7320A 37 in. HD-Ready LCD...
Settings screen keeps coming on
Remove the batteries from the remote and see if it still happens. If not, then you have a stuck button on the remote. If it continues, then it is a TV problem.
Apr 06, 2008 | Philips 42PF7220A 42 in. Plasma Television
Televison & Video Logo
213 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
